Jongoleur
Location: O'erlooking the sea, and all those effin windfarms...
Re: YOU SUCK: the venting thread
Sat Jan 14, 2012 10:45 pm
scep said:
tntexplosivesltd said:
Also I hate the fact that there will be a flood of millions of pointless unboxing videos a few days afterwards.
On the plus side, these will be very, very short: Open Jiffy, open ESD packet. Ummm... that's it
What'll be worse, will be the flood of "First Boot" videos with a liddle Raspberry in the TLC!
My brain is imploding, MY BRAIN IS IMPLODINGGGGGGGGGGGGGGGG.........
WTF is the sum of 6+1?
I'm too effin OLD to be doing sums.  At 22:43 of a Saturday evening!!!!!
And I've the willpower of a cabbage.. Hi!
I'm just a bouncer, splatterers do it with more force.....
pauldow
Sun Jan 15, 2012 12:50 am
Hey it beats using one of those slanty stretched ReCaptcha codes. Ya gotta use acid for those to start looking legible.
Chromatix
Sun Jan 15, 2012 4:12 am
Just HOW frigging difficult is it to get OpenVG and OpenGL ES and EGL working together on a desktop Linux install?  Using Ubuntu, it seems pretty much impossible, whether on desktop *or* TrimSlice - the OpenVG libraries are there but EGL doesn't report support for it.  Arch isn't much better as it requires hax0ring about with the AUR.
Mint seems to be better, and Gentoo seems to at least allege support for this stuff with the right useflags.  Shouldn't have to change distros for something like this though.
Bah humbug.
The key to knowledge is not to rely on people to teach you it.
Burngate
Sun Jan 15, 2012 5:24 pm
This forum software sucks
It keeps telling me there are only 4 threads I haven't caught up with, when I know there are over 50. And it doesn't like apostrophes.
Then, I haven't looked around, so maybe all software sucks. In fact I know all software sucks. Particularly stuff I wrote myself.
Also my car sucks. Then it squeezes. Then it bangs. Then it blows.
Like the wind. Except that doesn't do the suck-squeeze-bang bit. The fence did the bang bit. All of it. In the wind. All over my blackberry and raspberry briars. Which sucks.
Jongoleur
Sun Jan 15, 2012 7:37 pm
Which is ok, unless you run a Trabant.
Dancing on Ice sucks, but that's a subset of ITV, which sucks too.
1+3 sucks, but its better than distorted letters (I think...)
riffraff
Mon Jan 16, 2012 12:56 am
Forum can't suck nearly as bad as my ISP's DNS which insists that I need recipes for raspberry tarts every time I refresh a forum page. I have an entire flock of birds and a bushel or two of raspberries for them.
russ wall
Mon Jan 16, 2012 1:56 am
Twice as much flour as fat, yeh right! blah blah blah … but who does the washing up? This suckah!
celebrity mastercheifs .... I s*@T em
excuse but really ................
12 + 8 … a new high
tntexplosivesltd
Mon Jan 16, 2012 3:01 am
OH another thing, people who think that a Lego brick is called "A Lego". No. Just no. The product line is called Lego. When you purchase some, you receive Lego bricks.
Mon Jan 16, 2012 4:07 pm
Norovirus.
Having fun with that at the moment. Hence lack of comment moderation.
Jongoleur
Mon Jan 16, 2012 4:43 pm
JamesH said:
Norovirus.
Lovely.....
Get plenty of fluids in you!
ukscone
Mon Jan 16, 2012 4:49 pm
JamesH said:
Norovirus.
off to soak my keyboard in dettol. What is it with all these Raspberry Pi people getting colds and stuff? /me makes note to quarantine his Raspberry Pi when it arrives for a couple of weeks
max1zzz
Mon Jan 16, 2012 9:47 pm
My server crashed, opend my G5 to see what was wrong....
Seems it has finally given up to the dreaded G5 LCS leak, both cpu cards are badly corroded, one should pull through.
the other.... well that lost around 10 caps, almost certainly dead.
tomorrow i will drain and attempt to reseal it, hopefully it'll run fine with only one cpu card
MINKIN2
Mon Jan 16, 2012 9:54 pm
*Cough*LEGOS*cough*
Jongoleur
Mon Jan 16, 2012 9:57 pm
ukscone said:
JamesH said:
Norovirus.
You'd better do the mouse too.
Just be glad you're not using a touch-screen PC, you'd have to dunk the whole thing in dettol to be sure.  btw  Have you ever seen the Top Gear episodes where after buying second hand cars, they have them examined by forensic scientists to discover what crud might be inside the cars?
The results on both occasions were definitely gross…
On second thoughts, neat bleach would probably be for the best.
Combatants
Mon Jan 16, 2012 10:54 pm
Had something close happen last night. A mates Compression fitting on this radiator let go dropped fluid all down the board and pool onto the back of his new 6970
Dead CPU,Mobo,Ram and graphics
Water + PC = DONT MIX WHEN WILL PEOPLE LEARN !!
*real men use LN2 to run a pc *
rurwin
Mon Jan 16, 2012 11:25 pm
You can get a keyboard with a touchpad for about £30.
You can get a keyboard with a USB hub for about £30, but only ever two ports.
But you cannot get a keyboard with a touchpad and a USB hub for under £200.
I don't mind spending the same as the cost of the RPi on a keyboard. I object to spending ten times the amount.
liz
Mon Jan 16, 2012 11:46 pm
JamesH said:
Norovirus.
Commiserations. Go crazy with the spray bleach in the bathroom; it'll save the little Hs and Mrs H a lot of pain (if they haven't got it already).
I swear something to do with the stress of moderating this forum does awful things to the immune system.
Combatants
Tue Jan 17, 2012 12:33 am
I shiver the think about the stress the mods will face once the
OMGZ Y doze dis n0t run WoW!!
!!!!!one!!!!!
liz
Tue Jan 17, 2012 12:46 am
It's nothing compared to norovirus, but there's nowhere in this hotel room where I can sit and work without being dazzled. Eben and I stayed (for work) in so many Fairmonts last year that we've got bumped to a suite, which is very nice, but at the desk the sun shines off a mirror into your face; on one chair, it shines directly at you; and on the other, it shines off a building, into another mirror, and into your face.
Yes, I did do the sensible thing and shut the curtains.
Chromatix
Tue Jan 17, 2012 3:48 am
In fact the Trabant's engine does all that too, but in half the time.
The more you know...
Jongoleur
Tue Jan 17, 2012 7:34 am
Well, yes.  And no.
sucksqueeze/bangblow is one way to describe it, but it gets confusing when you consider that the suck also does the blow, and there's crankcase squeezing to consider too.  They're not all separate actions.
I'm surprised that people are still allowed to make two-stroke engines.....
9+4 - even my karma sucks.....
eeyore
Tue Jan 17, 2012 9:23 pm
My desktop of sucks, I turned it on and it"s beeps and that is nothing else, no bios or anything. Ram error according to the net.
And the fact I"ve just lost a whole post I typed in is thread cos I pressed the wrong button.....
riffraff
Fri Jan 20, 2012 6:19 am
In retrospect, I'd much rather do sums to post.
Just now read a medical article from my Android's news widget and wanted to post a comment.
Message at bottom reads "All opinions are moderated before being included (to stop spam)" and includes a ReCaptcha window with one word twisted into utter illegibility and the other in Hebrew - HEBREW!
Burngate
Fri Jan 20, 2012 6:49 pm
Well, yes.  And no.
Concorde did much the same thing, though it was a diesel. The suck & squeeze happened at the front, the bang was in the middle, and the blow was what made the thing go forward
TheEponymousBob
Fri Jan 20, 2012 8:03 pm
riFFraFF said:
In retrospect, I"d much rather do sums to post.
Just now read a medical article from my Android"s news widget and wanted to post a comment.
I remember one site using geometrical diagrams and asking "solve for x". I also spent one boring evening trying to come up with improved captchas:
What is this thing you call "love"? ________
This statement is false: (proceed/fail)
Open the pod bay doors? (OK/I"m afraid I can"t do that)
Launch Skynet? (Yes/No)
Why do you cry? _______
1 + 1: somehow fitting.
