gagarin
problem with raspberrypi-net-mods
Fri May 08, 2015 9:30 pm
help me please. I installed raspberrypi-net-mods but accidentally left the old file interfaces. manually configure the network wi-fi again . the new interface does not work ( the internet is working ) . when i reinstall the package raspberrypi-net-mods have not requested a replacement file interfaces. How do I reinstall the package raspberrypi-net-mods to prompted to replace the file . Show your file if you have a package raspberrypi-net-mods. apt-get clean and apt-get autoclean tried before reinstalling package
ShiftPlusOne
Re: problem with raspberrypi-net-mods
Sat May 09, 2015 3:52 am
Try this
apt-get install --reinstall -o Dpkg::Options::="--force-confask" raspberrypi-net-mods
Hove
Sat May 09, 2015 7:52 am
Worked for me, thanks!
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
TerryC65
Sat May 09, 2015 8:10 am
Can't help, but I'd like to add my experience.
I originally installed Raspbian about a month ago. Unfortunately, wpa-gui didn't work for me, so I manually set up the Wireless Access Point's credentials in the file /etc/wpa-supplicant/wpa-supplicant.conf and lived without the GUI icon.
Yesterday, I upgraded (by accident actually, I was trying to fix something else!). I then found that the new version was out when I visited the Pi Home Page and realised that there should now be a new GUI. However, I still didn't have one. Re-reading the original post I saw that the network interface was a separate package, so I ran the command given. I still cannot see the icon.
I have tried purging the network interface package and re-installing after purging wpa-gui, but no joy. I see that there are a couple of network related plugins for the Panel where the icon should be, but neither provide the new icon.
So how can I add the new network icon?
gagarin
Sat May 09, 2015 10:53 am
ShiftPlusOne wrote:Try this
thanks!
its greate.
TerryC65
Sat May 09, 2015 12:07 pm
TerryC65 wrote:I have tried purging the network interface package and re-installing after purging wpa-gui, but no joy. I see that there are a couple of network related plugins for the Panel where the icon should be, but neither provide the new icon.
Replying to myself.
I have now fixed this by re-running the commands to do the upgrade (eg apt-get update and apt-get dist-upgrade). There were a few packages that had changed, none related to the network package, but I noticed that one included adding items to the Panel.
Presumably, this refreshed the panel content, because the new icon appeared as a Panel Applet, which I was able to add.
Joe Schmoe
Sat May 09, 2015 1:56 pm
Did you ever figure out which thing specifically to install to get just the "panel changes" ? Can this, maybe, be deduced by looking at "dpkg -l" of a "patched" system?
TerryC65
Sat May 09, 2015 3:05 pm
Joe Schmoe wrote:Did you ever figure out which thing specifically to install to get just the "panel changes" ? Can this, maybe, be deduced by looking at "dpkg -l" of a "patched" system?
Only by guesswork and a somewhat faulty memory. I recall that the additional packages were related to Sonic Pi, but I think the key one was lxpanel. I remember some message about updating it to include the Sonic Pi icon.
Hope this helps.
