jtlns
Help with setting static IP address with June/2013 image
Fri Jun 14, 2013 11:59 am
Hi everybody,
I'm trying to give my Raspberry Pi (running the Arch image of June, 6th, 2013) a fixed IP address. I tried to look for tutorials in these forums and on the internet but all of them refer to files/commands that don't exist on my image. (I found some message mentioning since May 2013 things changed)
So, can anybody provide the steps (or some tips) to give my Pi a static IP address?
Many thanks!
Jan
redhawk
Re: Help with setting static IP address with June/2013 image
Fri Jun 14, 2013 12:03 pm
Wifi or Ethernet??
Richard S.
jtlns
Fri Jun 14, 2013 12:07 pm
redhawk wrote:Wifi or Ethernet??
I'm sorry, forgot to mention. Ethernet in my case. (dhcp is working fine)
sdjf
Fri Jun 14, 2013 4:35 pm
It should just work out of the box if you have a router. Are you wanting to assign the IP manually?
I haven't memorized the steps and locations, but you should be able to copy an example from /etc/netctl/examples to /etc/netctl/MYETHERNET and change the IPs listed manually. For static, I think the example file is /etc/netctl/examples/ethernet-static
Did my ethernet page turn up? Details there which should also fit the June image, although only last tested on May image but I believe the changes mentioned to /bin, /sbin, etc. should not affect netctl, just location of apps and commands that are not in the /etc directory.
http://sdjf.esmartdesign.com/raspberrypi/ethernet.html
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
pepedog
Fri Jun 14, 2013 5:27 pm
Copy /etc/netctl/examples/ethernet-static to /etc/netctl/ethernet-static
Edit it
Delete /etc/netctl/ethernet-dhcp
systemctl reenable netctl-ifplugd@eth0
DrMag
Sat Jun 15, 2013 3:05 am
The other option is to configure your router to issue the static IP. This way has an advantage that if you're disconnected for a long period of time and using other machines, the router won't reissue your IP to a different machine potentially causing an address conflict. If the router is configured to issue a static IP, dhcp will work as usual, but always pull up that address.
MrSamNC
Sat Jun 22, 2013 12:58 pm
DrMag wrote:The other option is to configure your router to issue the static IP. This way has an advantage that if you're disconnected for a long period of time and using other machines, the router won't reissue your IP to a different machine potentially causing an address conflict. If the router is configured to issue a static IP, dhcp will work as usual, but always pull up that address.
1+ this was very easy to setup on my end. Thanks DrMag!
shreyas_patel21
Sun Jul 28, 2013 2:17 pm
From the command prompt, type:
sudo bash and press enter
nano /etc/network/interfaces and press enter
Change the following entry from:
iface eth0 inet dhcp
Change it to:
iface eth0 inet static
address 192.168.0.2
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
Press CTRL and O at the same time to save
Press CTRL and X together to exit
Reboot
spartacus
Sun Jul 28, 2013 4:45 pm
shreyas_patel21 wrote:From the command prompt, type:
/etc/network/ doesn't exist. the network config is in /etc/netctl/
Return to “Arch”
