herbthom
Minimum gpu_mem setting for F18
Fri Mar 22, 2013 3:37 am
In case it saves someone else some time, by experiment I've found that the minimum bootable /boot/config.txt gpu_mem setting for F18 on my 256MB Pi is 24:
# /boot/config.txt
gpu_mem=24
This gives:
$ cat /proc/meminfo
MemTotal:         227432 kB
jojopi
Re: Minimum gpu_mem setting for F18
Fri Mar 22, 2013 2:54 pm
This is because Seneca have omitted the cutdown firmware files start_cd.elf and fixup_cd.dat. If you download those yourself you can boot with gpu_mem=16 like on any normal distro.
https://github.com/raspberrypi/firmware ... aster/boot
herbthom
Fri Mar 22, 2013 11:02 pm
jojopi wrote:This is because Seneca have omitted the cutdown firmware files start_cd.elf and fixup_cd.dat. If you download those yourself you can boot with gpu_mem=16 like on any normal distro.
Thanks for the tip.
The following worked for me:
cd /boot
su
wget https://github.com/raspberrypi/firmware/raw/master/boot/bootcode.bin
wget https://github.com/raspberrypi/firmware/raw/master/boot/fixup.dat
wget https://github.com/raspberrypi/firmware/raw/master/boot/fixup_cd.dat
wget https://github.com/raspberrypi/firmware/raw/master/boot/start.elf
wget https://github.com/raspberrypi/firmware/raw/master/boot/start_cd.elf
Return to “Pidora / Fedora”
