jvmauricio
Longest Raspberry Pi uptime
Wed Jul 10, 2013 4:21 am
Just for fun (or for any practical purpose this may serve).
How long is your RPi running and who has the longest running Raspberry Pi?
Uptime is based on how long your RPi is connected to a power source and switched on so auto system reboot is acceptable. :)
mine is below:
RPi: Model B 512
OS: Raspbian Wheezy
Service/s: Transmission
Uptime: 9 Days and counting.
James-McC
Re: Longest RPi Uptime
Wed Jul 10, 2013 5:08 am
I've got one that's been on continuously since December last year, monitoring the temperatures in my central heating system (little rrd graphs on a web browser). Current uptime is 86 days but that's because we had a power failure in April and it rebooted.
I'm sure someone can beat that hands-down!
Ravenous
Wed Jul 10, 2013 10:57 am
James-McC wrote:I've got one that's been on continuously since December last year, monitoring the temperatures in my central heating system (little rrd graphs on a web browser). Current uptime is 86 days but that's because we had a power failure in April and it rebooted.
Liz posted recently that someone has had one running for a year, or something like that.
Not that hard when you consider how easy it is to battery-back one of these things.
RaTTuS
Contact: Twitter YouTube
Re: Longest Raspberry Pi uptime
Wed Jul 10, 2013 11:10 am
http://www.raspberrypi.org/phpBB3/viewt ... 3&p=377583
I'll not re-do my list yet
there are plenty of others that have much longer
Covfefe
W. H. Heydt
Wed Jul 10, 2013 6:08 pm
My two biggest constraints on long uptimes are periodic software upgrades (usually every 2 to 3 months) and a headless Pi occasionally has its ethernet go down (anyone know a fix for that?). I think the most recent forced reboot for that latter was after a bit over 90 days.
It's about time I upgraded the software on the two I keep running anyway.
jvmauricio
Thu Jul 11, 2013 1:27 am
W. H. Heydt wrote:My two biggest constraints on long uptimes are periodic software upgrades (usually every 2 to 3 months) and a headless Pi occasionally has its ethernet go down (anyone know a fix for that?). I think the most recent forced reboot for that latter was after a bit over 90 days.
There is a cronjob for checking wlan here http://rpi.tnet.com/project/scripts/wifi_check that will auto connect whenever it lost its connection and I think this can be edited to work with ethernet.
Lob0426
Thu Jul 11, 2013 3:58 am
The same for me and uptime as W.H. Heydt. Mine comes down for updates, backup and the occasional crash. These crashes are not due to the RasPi itself but due to brown outs from the local power company. The other cuase of any extended outage is from updating and the occasional bad update. Other than those caveats it has been running continuously since 8/25/12. That Raspberry Pi was taken down last week and replaced with a 512MB.
They can run stably for very long periods of time.
I now take it down for a backup before running updates. After the update it is backed up again. My uptime would be even better if I had my WordPress sever connected to a battery backup.
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
jgreen71
Fri Jul 19, 2013 8:11 pm
Linux greenpi 3.6.11+ #456 PREEMPT Mon May 20 17:42:15 BST 2013 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Jun 16 14:36:42 2013
pi@greenpi ~ $
W. H. Heydt
Sat Aug 03, 2013 10:56 pm
jvmauricio wrote: There is a cronjob for checking wlan here http://rpi.tnet.com/project/scripts/wifi_check that will auto connect whenever it lost its connection and I think this can be edited to work with ethernet.
Finally getting around to trying out this script....and finding some peculiar coding and behavior.
First point is that it is using the --force flag on ifup. According to the man page on ifup, it doesn't take that flag. Is that an undocumented feature, ignored, or just wrong?
The problem I'm finding with it is a bit more complicated....
1. I run the Pis that I want this for with static IP addresses. That data is in /etc/network/interfaces (the default location).
2. If I manually do "ifdown --force eth0" followed by "ifup eth0", ifconfig shows the proper (i.e. static) IP address.
3. If I run "ifdown --force eth0" followed by the modified script "RJ45_Check" (modifications consist of name change and network ID change, plus removing the --force from ifup), I get what appears to be a DHCP-assigned IP address.
What gives?
One other note...so far as I can tell, in order to run this script from cron, it has to be run as root, so the specified permissions (755) are....overkill. They should probably be 744.
Joe Schmoe
Sun Aug 04, 2013 1:04 am
700.
W. H. Heydt
Sun Aug 04, 2013 5:48 am
700.
I would argue that, on a device intended for educational purposes, making as much source code (such as a script like this) publicly readable is desirable, hence 744 instead of 700.
PaulCheffus
Mon Aug 05, 2013 10:15 am
Lob0426 wrote:The same for me and uptime as W.H. Heydt. Mine comes down for updates, backup and the occasional crash. These crashes are not due to the RasPi itself but due to brown outs from the local power company. The other cuase of any extended outage is from updating and the occasional bad update. Other than those caveats it has been running continuously since 8/25/12. That Raspberry Pi was taken down last week and replaced with a 512MB.
Hi
Same here as mine only seems to die due to a power cut. The best I have had is 99 days continuous uptime ended by a recent thunderstorm causing a power failure. Mine is one of the original model Bs with the F1 & F2 fuses.
Cheers
Paul
Procrastination - The Thief of Time.
W. H. Heydt
Mon Aug 05, 2013 6:12 pm
My "development" system is at 88 days right now.
I need to update it soon, though, I think. Probably once I get that Ethernet restart script working.
RaTTuS
Tue Aug 06, 2013 8:14 am
 for a in 31 32 33 34 35 ; do ssh 192.168.8.$a ""cat /etc/hostname ; grep Revision /proc/cpuinfo ; uname -v ; df -h ; uprecords" ; done ;
Monitoring RPi - runs in portrait mode has a Texy LCD screen attached for future use
mainly reset for updates but has had some power fails
raspberrypi
Revision        : 0002
#474 PREEMPT Thu Jun 13 17:14:42 BST 2013
Filesystem      Size  Used Avail Use% Mounted on
rootfs           15G  5.2G  8.8G  38% /
/dev/root        15G  5.2G  8.8G  38% /
devtmpfs        101M     0  101M   0% /dev
tmpfs            22M  564K   22M   3% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs            44M     0   44M   0% /run/shm
/dev/mmcblk0p1   56M   24M   33M  43% /boot
     #               Uptime | System                                     Boot up
     1    71 days, 22:59:51 | Linux 3.6.11+             Tue Mar 12 08:37:44 2013
     2    32 days, 17:49:08 | Linux 3.6.11+             Thu Jun 20 17:30:57 2013
     3    30 days, 05:03:22 | Linux 3.2.27+             Wed Dec 12 12:26:21 2012
     4    27 days, 18:56:43 | Linux 3.6.11+             Thu May 23 17:35:40 2013
     5    22 days, 23:26:51 | Linux 3.2.27+             Sat Nov 17 17:55:38 2012
     6    18 days, 05:55:29 | Linux 3.1.9+              Fri Aug 10 11:23:26 2012
     7    17 days, 00:47:44 | Linux 3.6.11+             Mon Feb 11 16:24:05 2013
     8    13 days, 20:10:25 | Linux 3.2.27+             Thu Sep 20 16:53:12 2012
->   9    12 days, 20:23:58 | Linux 3.6.11+             Wed Jul 24 12:35:39 2013
    10    11 days, 04:54:32 | Linux 3.2.27+             Fri Oct 19 08:39:20 2012
1up in     0 days, 23:46:28 | at                        Wed Aug  7 08:46:04 2013
no1 in    59 days, 02:35:54 | at                        Fri Oct  4 11:35:30 2013
    up   366 days, 05:58:16 | since                     Tue Jul 17 12:46:07 2012
  down    18 days, 14:15:14 | since                     Tue Jul 17 12:46:07 2012
   %up               95.168 | since                     Tue Jul 17 12:46:07 2012
current development version has a Pi-Lite onboard
Lite
Revision        : 000f
rootfs           15G  3.3G   11G  24% /
/dev/root        15G  3.3G   11G  24% /
devtmpfs        212M     0  212M   0% /dev
tmpfs            44M  236K   44M   1% /run
tmpfs            88M     0   88M   0% /run/shm
/dev/mmcblk0p1   56M   19M   38M  33% /boot
     1    46 days, 18:16:41 | Linux 3.6.11+             Thu May 30 16:04:25 2013
     2    15 days, 01:43:23 | Linux 3.6.11+             Tue Jul 16 10:16:53 2013
->   3     3 days, 19:08:55 | Linux 3.6.11+             Fri Aug  2 13:50:43 2013
     4     1 day , 01:22:24 | Linux 3.6.11+             Thu Aug  1 12:28:13 2013
     5     0 days, 00:36:40 | Linux 3.6.11+             Thu Aug  1 11:51:27 2013
     6     0 days, 00:18:13 | Linux 3.6.11+             Thu Aug  1 11:32:54 2013
     7     0 days, 00:17:27 | Linux 3.6.11+             Thu Aug  1 11:06:56 2013
1up in    11 days, 06:34:29 | at                        Sat Aug 17 15:34:05 2013
no1 in    42 days, 23:07:47 | at                        Wed Sep 18 08:07:23 2013
    up    66 days, 17:43:43 | since                     Thu May 30 16:04:25 2013
  down     0 days, 23:11:30 | since                     Thu May 30 16:04:25 2013
   %up               98.573 | since                     Thu May 30 16:04:25 2013
Has a SSD attached for quiet xbmc use - has my own kernel as it has a cypress usb controller which is not supported for rootfs use which I use
mainly rebooted when moving between places
Rasp-Solder
Revision        : 0002
#4 PREEMPT Wed May 29 18:49:21 BST 2013
rootfs           59G   46G  9.9G  83% /
/dev/root        59G   46G  9.9G  83% /
devtmpfs         85M     0   85M   0% /dev
tmpfs            19M  268K   19M   2% /run
tmpfs            37M     0   37M   0% /run/shm
/dev/mmcblk0p1   56M   30M   27M  54% /boot
     1    72 days, 21:43:04 | Linux 3.6.11+             Fri Mar  1 12:24:00 2013
->   2    47 days, 20:29:58 | Linux 3.6.11+             Wed Jun 19 12:29:41 2013
     3    20 days, 21:24:58 | Linux 3.2.27+             Thu Feb  7 12:16:50 2013
     4    13 days, 02:57:41 | Linux 3.6.11+             Thu Jun  6 09:30:02 2013
     5    12 days, 05:36:26 | Linux 3.6.11+             Fri May 17 10:31:54 2013
     6     6 days, 04:43:05 | Linux 3.6.11+             Thu May 30 12:37:07 2013
     7     2 days, 03:19:35 | Linux 3.6.11+             Mon May 13 10:16:49 2013
     8     1 day , 19:55:38 | Linux 3.6.11+             Wed May 15 14:31:09 2013
     9     0 days, 20:13:58 | Linux 3.6.11+             Wed May 29 16:23:02 2013
    10     0 days, 00:10:04 | Linux 3.6.11+             Wed May 29 16:08:08 2013
no1 in    25 days, 01:13:07 | at                        Sat Aug 31 10:12:44 2013
    up   178 days, 00:34:27 | since                     Thu Feb  7 12:16:50 2013
  down     1 day , 19:08:22 | since                     Thu Feb  7 12:16:50 2013
   %up               99.000 | since                     Thu Feb  7 12:16:50 2013
main development system has a camera which is used as a surveillance system ...
raspberrypi-IP
Revision        : 000d
rootfs          504G  124G  356G  26% /
/dev/root       504G  124G  356G  26% /
devtmpfs        180M     0  180M   0% /dev
tmpfs            38M  576K   37M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           1.6G     0  1.6G   0% /run/shm
     1    94 days, 18:18:26 | Linux 3.2.27+             Fri Feb  8 14:57:57 2013
     2    33 days, 19:22:26 | Linux 3.2.27+             Thu Dec 13 15:19:43 2012
     3    30 days, 18:04:22 | Linux 3.1.9+              Fri Jul 20 16:59:35 2012
     4    25 days, 04:38:26 | Linux 3.2.27+             Sun Nov 18 10:41:09 2012
->   5    24 days, 20:41:08 | Linux 3.6.11+             Fri Jul 12 12:18:32 2013
     6    16 days, 17:37:40 | Linux 3.2.27+             Fri Aug 24 16:10:54 2012
     7    14 days, 20:13:22 | Linux 3.2.27+             Fri Nov  2 13:39:18 2012
     8    14 days, 04:09:16 | Linux 3.6.11+             Tue May 28 12:04:26 2013
     9    14 days, 01:01:47 | Linux 3.2.27+             Mon Oct  8 09:33:30 2012
    10    12 days, 23:20:15 | Linux 3.2.27+             Tue Sep 25 10:09:04 2012
1up in     0 days, 07:57:19 | at                        Tue Aug  6 16:56:57 2013
no1 in    69 days, 21:37:19 | at                        Tue Oct 15 06:36:57 2013
    up   373 days, 00:05:35 | since                     Tue Jul 17 11:45:03 2012
  down    11 days, 21:09:02 | since                     Tue Jul 17 11:45:03 2012
   %up               96.913 | since                     Tue Jul 17 11:45:03 2012
this is a Model A has a macro mod camera attached
and attached to the host system via the serial GPIO's
raspberrypi-Slim
Revision        : 0008
rootfs          7.4G  1.9G  5.2G  27% /
/dev/root       7.4G  1.9G  5.2G  27% /
devtmpfs         53M     0   53M   0% /dev
tmpfs            13M  264K   12M   3% /run
tmpfs            25M     0   25M   0% /run/shm
     1    22 days, 17:33:15 | Linux 3.6.11+             Wed Jun 19 16:54:19 2013
     2    11 days, 01:00:07 | Linux 3.6.11+             Fri Jul 12 11:57:39 2013
     3     8 days, 18:58:58 | Linux 3.6.11+             Tue Jul 23 12:57:36 2013
     4     6 days, 01:57:28 | Linux 3.6.11+             Thu May 30 15:01:37 2013
     5     5 days, 15:59:39 | Linux 3.6.11+             Tue Jun 11 00:26:55 2013
     6     5 days, 07:19:29 | Linux 3.6.11+             Wed Jun  5 17:07:37 2013
     7     3 days, 21:46:44 | Linux 3.6.11+             Wed May 22 12:42:20 2013
     8     2 days, 18:08:24 | Linux 3.6.11+             Fri Aug  2 15:56:53 2013
     9     1 day , 12:09:29 | Linux 3.6.11+             Fri Feb  8 19:10:46 2013
    10     1 day , 06:03:57 | Linux 3.6.11+             Wed May 29 08:54:24 2013
->  14     0 days, 19:33:12 | Linux 3.6.11+             Mon Aug  5 13:26:33 2013
1up in     0 days, 00:29:20 | at                        Tue Aug  6 09:29:04 2013
t10 in     0 days, 10:30:46 | at                        Tue Aug  6 19:30:30 2013
no1 in    21 days, 22:00:04 | at                        Wed Aug 28 06:59:48 2013
    up    75 days, 00:16:41 | since                     Fri Feb  8 12:41:42 2013
  down   103 days, 19:01:22 | since                     Fri Feb  8 12:41:42 2013
   %up               41.952 | since                     Fri Feb  8 12:41:42 2013
Covfefe
caldimerda
Sun Sep 01, 2013 9:49 am
Must power mine down tomorrow :(
uptime
10:37:57 up 268 days, 21:18, 9 users, load average: 0.65, 0.31, 0.26
Running a Java home automation app that talks to an x10 controller via a USB to serial cable. Part of a little network of four Raspis all running java apps (the other three run a maxim weatherstation monitor, fileserver/webserver and development) that communicate using a UDP datagrams. I think having each raspi do different jobs makes for a more reliable system - hence the uptime.
Needless to say, the big question is whether to update the kernel when I power it back up. There have been a lot of USB fixes since December, but on the other hand, 268 days uptime is pretty reliable.
autotravis
Fri Sep 13, 2013 10:08 pm
caldimerda wrote:Must power mine down tomorrow :(
uptime
Wow, that's pretty impressive. I was up to 73 days when a storm caused the power to go out at my house.
Things I do with my Raspberry Pi -> http://magnatecha.com/things-i-do-with-my-raspberry-pi/
starspread
Thu Oct 10, 2013 1:42 am
uptime:
03:17:50 up 324 days, 6:34, 1 user, load average: 0.25, 0.15, 0.09
Using this one as my pppoe router
:D
DavidS
Thu Oct 10, 2013 11:25 am
Uptime on one RPi 318 days with out any reboot, RISC OS 5.19 512MB Model B.
On another 327 days, though reboot everyday after recompiling the ROM image from source, RISC OS 5.21 512MB Model B.
dcurzon
Fri Oct 11, 2013 3:07 pm
9 days 6hr so far
sim_tcr
Wed Dec 25, 2013 7:53 am
My pi is running continuous for 162 days now!! here you can see the live status http://raspisimon.no-ip.org/status.php
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
Joe Schmoe
Wed Dec 25, 2013 10:06 am
I find this thread funny, for the following reason:
Long uptimes on Linux systems (including the Pi) shouldn't really be news. Stable OS running stable processes - you expect long uptimes.
This next (what I am about to report) should be considered interesting and newsworthy:
  • I have a WIndows XP system (in my living room, which hosts several shared hard disks and runs various processes relating to recording TV shows), with 423 days of uptime (!).
Incidentally, my Pi gets rebooted fairly frequently, most recently to update the kernel (as recommended in various threads about "SD card corruption"). Also, when I switch between OSes (raspbian vs. open ELEC, mostly)
Ravenous
Fri Dec 27, 2013 8:53 am
Agreed, even in the Windows 95 days I used to have a little Toshiba Libretto that would run for a year or more at a time - it was just used as a music player in my kitchen, so a pretty undemanding application.
Uptime boasting is pretty pointless with the raspi - it's so easy to run it from a battery backup, there shouldn't really be an excuse for the more fanatical of the first adopters to have one that's been up since almost Day 1. You're never going to catch up with them! :D
Fri Dec 27, 2013 9:38 am
I'm keeping my RPi up as much as possible, but every time I want to play with GPIO or add a GPIO shield or update the kernel or update Raspbian or run RiscOS (or Pidora, or Arch, or XBMC) then it get a reboot (or even a power down).
If you don't want to see the white smoke of death then it's safer to shutdown before going anywhere near the pins.
I think the longest I've run it continuously is about a month. Since Xmas it's not been up for more than ten hours at a stretch.
If you add in the number of kernel updates and the move from Wheezy to Jessie (beta) it's going to be a while before it gets any long uptimes.
TheRPi
Fri Jan 03, 2014 12:20 am
RPi: Model B 512
OS: Raspbian Wheezy
Service/s: Apache/PHP/IRC
Uptime: up 45 days, 12:19
It was up for 182days prior to this, Power outage (Grid Fail) caused dowtime :(
iRaspberryPi
http://www.iRaspberryPi.pw
mikerr
Fri Jan 03, 2014 9:13 pm
Ravenous wrote:Agreed, even in the Windows 95 days I used to have a little Toshiba Libretto that would run for a year or more at a time - it was just used as a music player in my kitchen, so a pretty undemanding application.
Libretto was a great machine, ahead of it's time - but let down by a tiny battery life.
Of course Windows 95 had that HILARIOUS bug that meant it would crash at 49.7 days uptime,
http://news.cnet.com/2100-1040-222391.html
I remember it being routine to schedule a reboot every 30 days on quite a few systems.
As for raspi uptime, my pi-in-the-loft has 223 days uptime - that's mainly used for torrents / file server,
others rarely left on - I still like to go round randomly switching plugs off before bed - hate leaving stuff on !
