champ1
How FreeRTOS chooses which task should execute at any given time.
Sat Sep 18, 2021 10:55 am
Hello everyone
Can anyone tell me how the following behavior of the system can be obtained in free rtos
T1 runs once for 8ms in every 38ms with Priority 2
T2 runs twice for 5ms in every 38ms with Priority1
T3 runs twice times for 10ms in every 38ms with Priority3
I use xTaskCreate function to create Task's and vTaskStartScheduler(); to start scheduler.
B.Goode
Re: How FreeRTOS chooses which task should execute at any given time.
Sat Sep 18, 2021 10:58 am
Hello everyone
The organisation who develop, distribute and support that Operating System might know?
https://www.freertos.org/contact.html
Sat Sep 18, 2021 11:31 am
Are you using this on a Pi? On a Pico? On something else?
ghellquist
Sun Sep 19, 2021 8:03 am
My suggestions. Not really specific to this OS. All require that the OS has a hardware tick function.
.1) Use the OS supplied period timers to start the task (xTimerCreate with uxAutoReload) . You might write the callback function to realease all the tasks to run.
.2) Each task uses the delay function ( vTaskDelay ) until next start time. The task needs to calculate the difference between "now" and when it wants to start.
.3) Variation: use the delay until function (vTaskDelayUntil ). Add cycle time to last startup time.
.4) Do the cycle calculations and starts outside the three tasks. Could as exemple be done as an extension to the tick interrupt. The tasks waits for next start, the tick function signals the task somehow to start.
