#include <assert.h>
#include "GLES/gl.h"
#include "EGL/egl.h"
#include "EGL/eglext.h"
#define EGL_PIXEL_FORMAT_ARGB_8888_PRE_BRCM 0
#define EGL_PIXEL_FORMAT_ARGB_8888_BRCM 1
#define EGL_PIXEL_FORMAT_XRGB_8888_BRCM 2
#define EGL_PIXEL_FORMAT_RGB_565_BRCM 3
#define EGL_PIXEL_FORMAT_A_8_BRCM 4
#define EGL_PIXEL_FORMAT_RENDER_GL_BRCM (1 << 3)
#define EGL_PIXEL_FORMAT_RENDER_GLES_BRCM (1 << 4)
#define EGL_PIXEL_FORMAT_RENDER_GLES2_BRCM (1 << 5)
#define EGL_PIXEL_FORMAT_RENDER_VG_BRCM (1 << 6)
#define EGL_PIXEL_FORMAT_RENDER_MASK_BRCM 0x78
#define EGL_PIXEL_FORMAT_VG_IMAGE_BRCM (1 << 7)
#define EGL_PIXEL_FORMAT_GLES_TEXTURE_BRCM (1 << 8)
#define EGL_PIXEL_FORMAT_GLES2_TEXTURE_BRCM (1 << 9)
#define EGL_PIXEL_FORMAT_TEXTURE_MASK_BRCM 0x380
#define EGL_PIXEL_FORMAT_USAGE_MASK_BRCM 0x3f8
EGLSurface create_shared_pixmap(EGLDisplay display, EGLConfig config, EGLint* global_image, int width, int height) {
EGLint pixel_format = EGL_PIXEL_FORMAT_ARGB_8888_BRCM;
EGLint rt;
eglGetConfigAttrib(display, config, EGL_RENDERABLE_TYPE, &rt);
if (rt & EGL_OPENGL_ES_BIT) {
pixel_format |= EGL_PIXEL_FORMAT_RENDER_GLES_BRCM;
pixel_format |= EGL_PIXEL_FORMAT_GLES_TEXTURE_BRCM;
if (rt & EGL_OPENGL_ES2_BIT) {
pixel_format |= EGL_PIXEL_FORMAT_RENDER_GLES2_BRCM;
pixel_format |= EGL_PIXEL_FORMAT_GLES2_TEXTURE_BRCM;
if (rt & EGL_OPENVG_BIT) {
pixel_format |= EGL_PIXEL_FORMAT_RENDER_VG_BRCM;
pixel_format |= EGL_PIXEL_FORMAT_VG_IMAGE_BRCM;
if (rt & EGL_OPENGL_BIT) {
pixel_format |= EGL_PIXEL_FORMAT_RENDER_GL_BRCM;
global_image[0] = 0;
global_image[1] = 0;
global_image[2] = width;
global_image[3] = height;
global_image[4] = pixel_format;
eglCreateGlobalImageBRCM(width, height, global_image[4], 0, width*4, global_image);
EGLint attrs[] = {
EGL_VG_COLORSPACE, EGL_VG_COLORSPACE_sRGB,
EGL_VG_ALPHA_FORMAT, pixel_format & EGL_PIXEL_FORMAT_ARGB_8888_PRE_BRCM ? EGL_VG_ALPHA_FORMAT_PRE : EGL_VG_ALPHA_FORMAT_NONPRE,
EGL_NONE
return eglCreatePixmapSurface(display, config, (EGLNativePixmapType)global_image, attrs);
GLuint create_texture_from_shared_pixmap(EGLDisplay display, EGLint* global_image) {
assert (eglQueryGlobalImageBRCM(global_image, global_image+2));
EGLImageKHR image = eglCreateImageKHR(display, EGL_NO_CONTEXT, EGL_NATIVE_PIXMAP_KHR, (EGLClientBuffer)global_image, (void*)0/*NULL*/);
assert (image != EGL_NO_IMAGE_KHR);
GLuint tid;
glGenTextures(1, &tid);
glBindTexture(GL_TEXTURE_2D, tid);
glEGLImageTargetTexture2DOES(GL_TEXTURE_2D, image);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT); //GL_CLAMP_TO_EDGE);
glTexParameterf(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT); //GL_CLAMP_TO_EDGE);
eglDestroyImageKHR(display, image);
return tid;
Now that I have something that runs, I'll perhaps turn it into a python module or something.
I also keep wondering one thing. Now If I'd go and turn this into a desktop env, how would I synchronize the rendering such that there would be minimum issues with doing it all with compositing?
Also, how would I go if I'd want to optimize the desktop env mostly away, when the thing is in fullscreen mode? (This I might guess on my own though..)
Edit: Btw. if you try the example.. try call: sh build.sh, then ./compositing and keep it running while you call ./compositing2
