kobazik
Pidora 2014 gpu mem
Sat Jul 05, 2014 8:19 pm
I've installed Pidora 2014 on my Raspberry Pi B with 512MB and after boot it only shows 372MB available ram. I've set gpu_mem to 16 but it doesn't make any difference.
[root@rpi ~]# free -m
total used free shared buffers cached
Mem: 372 80 291 0 9 43
-/+ buffers/cache: 28 343
Swap: 511 0 511
My /boot/config.txt looks like that:
dtv_mode=0
sdtv_aspect=1
overscan_left=15
overscan_right=15
overscan_top=15
overscan_bottom=15
hdmi_drive=1
start_file=start_x.elf
fixup_file=fixup_x.elf
gpu_mem=16
arm_freq=1000
core_freq=500
sdram_frewq=500
over_voltage=6
Also I've noticed it a bit slower than when I was running raspbian :(
ShiftPlusOne
Re: Pidora 2014 gpu mem
Sat Jul 05, 2014 9:01 pm
Does 32 work?
kobazik
Sun Jul 06, 2014 10:41 am
No, gpu_mem=32 doesn't work it still shows 372MB available after reboot
ShiftPlusOne
Sun Jul 06, 2014 10:51 am
I would take a look at the output of vcgencmd get_config to check that the firmware is reading the options correctly, at least. Then if 'vcgencmd get_mem gpu ' conflicts with that... that would be strange.
kobazik
Sun Jul 06, 2014 11:31 am
Hmm that is strange
[root@rpi ~]# vcgencmd get_mem gpu
gpu=128M
[root@rpi ~]# grep gpu /boot/config.txt
gpu_mem=16
ShiftPlusOne
Sun Jul 06, 2014 11:40 am
and vcgencmd get_config gpu_mem?
kobazik
Sun Jul 06, 2014 11:47 am
[root@rpi ~]# vcgencmd get_config gpu_mem
gpu_mem is unknown
ShiftPlusOne
Sun Jul 06, 2014 11:52 am
:? Don't have my pi to check if that should work, but that seems strange.
kobazik
Sun Jul 06, 2014 11:57 am
My overclocking settings are there but gpu_mem is not.
[root@rpi ~]# vcgencmd get_config int
arm_freq=1000
core_freq=500
over_voltage=6
sdtv_aspect=1
hdmi_drive=1
overscan_left=15
overscan_right=15
overscan_top=15
overscan_bottom=15
program_serial_random=1
config_hdmi_boost=2
emmc_pll_core=1
hdmi_force_cec_address=65535
temp_limit=85
force_pwm_open=1
pause_burst_frames=1
avoid_fix_ts=1
ShiftPlusOne
Sun Jul 06, 2014 12:09 pm
What if you remove this part?
kobazik
Sun Jul 06, 2014 12:24 pm
Removing those files did that job ! :) Thanks !
Mem: 483 87 395 0 9 48
-/+ buffers/cache: 29 454
Swap: 511 0 511
gpu_mem is unknown
ShiftPlusOne
Sun Jul 06, 2014 12:30 pm
start_x.elf is used for the camera and some other additional 'media stuff' which requires more RAM, so I figured it might be forcing a minimum requirement.
kobazik
It could be related to this as well
http://www.raspberrypi.org/forums/viewt ... 51&t=37962
Return to “Pidora / Fedora”
