haroldjclements
You must have correct permissions to upgrade the database
Sun Jan 25, 2015 4:41 pm
Hello forum,
I have just installed Arch Linux (only default root user has been created). I did a full system update (pacman -Syu). When I attempt the install new packages, I get :
error: try running pacman-db-upgrade
If I run pacman-db-upgrade I get:
==> ERROR: You must have correct permissions to upgrade the database.
I am root user, so I am complete perplexed. Any help will be gratefully received.
Thanking you,
Harold Clements
haroldjclements
Re: You must have correct permissions to upgrade the databas
Sun Jan 25, 2015 5:09 pm
I think I know what the problem is, I just don't know how to fix it. My who OS is in read-only mode since I did the latest upgrade.
Any thoughts?
pepedog
Mon Jan 26, 2015 12:19 pm
Edit cmdline.txt, put rw just before rootwait
coproc
Tue Jan 27, 2015 12:54 am
Thank you! This was extremely useful to me
(albeit a bit late, I just got my RPi running Arch within the last week.)
pepedog
Tue Jan 27, 2015 2:02 pm
Every other arm system I have worked on has had to have rw in the kernel boot args (unless they had an initrd), not needed on rpi on old kernel
jtlns
Mon Feb 09, 2015 6:38 pm
Thanks for the "rw" tip! I had a Raspberry Pi running Arch for 1+ year, after "pacman -Suy" the file system was in read only mode, but the "rw" fixed it.
Now, the $1M question is: why did this happen? Was this expected? Will this happen in the future again, when I do "pacman -Suy"?
Jan
pepedog
Mon Feb 09, 2015 8:35 pm
I have no idea, but it is the kernel that caused it.
Going back to basics, you should always investigate a pacnew file, see what is new.
A tool provided with pacman
DIFFPROG=nano pacdiff
joeschmo
Mon Apr 27, 2015 2:46 pm
pepedog wrote:Edit cmdline.txt, put rw just before rootwait
Worked for me, but my cmdline.txt was setup a little different just to clarify you have to add rw after root=/dev/xxxxx
cat /boot/cmdline.txt
ipv6.disable=1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rw rootfstype=ext4 elevator=noop rootwait
Return to “Arch”
