haaldemir
Re: Updated 64-bit Gentoo Image for RPi3 Released (now also for RPi3B+ and RPi4B)
Wed Dec 11, 2019 9:21 am
Hi Sakai
you mean this?
pi@raspberrypi:~ $ sudo su
root@raspberrypi:/home/pi# # md5sum /lib/firmware.bad/brcm/brcmfmac434*
root@raspberrypi:/home/pi# md5sum /lib/firmware.bad/brcm/brcmfmac434*
8c97a1fb04a8c2c0ca0a8ed0814f38ae /lib/firmware.bad/brcm/brcmfmac43430a0-sdio.bin
864a714701fc0581f43e5afe155938be /lib/firmware.bad/brcm/brcmfmac43430a0-sdio.jumper-ezpad-mini3.txt
74e00528d84534ba68fe92c512d11de5 /lib/firmware.bad/brcm/brcmfmac43430a0-sdio.ONDA-V80 PLUS.txt
56bd4e83a74244068c07f4045450eff6 /lib/firmware.bad/brcm/brcmfmac43430-sdio.AP6212.txt
ba679a85c1dc76e9775603af45440bc0 /lib/firmware.bad/brcm/brcmfmac43430-sdio.bin
fdc506b375fd121d595da9fdacb25d55 /lib/firmware.bad/brcm/brcmfmac43430-sdio.Hampoo-D2D3_Vi8A1.txt
2f038b3611fe82414318bc8ed98a535c /lib/firmware.bad/brcm/brcmfmac43430-sdio.MUR1DX.txt
f823f96f057b31558e70425830858723 /lib/firmware.bad/brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt
f823f96f057b31558e70425830858723 /lib/firmware.bad/brcm/brcmfmac43430-sdio.raspberrypi-rpi.txt
dede46f30e4ceac2823a59b7f6ebbc34 /lib/firmware.bad/brcm/brcmfmac43430-sdio.txt
0324fe9ce34b6c6c44cc5fd77a669d39 /lib/firmware.bad/brcm/brcmfmac43455-sdio.bin
c5aeca0e33de4ae870986c517963fef7 /lib/firmware.bad/brcm/brcmfmac43455-sdio.clm_blob
33ad683f22dc4bd4b398629821d7a3de /lib/firmware.bad/brcm/brcmfmac43455-sdio.MINIX-NEO Z83-4.txt
62d3e3bad57b074d6853f02270a8610e /lib/firmware.bad/brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt
7b983812a8aee7bf701460436c686226 /lib/firmware.bad/brcm/brcmfmac43455-sdio.txt
root@raspberrypi:/home/pi# md5sum /lib/firmware/brcm/brcmfmac434*
8c97a1fb04a8c2c0ca0a8ed0814f38ae /lib/firmware/brcm/brcmfmac43430a0-sdio.bin
ba679a85c1dc76e9775603af45440bc0 /lib/firmware/brcm/brcmfmac43430-sdio.bin
dede46f30e4ceac2823a59b7f6ebbc34 /lib/firmware/brcm/brcmfmac43430-sdio.txt
963eb0d4903040974ee88b4f85cb1f4f /lib/firmware/brcm/brcmfmac43455-sdio.bin
c5aeca0e33de4ae870986c517963fef7 /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob
7b983812a8aee7bf701460436c686226 /lib/firmware/brcm/brcmfmac43455-sdio.txt
regards
sakaki
Wed Dec 11, 2019 3:17 pm
OK, interesting. So, most of the key files match under the MD5 digest. However, the uploadable firmware file brcmfmac43455-sdio.bin does not.
On the (working) Raspbian image, this appears to have md5sum 963eb0d4903040974ee88b4f85cb1f4f.
Whereas on the Gentoo image it has md5sum 0324fe9ce34b6c6c44cc5fd77a669d39
According to the official linux/firmware git tree, this file hasn't been changed since 2015 (and also has md5sum 0324fe9ce34b6c6c44cc5fd77a669d39, as per Gentoo).
But the Raspbian firmware repo does indeed have a variant copy of this firmware file, which is interesting and could well explain the WiFi issue.
I'm not quite sure where this version of the file has come from originally. Perhaps one of the RPT engineers could jump in with further colour here?
Anyway, what would be useful next would be to try this modified firmware file on your Gentoo system, to see if that improves things.
To do so, boot up your Gentoo system, and issue (as root):
pi64 ~ # mv -v /lib/firmware/brcm/brcmfmac43455-sdio.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin.orig
pi64 ~ # wget https://github.com/RPi-Distro/firmware-nonfree/raw/master/brcm/brcmfmac43455-sdio.bin -O /lib/firmware/brcm/brcmfmac43455-sdio.bin
pi64 ~ # sync
Reboot once the above steps have been completed. Once rebooted, test WiFi again.
Does this improve things (under Gentoo)?
thanks, sakaki
haaldemir
Wed Dec 11, 2019 4:28 pm
Hi Sakaki,
Yes i added codes on Gentoo and yes good news wifi working now.
many Thanks
sakaki
Wed Dec 11, 2019 4:49 pm
Great to hear, I will add this change to the overlay shortly, so others can benefit from it.
many thanks for taking the time to report this and follow it up,
sakaki
sakaki
Sat Dec 14, 2019 5:56 pm
All,
Updated CYW43455 Firmware
it has come to my attention that some of the uploadable firmware for the CYW43455 WiFi/BT chip (RPi3B+/RPi4B) shipped on the current Gentoo image is not the same as that provided by the Raspbian distribution. This appears to cause sub-optimal WiFi performance in some situations, particularly on the RPi4.
I have addressed this by adding Raspbian's version of the affected firmware file [1] to the sys-firmware/brcm43430-firmware package, controlled by the 43455-fix USE flag, removing it from sys-kernel/linux-firmware, basis the same USE flag, and adding the 43455-fix USE flag to the default profile.
So, to get the updated firmware, issue:
demouser@pi64 ~ $ sudo emaint sync --repo genpi64
demouser@pi64 ~ $ sudo emerge -v1u sys-firmware/brcm43430-firmware
Reboot once done to start using the updated driver.
Thanks to haaldemir for reporting the issue, and for persisting through the follow up! [2]
64-bit Userland MMAL Support Merged Upstream
In other news, as 6by9's pointer-wrangling PR#586 [3] has now been tidied up and merged into raspberrypi-userland upstream, I have bumped the corresponding ebuild accordingly (removing the temporary patch for this PR).
To get the new version, issue:
demouser@pi64 ~ $ sudo emerge -v1u media-libs/raspberrypi-userland
Again, reboot once done to start using this.
best, sakaki
[1] /lib/firmware/brcm/brcmfmac43455-sdio.bin
[2] https://www.raspberrypi.org/forums/view ... 5#p1576715 ff
[3] https://github.com/raspberrypi/userland/pull/586
haaldemir
Sat Dec 14, 2019 6:37 pm
All,
best, sakaki
Hi Sakaki
Thanks to you too. now wireless working very well. İ should done above parts only second part? right? or both?
Regards
sakaki
Sat Dec 14, 2019 6:44 pm
You should do both (the first will make the same fix you applied locally, but the driver will now be supplied from the genpi64 repository).
Best, sakaki
cjan
Sun Dec 15, 2019 10:35 pm
gentoo, wonder which way setup swap file by default for PI-1G models?
sakaki
Mon Dec 16, 2019 4:42 pm
The image currently uses a 1GiB swapfile (subject to sufficient space on the drive) by default, and uses zswap. This is the case regardless of RAM size.
hth, sakaki
sakaki
Fri Dec 27, 2019 10:40 pm
I've just posted a v1.5.3 bugfix release of my bootable 64-bit Gentoo image for the RPi4 B / RPi3 B & B+ on GitHub (here, includes full download instructions).
For screenshots, and details of the major changes introduced in 1.5.2, please see my earlier post.
A changelog from the prior release image (with upgrade instructions) may be viewed here, but in summary:
  • Updated the uploadable firmware file /lib/firmware/brcmfmac43455-sdio.bin (for the RPi3B+/4B's CYW43455 WiFi/BT chip) to match that provided by the Raspbian distribution (by adding their newer version of this file to the sys-firmware/brcm43430-firmware package, controlled by the 43455-fix USE flag, removing it from sys-kernel/linux-firmware, basis the same USE flag, and adding the 43455-fix USE flag to the default profile). This change will (hopefully) improve WiFi performance / stability meaningfully, particularly on the RPi4B (where, for some APs, the older driver was preventing association entirely). Thanks to haaldemir for reporting.
  • Bumped media-libs/raspberrypi-userland, as 6by9's pointer-wrangling PR#586 (64-bit userland MMAL) has now been tidied up and merged into raspberrypi-userland upstream.
  • Upgraded the shipped kernels, to bcm{rpi3,2711}-kernel-bis-bin-4.19.89.20191217.
  • Various minor ebuild tidy-ups.
  • All packages brought up-to-date against the Gentoo tree, as of 14 December 2019 (so e.g., sys-devel/clang is now at 9.0.1_rc2).
Users on the prior 1.5.2 release can simply run "sudo genup" in a terminal to upgrade to 1.5.3 (or wait for the weekly autoupdate to do it on your behalf), rebooting once complete. Manual upgrade instructions for users on older versions of the image are also provided, here.
Have fun ^-^
And, as always, any problems or comments, please post either in this thread, or in the project's (sticky) thread on the Gentoo forums (here).
sakaki
PS the bootable images are also available for download via PINN, for those who prefer that route, called gentoo64 and gentoo64lite there.
SummerRainbowz
Sun Dec 29, 2019 10:19 pm
Does anyone have a binary version of chromium with h264 enabled? This image would be perfect for me if it weren't for the lack of h264, since lots of sites that I visit serve videos in this codec, so I have to use another browser to view them which is inconvenient.
I'd compile it myself, but unfortunately at the moment I don't have a spare PC install Gentoo on in order to compile a modified version.
Thanks for taking the time to read this, happy holidays!
Gavinmc42
Mon Dec 30, 2019 10:43 am
Been using 1.5.3 Desktop and Lite with x11/Openbox for a few days, no bugs noticeable yet.
Re h.264, this one worked in Aurora
http://www.html5videoplayer.net/html5vi ... ideo-test/
But did not seem to work in Chromium.
Aurora played all these except for the MPEG4 video
http://demo.nimius.net/video_test/
Chromium did not play the h.264 but did play the audio on the MPEG4.
Is there plug-ins that can fix this?
Or is it still work in progress?
Browsers are the biggest pieces of software that run on Pi's.
There are other ways to run videos, some download and use the players.
But try Aurora and see if it works for you.
I'm dancing on Rainbows.
SummerRainbowz
Mon Dec 30, 2019 11:34 am
Indeed, h264 does work on Aurora, but I prefer to use chromium (having everything synced between my devices & Google Account is one of the big draws for me).
So, switching to it just to watch videos is inconvenient, that's why I was looking for a solution for chromium.
Gavinmc42
Mon Dec 30, 2019 11:47 am
Have you tried the Chromium in Raspbian Buster?
Sometimes it can be ahead. OS leapfrog.
If it works in Buster chances are it will get working in Gentoo64 if Sakaki knows about it.
BRX7
Mon Dec 30, 2019 9:57 pm
Hi Sakaki , Happy New Year,
A few questions Ive re installed clean 1.5.3 ,
Is the userland already preinstalled? Becuase i try to ermege and it cant find it.
Secondly I want to compile and install amiberry Amiga emulator with dispmanx via
https://github.com/midwan/amiberry/wiki ... y-Pi-64bit
I cannot unmask sdl2-ttf can you help me on this please? Its saying unknown keywords when I add a umask portage file
Gavinmc42
Tue Dec 31, 2019 3:41 am
Autounmask has been turned off, so I add it to the emerge command line.
I think it might be a dependency for some sdl2 stuff as my Gentoo64 shows it installed.
Do this from root
"emerge -a --autounmask media-libs/sdl2-ttf"
DarkPlatinum
Contact: YouTube
Tue Dec 31, 2019 5:07 pm
Hi! I recently installed gentoo but have had some internet problems. The funny thing is I can connect to my router but can't ping the router or ping the pi. The router says it is connected but when trying out some web browsing on the pi or pinging google.com it doesn't seem to work. I know it is not a router problem due to the fact I have many other devices which are working alright. On top of this, for some reason gentoo is not allowing me to connect to the 5G network. Whenever I try connect, it shows the connecting symbol forever. Do you know how I can fix this?
DarkPlatinum
Contact: YouTube
Wed Jan 01, 2020 5:00 pm
Hmm.. it seems I did not have the latest of version of gentoo. I saw that some other people had the same problems on the Pi 4 before you updated it. I am testing it our right now and hopefully all goes well.
sakaki
Thu Jan 02, 2020 2:57 pm
Unfortunately, I can't ship the openh264 codec package with Chromium due to licensing restrictions (despite the name!). You can build it locally yourself (by turning on the openh264 USE flag on www-client/chromium) if desired.
best, sakaki
sakaki
Thu Jan 02, 2020 3:00 pm
Yes, there were issues with WiFi on the RPi4 with versions of the image <= v1.5.2 for some APs, due to the use of an older uploadable driver file (/lib/firmware/brcmfmac43455-sdio.bin) from linux-firmware (compared with the Raspbian version).
This is (hopefully ^-^) fixed in v1.5.3; please see the release notes here.
best, sakaki
sakaki
Thu Jan 02, 2020 3:17 pm
If you mean raspberrypi-userland, then yes a recent version of this (with e.g. 64-bit MMAL support included) is bundled with the image (both full and lite variants).
As to sdl2-ttf, as Gavinmc42 notes the default behaviour of emerge has now changed, such that packages not explicitly "keyworded" (marked as having been tested by a Gentoo dev for your target architecture) now fail to emerge (it used to be that emerge would allow you to autounmask them, but as this led to people trying (often) to build -9999, aka 'live tree', variants, leading to nasty dependency tangles (where these had -9999 deps, for example, which then cascaded in a horrible transitive closure) this feature was recently withdrawn).
The easiest thing nowadays is to create a package keyword callout for this, which says to Portage in effect "allow versions of this package marked as stable or testing for any architecture, but do not use -9999 versions). To do this, as root issue:
pi64 ~ # echo "media-libs/sdl2-ttf * ~*" >> /etc/portage/package.accept_keywords/sdl2-ttf
You should then be able to emerge this package as normal.
hth, sakaki
sakaki
Thu Jan 02, 2020 10:33 pm
Although the gentoo-on-rpi-64bit image now supports access to the RPi's built-in h/w video codecs via both V4L2-M2M and MMAL endpoints (and ships with a custom version of ffmpeg that can utilise both), neither firefox nor chromium currently exploit these out of the box (see e.g. this post and this thread), although I think Raspbian's 32-bit custom Chromium build can use MMAL codecs, so it may be possible to adopt some of their patches (not something I've looked at yet). PRs on this topic welcome!
However, one way you can stream high-res YouTube videos is by using Applications -> Multimedia -> SMPlayer, as this does have the necessary acceleration enabled. In this app, you can specify the default quality you want via Options -> Preferences, Network (left tab), and open streams via Open -> URL... (just paste in the youtube URL you want to watch).
On my RPi4B (4GB), with a fast IP connection, this plays back 1080p videos smoothly; for instance:
If you like this route, you can also install media-video/smtube as a front end:
demouser@pi64 ~ $ sudo emerge -v media-video/smtube
Once built, this YouTube browser front-end can be launched by pressing F11 from within SMPlayer.
hth, sakaki
idpitt
Sat Jan 04, 2020 2:32 pm
Great work on the Gentoo image!
In keeping with earlier releases of Raspian, I'm struggling with dpms on my monitor. I've got hdmi_blanking=1 in the config file, dpms is enabled according to xset and I've got the appropriate settings in ~/.xscreensaver. When the screensaver kicks in ( or I run xset dpms force off ), the monitor blanks but the backlight stays on. Before I switched from Raspian to Gentoo, the backlight would go off.
Am I missing a setting or did this addition to Raspian not make it into the Gentoo build?
Ian
sakaki
Tue Jan 07, 2020 9:00 pm
Hi Ian -
the issue may lie with the following autostart entry?
https://github.com/sakaki-/genpi64-over ... -r3.ebuild
hth, sakaki
idpitt
Sun Jan 12, 2020 11:33 am
I removed that autostart and also unmerged the package too. There's no difference. Doing an xset dpms force off only blanks the screen too ( regardless of the setting of hdmi_blanking in /boot/config.txt ). I'll boot a raspian image today and see if there's something off with the firmware.
UPDATE: With a clean image of Raspian ( 32 bit ) and an apt update, I get the same behavior as Gentoo - display blanks but light stays on. With an rpi-update run and corresponding kernel bump , xset dpms force off works correctly in that the screen blanks and backlight goes off ( and monitor announces 'no signal' just before the backlight goes off ).
I pulled a clean gen64 image and flashed that to remove any thing I had done to the install - same as before: no backlight control either before or after disabling the autostart script that Sakaki references above. If anyone has this working on their gentoo install, pls let me have the settings.
Ian
Return to “Gentoo”
