If someone is interested I made my own custom image:
http://www.linuxsystems.it/2012/06/debi ... mal-image/
Re: Debian Wheezy minimal custom image
Nice one. I'll be having a play with this tomorrow.
Can you elucidate any on A custom 3.1.9+ kernel with latest raspberry pi patches? Do you have a list of what's been patched?
I used latest snapshot of the patches from the raspberrypi's github git branch
Hrm. I can't download from the link provided in your blog post
On clicking the download to disk image, it just comes up with XML content:
... does AjaXplorer require a specific client installed? I couldn't tell from their website.
<tree>
<message type="SUCCESS"/>
<require_auth/>
</tree>
Try opening it in your browser, you will get the real link.
I get the same XML displayed in my browser (IE9) rather than the file downloading/
I would hardly call IE a browser. Please try with a better browser (even links works for me) and let me know if it does work for you. In the meantime I will try to find a Windows machine to test it.
@everybody else
Does it work for you?
@everybody else
P.S.
Please try the new link in the meantime and let me know if it does work.
Nope: Safari Version 5.1.5 on Macdarkbasic wrote:I would hardly call IE a browser. Please try with a better browser (even links works for me) and let me know if it does work for you. In the meantime I will try to find a Windows machine to test it.
@everybody else
New link, faster server. Enjoy
Download link wont even load for me, the other link worked fine.darkbasic wrote:New link, faster server. Enjoy
My fault, it should be ok now.
Yep, download link working now. Many thanks!
I made a new image based on raspbian: http://www.linuxsystems.it/2012/06/rasp ... mal-image/
I rather like the sound of that... now if only I had a Raspberry Pi to try it out on!darkbasic wrote:I made a new image based on raspbian: http://www.linuxsystems.it/2012/06/rasp ... mal-image/
Update:
- Synced to 2012/06/08
- Disabled incremental updates, means apt-get update is much faster
- Workaround for a kernel bug which hangs the Raspberry Pi under heavy network/disk loads.
http://www.linuxsystems.it/2012/06/debi ... imal-image
Could you possibly make an image for slightly under 2gb? I'm trying to write the image to a 2gb card in Windows, but it is complaining that the disk is too small (1800mb i think).
Can you force it? Because at the end I put the swap partition so you will lose no data... Such a way you can easily resize the root partition and create a new swap.
P.S.
Can you write the official debian image? Mine should be of the same size...
P.S.
I'll have a go and report back. I'm playing with Rasbmc at the moment. Really should invest in some more 4-8GB SD cards!
2GB should be enough, mine is 2GB too and works flawlessly...
BTW, the Wikipedia article reads:
Or (as seems to be suggested by the possibility to run the image under QEMU) the non-free drivers are only necessary to utilize the “advanced” features of the GPU (such as, e. g., 3D and video decoding)?
As non-free (= “closed source”) software (including device drivers) is not permitted in Debian (in accordance with Debian Social Contract & DFSG), do I understand it correctly that the image also includes non-Debian software? (And if yes, is there any other non-Debian software beside these video drivers?)The GPU hardware is accessed via a firmware image which is loaded into the GPU at boot time from the SD-card. The firmware image is known as the binary blob, while the associated Linux drivers are closed source.
They aren't drivers. They are closed source implementations of OpenGL/ES and OpenVG.
Wiki wrong as usual, world points and laughs.
Simon
Simon
http://ftp.debian.org/debian/pool/non-free/oneingray wrote:As non-free (= “closed source”) software (including device drivers) is not permitted in Debian
Correct.oneingray wrote:do I understand it correctly that the image also includes non-Debian software?
The kernel isn't Debian software too, as I said it is a custom kernel (basically it is vanilla + some raspberry pi patches, there are no Debian patches at all).oneingray wrote:(And if yes, is there any other non-Debian software beside these video drivers?)
Not quite, as long as http://www.debian.org/social_contract is concerned:darkbasic wrote:http://ftp.debian.org/debian/pool/non-free/oneingray wrote:As non-free (= “closed source”) software (including device drivers) is not permitted in Debian
We acknowledge that some of our users require the use of works that do not conform to the Debian Free Software Guidelines. We have created "contrib" and "non-free" areas in our archive for these works. The packages in these areas are not part of the Debian system, although they have been configured for use with Debian.
ACK, thanks.darkbasic wrote:Correct.oneingray wrote:do I understand it correctly that the image also includes non-Debian software?
I'm curious, are there any specific issues with the Debian patches?darkbasic wrote:The kernel isn't Debian software too, as I said it is a custom kernel (basically it is vanilla + some raspberry pi patches, there are no Debian patches at all).oneingray wrote:(And if yes, is there any other non-Debian software beside these video drivers?)
Conversely, are the Raspberry Pi patches going to be accepted into either upstream or Debian (or both)?
No, they are simply not needed for the raspberry pi.oneingray wrote:I'm curious, are there any specific issues with the Debian patches?
I don't know, I'm sorry.oneingray wrote:Conversely, are the Raspberry Pi patches going to be accepted into either upstream or Debian (or both)?
