sorinm
ArmedSlack 13.37
Sat May 19, 2012 7:43 am
The rootfs is about ~ 1.2 GB.
- It boots incredibly quick (thanks to the latest firmware)
- Rock solid
- Default window manager is Xfce4 but Fluxbox is also included
- Xfce has a greater load time than Lxde but once started it`s as fast as Lxde.. maybe faster
- Mozilla Firefox 3.6.28 is the default browser. It needs a few seconds to load but once started it loads and renders pages faster than Midori.
- SSH is enabled by default
- It uses the 192 MB start.elf
- User "root" password "raspberry"
- Based on ArmedSlack 13.37 + latest patches
- slackpkg tool included
http://ns1.spit-ct.ro/raspberrypi/
I`ll need some mirrors, please help out :)
trn
Re: ArmedSlack 13.37
Sat May 19, 2012 8:53 am
mysql server work?
play divx movie work?
sorinm
Sat May 19, 2012 9:10 am
MySql works, I didn`t tested multimedia capabilities.
I`ll test that. Slackware has xine, xmms and audacious packages for multimedia playback.
To install them use slackpkg install xine* xmms audacious*
Remember to load the audio module first.
P.S. I forgot Mplayer
nick.mccloud
Sat May 19, 2012 9:20 am
Pico/RP2040 ≠ Arduino
Pico = hot rod kit car, Arduino = hot rod kit car wrapped in cotton wool with buoyancy aids & parachute
sorinm
Sat May 19, 2012 9:25 am
Seeding
John_McC
Sat May 19, 2012 10:24 am
Firstly thanks for the hard work and please excuse my lack of knowledge :oops: but when I run up your image on the pi it say its unable to connect to the site to update try again or continue ? if I continue it all loads ok but if I open the browser it seems unable to connect to any internet sites (can not connect to server) I know the connection is working as is the pi as other images are working. what am I doing wrong please help.
Cheers John
geep999
Sat May 19, 2012 10:37 am
Please post the .md5 - my download is:
f1b521ebc736b17933fdf19b5acb8ad9 ArmedSlack-13.37-18.05.2012.zip
Cheers,
Peter
sorinm
Sat May 19, 2012 12:01 pm
geep999 wrote:Please post the .md5 - my download is:
Cheers,
Peter
When you uncompress the archive you have the sha1sum of the .img. md5 is almost deprecated.
sorinm
Sat May 19, 2012 12:05 pm
John_McC wrote:Firstly thanks for the hard work and please excuse my lack of knowledge :oops: but when I run up your image on the pi it say its unable to connect to the site to update try again or continue ? if I continue it all loads ok but if I open the browser it seems unable to connect to any internet sites (can not connect to server) I know the connection is working as is the pi as other images are working. what am I doing wrong please help.
Cheers John
See if the Pi got its lease from the dhcp server.
What is the output of /sbin/ifconfig ?
If you refer to the message that appears when you startx is because it can`t resolve "slackware" hotname. Eighter change your hostname so that the dns server can resolve it or define in /etc/hosts slackware to your ip.
sorinm
Sat May 19, 2012 1:47 pm
I`d like to mention that the ArmedSlack`s firmware version is 32e0f0ed3f, added 2 days ago.
This firmware is supposed to fix more mmc0 timeouts from different cards.
More info http://www.raspberrypi.org/phpBB3/viewt ... f=2&t=6093
This firmware made my Sandisk Mobile Ultra microSDHC 8 GB class 6 usable with Pi.
sorinm
Sat May 19, 2012 3:43 pm
To get rid of this annoyng message init: Id "s0" respawning too fast: disabled for 5 minutes comment the following line in /etc/inittab: s0:12345:respawn:/sbin/agetty 115200 ttyS0 vt100
trn
Sun May 20, 2012 8:38 am
ifconfig return only lo
what with eth0? how can i get ip?
how to start fluxbox?
sorinm
Sun May 20, 2012 9:16 am
Please check logs and see why dhcp doesn`t work for you.
I don`t have any problem using dhcp. Use "netconfig" to run the network configuration script again.
To change your window manager to fluxbox for the whole system delete /etc/X11/xinit/xinitrc and symlink whatever xinitrc.* you have there to xinitrc
example: ln -s /etc/X11/xinit/xinitrc.fluxbox /etc/X11/xinit/xinitrc
OR
The simple way ! :)
slackpkg install x11-skel
pkgtool => setup => xwmconfig
Remember, run pkgtool to configure your system after the first boot.
trn
Sun May 20, 2012 1:59 pm
i dont have eth0, only lo
must install samo module to get eth0?
sorinm
Sun May 20, 2012 2:07 pm
Run netconfig
trn
Sun May 20, 2012 2:24 pm
i run
set hostname ...
1.set static, gw..
2.set dhcp
ifconfig return lo only too
sorinm
Sun May 20, 2012 2:28 pm
if you bring eth0 manually up what it says ?
/sbin/ifconfig eth0 inet {your ip} netmask {your netmask}
/sbin/route add default gw {your gw}
trn
Sun May 20, 2012 2:34 pm
eth0 device not found
eth1 is ok! (i found on boot, udev eth0 to eth1?!?!)
trn
how add to some skript, to always have eth1 static adr?
sorinm
Sun May 20, 2012 2:40 pm
Ok ,
I forgot to delete my mac address from udev rules
Delete from /etc/udev/rules.d/70-persistent-net.rules everything and after you reboot you should have eth0 up.
Thanks for reporting this, I totally forgot to clean this rule before packaging the image.
We`ll call the present slackware image a release candidate.
Please report any bugs.
trn
Sun May 20, 2012 2:45 pm
how to load sound module?
any module to play divx(video module)?
sorinm
Sun May 20, 2012 2:50 pm
I don`t recommend loading the sound module. It`s very very very buggy. I played an mp3 file and it hurt my ears. :)
to load the sound module : /sbin/modprobe snd-bcm2835
also you need alsa: slackpkg install alsa*
trn
Sun May 20, 2012 3:13 pm
xine is crashing
who and when repair sound driver?some guys on raspberry team, or distro team?
same question for GPU driver in X
sorinm
Sun May 20, 2012 3:22 pm
dom is responsable for the kernel.
I used audacious to play audio files ... or at least try.
slackping install audacious*
sorinm
Sun May 20, 2012 8:34 pm
There will be another version the following days to correct some minor problems. Also I want to include Midori in the next release. I already started to build some dependencies for it. Now I remember the good old days when I was recompiling the kernel in screen overnight on Pentium MMX 166 MHz :).
Return to “Other”
