paulwratt
PipaOS 5.0 with Chrome & GCC 6.1.0
Sat Jun 03, 2017 12:46 am
PipaOS is Raspbian based, boots in 3 seconds
http://pipaos.mitako.eu/
http://pipaos.mitako.eu/download/pipaos ... 5.0.img.gz
305Mb, expanded image is 2.8Gb with 1.2Gb free
PipaOS 5.0 is Raspbian Jessie with X Windows, running Openbox (right
click for apps and shells/terminals). It is a console OS, I just tacked
on some frills.
this image has the following installed:
gpm - general purpose mouse (on console), use middle-click to copy, use
right-click to paste
fte - a DOS EDIT work-a-like console editor
gcc-6.1.0 - in "/usr/local/gcc-6.1.0/bin" (see "/etc/profile")
chromium-browser - "~/bin/chrome" runs on VT6 from a console or an X
windows terminal (X is now on VT1, not VT7 - use CTRL+ALT+F1 .. F6 to
switch VT)
PepperFlash - Flash for Chromium Browser
not ( SDL - version 1.2.15 from DietPi ) this is self build version
mount-manager2 - a custom usb mount script for UDEV (no extra overhead)
wpa_supplicant.conf - working (roaming) wifi, add your own in order of
preference, "sudo ifconfig wlan0 down && sudo ifconfig wlan0 up" will
connect to strongest signal starting from top of conf file.
some other things I can't remember like "sqlite commanline tools", 7zip
this image does not have installed:
a graphical file manager (use "mc" in console or terminal)
a desktop (like LXDE,KDE, Mate or Cinnamon)
SDL2
The complete SDL 1.2 -dev install will add a further 65Mb after
https://mega.nz/#!tQND2ZJJ!BWk3axXrPVH9 ... ZykCIv2hwc
882Mb, expanded image is 2.8Gb with 868Gb free
enjoy 3 second boot times and (almost) instant shutdown
Cheers
Paul
paulwratt
Re: PipaOS 5.0 with Chrome & GCC 6.1.0
Tue Jun 06, 2017 7:46 am
updated Mega.NZ url, sorry, forgot the key, should be fine now
paulwratt
Fri Jun 30, 2017 8:18 am
I have an updated udev mount manager that should work with any fuse driver (ntfs-3g auto-mounts as fuseblk)
either modify "/etc/udev/rules.d/99-mount_manager.rules" or "/sbin/mount_manager/mount_manager_v2"
"mount_manager_v2" comes fro the following url, and will probably be updated with my fixes sometime after this post:
http://solvedforhome.com/?p=2806&v=3a52f3c22ed6
Cheers
Paul
mount_manager_v3.gz
(1.56 KiB) Downloaded 111 times
Return to “Other”
