kulrich
PILFS : Error during gcc compilation
Wed Mar 16, 2016 1:07 pm
I'm into building PiLFS for the raspberrypi 2 with
Raspbian Jessie Lite
Version: February 2016
Release date: 2016-02-26
Kernel version: 4.1
lfs@raspberrypi:/mnt/lfs/sources$ uname -m
armv7l
I failed during the ch5-build.sh execution.
The error happend by the compilation of gcc by executing ch5-build.sh.
tmp-divrem_1.s: Assembler messages:
tmp-divrem_1.s:129: Error: selected processor does not support ARM mode `mls r1,r4,r8,r11'
tmp-divrem_1.s:145: Error: selected processor does not support ARM mode `mls r1,r4,r8,r11'
tmp-divrem_1.s:158: Error: selected processor does not support ARM mode `mls r1,r4,r8,r11'
tmp-divrem_1.s:175: Error: selected processor does not support ARM mode `mls r1,r4,r3,r8'
tmp-divrem_1.s:209: Error: selected processor does not support ARM mode `mls r11,r4,r12,r3'
Makefile:768: recipe for target 'divrem_1.lo' failed
make[4]: *** [divrem_1.lo] Error 1
make[4]: Leaving directory '/mnt/lfs/sources/gcc-5.3.0/build/gmp/mpn'
Makefile:954: recipe for target 'all-recursive' failed
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory '/mnt/lfs/sources/gcc-5.3.0/build/gmp'
Makefile:773: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/mnt/lfs/sources/gcc-5.3.0/build/gmp'
Makefile:4547: recipe for target 'all-gmp' failed
make[1]: *** [all-gmp] Error 2
make[1]: Leaving directory '/mnt/lfs/sources/gcc-5.3.0/build'
Makefile:858: recipe for target 'all' failed
make: *** [all] Error 2
Any Ideas? If you need more Information. Just give me a call.
Kind regardes.
Kai
Bingo600
Re: PILFS : Error during gcc compilation
Wed Mar 23, 2016 7:47 am
I'm having the same issue , building gmp-6.1.0 on the new Raspi3
builddir/src/gmp-6.1.0 -DOPERATION_divrem -fPIC -c divrem.c -o divrem.o
libtool: compile:  gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0/mpn -I.. -D__GMP_WITHIN_GMP -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0 -DOPERATION_divrem_2 -fPIC -c divrem_2.c -o divrem_2.o
libtool: compile:  /home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0/mpn/m4-ccas --m4=m4 gcc -std=gnu99 -c -DHAVE_CONFIG_H -I. -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0/mpn -I.. -D__GMP_WITHIN_GMP -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0 -DOPERATION_divrem_1 -fPIC -Wa,--noexecstack divrem_1.asm -o divrem_1.o
m4  -DHAVE_CONFIG_H -D__GMP_WITHIN_GMP -DOPERATION_divrem_1 divrem_1.asm >tmp-divrem_1.s
 gcc -std=gnu99 -c -DHAVE_CONFIG_H -I. -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0/mpn -I.. -D__GMP_WITHIN_GMP -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0 -DOPERATION_divrem_1 -fPIC -Wa,--noexecstack tmp-divrem_1.s -o divrem_1.o
make[2]: *** [divrem_1.lo] Error 1
make[2]: *** Waiting for unfinished jobs....
libtool: compile:  gcc -std=gnu99 -DHAVE_CONFIG_H -I. -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0/mpn -I.. -D__GMP_WITHIN_GMP -I/home/bingo/Atmel-3.5.1/builddir/src/gmp-6.1.0 -DOPERATION_fib2_ui -fPIC -c fib2_ui.c -o fib2_ui.o
make[2]: Leaving directory '/home/bingo/Atmel-3.5.1/builddir/build/gmp/mpn'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/bingo/Atmel-3.5.1/builddir/build/gmp'
Raspbian jesse fully updated:
uname -a
Linux raspi-4 4.1.18-v7+ #846 SMP Thu Feb 25 14:22:53 GMT 2016 armv7l GNU/Linux
GCC
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.9/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Raspbian 4.9.2-10' --with-bugurl=file:///usr/share/doc/gcc-4.9/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.9 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.9 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.9-armhf/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.9-armhf --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.9-armhf --with-arch-directory=arm --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 4.9.2 (Raspbian 4.9.2-10)
I have build avr-gcc before (in november i think) , but it was on an old Raspi (512k single core) Raspbian wheezy
/Bingo
Bingo600
Wed Mar 23, 2016 9:42 am
Update
GMP is building ok on an old Raspi (512K)
This might be a configure issue.
I tried to get gmp-6.1.0 on the Raspi3 , and build it.
just a ./configure && make
But my Raspi3 stopped responding (crashed) during build , and it's 140km away :(
/Bingo
Thantelius
Sat Feb 18, 2017 6:41 am
Hi!
Have you ever solved this?
I'm having the same issue but there's no info about it.
Regards
Return to “Other”
