smx wrote:Hello texy,
I have a couple of questions.
- 1. How much power does this shield use?
I need to check that and report back. I believe it will be less than 50mA, but I will confirm.
smx wrote:
- 2. I am using 3 heatsinks on my Rapsberry Pi. Doe they interfere with the size of your shield?
How high do the heatsinks go? The shield pcb rests on top of the ethernet port connector (on a model B).
smx wrote:
- 3. Is access to the remaining GPIO pins possible?
Yes - they are made available on a replication of the GPIO port on the shield pcb - you can just see part of the silkscreen through the top left mounting hole of the TFT pcb in the picture.
smx wrote:
- 4. Do you know of any case that fits this shield-Pi-combination's characteristics?
Yes - someone has fitted one to a pibow case here :
http://www.raspberrypi.org/phpBB3/viewt ... 77#p356770
I am also in discussion with a case designer, so watch this space
Texy
