Hello from Vienna,
If you want to get a good overview on ARM based boards and computers running
Linux have a look on my blog.
http://bitkistl.blogspot.co.at/2013/02/ ... vices.html
Best Regards,
Peter Bauer
Re: Overview on ARM based computer
I received my Utilite computer some days ago and it came with Ubuntu 12.04 pre installed.
It has many interfaces but now GPIO's. So its more for Desktop use and not for tinkering.
I have done some small benchmark comparing it with the Pi and performance is nice.
http://bitkistl.blogspot.co.at/2013/07/ ... puter.html
Regards,
Peter
Regards,
Peter
On your page there is a typo in the url for the Utilite. You have it as .co instead of .com.
Thanks for the typo
WOW:
Are you aware that your page is 100% script with no way to access an alternitive HTML only version?
I opened the link to see a blank page, so I downloaded the page and opened it in !SrcEdit to see why a page of 20464 Bytes apeared blank.
Could you please provide a pure HTML alternitive (if it is not to much trouble).
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers.
It's his webpage....works fine on my machine...DavidS wrote:WOW:
Could you please provide a pure HTML alternative (if it is not to much trouble).
I am sure it does. And I am sure that you are using a web browser with Java Script enabled.
Yes, because this is 2013!DavidS wrote:I am sure it does. And I am sure that you are using a web browser with Java Script enabled.
Don't blame the OP, blame Google's blogger platform...DavidS wrote:Could you please provide a pure HTML alternitive (if it is not to much trouble).
I have JavaScript disabled by default. I always thought it was one more route in for malware. I particularly dislike having to enable JavaScript for my bank as they insist it makes the "experience" better.jamesh wrote:Yes, because this is 2013!DavidS wrote:I am sure it does. And I am sure that you are using a web browser with Java Script enabled.
Yes it is 2013. This gives us many more reasons to dissable JavaScript.jamesh wrote:Yes, because this is 2013!DavidS wrote: I am sure it does. And I am sure that you are using a web browser with Java Script enabled.
I like Java Script for loacal applications, not so much for use in a web page.
And yes I know that it was originaly designed as a scripting language for the web. That was the 90's I do not live in the past.
Oh realy. Interesting. I do not use a blogger so did not know that. I prefer to write HTML directly.AndrewS wrote:Don't blame the OP, blame Google's blogger platform...DavidS wrote: Could you please provide a pure HTML alternitive (if it is not to much trouble).
Maybe so. I do not like it as it makes the experience worse.joan wrote: I have JavaScript disabled by default. I always thought it was one more route in for malware. I particularly dislike having to enable JavaScript for my bank as they insist it makes the "experience" better.
I have the same problem with my bank. So I do not use there site ever.
