REMOVED!
REMOVED!
Last edited by SPS TradeMark on Thu Feb 22, 2018 8:08 pm, edited 2 times in total.
Re: Cross Compile High detail guide
Seems maybe useful for Windows users that are switching over to the RPi?
Though why not just compile under Raspbian?
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers.
The compilation this way seemed really fast, while if you compile it on the raspberry pi i read that it could take about 12h 30 min
It can, depending on options, and compiler. Though I doubt it would take anywhere near that long on a Raspberry Pi 3B, with everything running in RAM for the compile (as in NOT having to access the mass storage device [SD-Card/USB HDD/USB Flash/etc]), I do not think it would take more than an hour if the RPi is correctly set up for the compile (on an RPi 3B).SPS TradeMark wrote:The compilation this way seemed really fast, while if you compile it on the raspberry pi i read that it could take about 12h 30 min
Remember that in most cases a larg part of the compile time is writing and reading files, so working from RAM greatly speeds things up.
Just setup a RAM disk and give it a try, if it is fast enough for you it may be an option, if not use your old no longer needed PC.
Thank you so muccchhh!!
I have been struggling a lot before i found your tutorial...!
Nice job...!
Nice job...!
