kik1972
Mounting SD card reader (ubuntu mate)
Fri Dec 14, 2018 8:17 pm
I had unbuntu mate running on my raspbery pi 3. I ran into an issue with trying to get it to auto login. As a result I can’t log in anymore.
I created a new SDK card that is running. I would like to get a file off of the old SD card running the ubuntu mate I can no longer log into.
I got a SD card read and connected it to my raspberry pi via USB. I want to mount it and get my file off.
I have run fdisk -l
I do not see it in the results.
Any ideas as to what I might try?
DirkS
Re: Mounting SD card reader (ubuntu mate)
Fri Dec 14, 2018 9:11 pm
Run
lsblk
to see all connected block devices (drives)
Your card will probably show up as /dev/sda, so you may need to mount /dev/sda2
kik1972
Mon Dec 17, 2018 2:34 pm
Thank you for the reply.
Unfortunately I don't see that:
pi@raspberrypi:~ $ lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0     179:0    0 29.8G  0 disk
|-mmcblk0p1 179:1    0  1.4G  0 part
|-mmcblk0p2 179:2    0    1K  0 part
|-mmcblk0p5 179:5    0   32M  0 part /media/pi/SETTINGS
|-mmcblk0p6 179:6    0   69M  0 part /boot
`-mmcblk0p7 179:7    0 28.4G  0 part /
DirkS
Mon Dec 17, 2018 2:38 pm
Is your SD card reader recognised?
Check with
lsusb
And / or boot with the reader disconnected. After booting plug it in (with the SD card in it) and then check the log with
dmesg
If it works then you should see the messages that the USB device is recognised, etc
TxRider
Fri Dec 21, 2018 7:31 am
I was able to mount my SD card with no problem BUT after I re-boot, and then click on my SD card which in this case is labeled (VIDEO), it pops up as (VIDEO1) but writes my data to (VIDEO) ?...any thoughts?
See Pic:
https://www.dropbox.com/s/e53v6djpt43n9 ... s.jpg?dl=0
Return to “Other”
