kusti8
Re: Guide: Chromium 45 on Raspbian Jessie
Tue Oct 27, 2015 8:36 pm
usultis wrote:Yeah, I recall from Ubuntu's launchpad that [armhf build][https://launchpadlibrarian.net/21920828 ... ING.txt.gz] takes them around 10h (I'm not sure what hardware do they use), still doing that on Raspberry Pi is "more demanding".
Let me know of the outcome, even if it fails I would like to take a look at the build steps necessary.
Sure. I saw that page, but on the Pi it's going to take much longer. I tried cross compiling it but for some reason it wouldn't work. I'll detail my steps if I have time.
kusti8
Tue Oct 27, 2015 8:49 pm
Here were my basic steps:
1. Download this and this:
http://ports.ubuntu.com/pool/universe/c ... ian.tar.xz
http://ports.ubuntu.com/pool/universe/c ... rig.tar.xz
2. Unzip both and bring the debian folder into the chromium folder
3. In the debian folder, change the rules file to this:
#!/usr/bin/make -f
DEBIAN_NAME		:= $(shell dpkg-parsechangelog | sed -n 's/^Source: *\(.*\)$$/\1/ p')
DEBIAN_VERSION		:= $(shell dpkg-parsechangelog | sed -n 's/^Version: *\(.*\)$$/\1/ p')
DEBIAN_UPSTREAM_VERSION	:= $(shell echo $(DEBIAN_VERSION) | sed 's/^\(.*\)-[^-]*$$/\1/')
DEBIAN_REVISION		:= $(shell echo $(DEBIAN_VERSION) | sed 's/^.*r\([^-]*\)-.*/\1/')
DEBIAN_DIST		:= $(shell lsb_release -ds | tr -d '()' |sed -e 's/\#/ /g')
DEBIAN_DIST_NAME	:= $(shell lsb_release -si |sed -e 's/\#/ /g')
DEBIAN_DIST_VERSION	:= $(shell lsb_release -sr |sed -e 's/\#/ /g')
DEBIAN_CODECS_NAME      := $(subst browser,codecs-ffmpeg,$(DEBIAN_NAME))
DEBIAN_DRIVER_NAME      := $(subst browser,chromedriver,$(DEBIAN_NAME))
DEB_HOST_ARCH ?= $(shell dpkg-architecture -qDEB_HOST_ARCH)
export DEB_HOST_ARCH
DEB_HOST_MULTIARCH ?= $(shell dpkg-architecture -qDEB_HOST_MULTIARCH)
DEB_HOST_ARCH_CPU ?= $(shell dpkg-architecture -qDEB_HOST_ARCH_CPU)
DEB_BUILD_ARCH ?= $(shell dpkg-architecture -qDEB_BUILD_ARCH)
DEB_BUILD_ARCH_BITS ?= $(shell dpkg-architecture -qDEB_BUILD_ARCH_BITS)
DEB_TAR_SRCDIR := .
SRC_DIR        := $(CURDIR)/$(DEB_TAR_SRCDIR)
LIB_DIR        := usr/lib/$(DEBIAN_NAME)
BINARY_PACKAGE_COMPRESSION ?= xz
FFMPEG_DIR     := third_party/ffmpeg
FFMPEG_SRC_DIR := $(SRC_DIR)/$(FFMPEG_DIR)
NINJA          := ninja
SNAPPY_PKGR_TO_USE :=
# Whitelist LP provided new langs only in release builds, PPAs ship them all
WANT_ONLY_WHITELISTED_NEW_LANGS ?= 0
ifneq (,$(findstring Ubuntu,$(DEBIAN_DIST)))
DISTRIBUTION=UBUNTU
UBUNTU_DIST=$(DEBIAN_DIST)
endif
ifneq (,$(findstring Debian,$(DEBIAN_DIST)))
DISTRIBUTION=DEBIAN
endif
WANT_DEBUG       ?= 0
WANT_SHARED_LIBS ?= 0
# Set up Google API keys, see http://www.chromium.org/developers/how-tos/api-keys .
# Note: these are for Ubuntu use ONLY. For your own distribution,
# please get your own set of keys.
# Permission to add API keys, from Paweł Hajdan, To chad.miller@canonical.com
# msgid: CAADNaOFSFoch68NM1SGpCTRXqmspyKQgUPUtsF7SGRsRXiHZcg@mail.gmail.com
GOOGLEAPI_APIKEY_UBUNTU := AIzaSyAQfxPJiounkhOjODEO5ZieffeBv6yft2Q
GOOGLEAPI_CLIENTID_UBUNTU := 424119844901.apps.googleusercontent.com
GOOGLEAPI_CLIENTSECRET_UBUNTU := AIienwDlGIIsHoKnNHmWGXyJ
GYP_PARAMS := --depth=$(CURDIR) --format=ninja
BROWSER_GYP_DEFINES =
FFMPEG_GYP_DEFINES =
GYP_DEFINES =
# Build the launchpad translations (already landed upstream)
GYP_DEFINES += use_third_party_translations=1
# Always add debug symbols, and strip them when we don't want them.
#GYP_DEFINES += release_extra_cflags="-g"
# Don't fail on compilation warnings.
GYP_DEFINES += werror=$(NULL)
# We are never using a sysroot-based toolchain; override the wrong
# autodetection for arm.
GYP_DEFINES += sysroot=
# Link directly to library instead of using dlopen.
GYP_DEFINES += linux_link_gsettings=1
# Disable NaCl until we figure out what to do with the private toolchain
GYP_DEFINES += disable_nacl=1
# do not use third_party/gold as the linker.
GYP_DEFINES += linux_use_gold_binary=0 linux_use_gold_flags=0
# enable features that we want.
GYP_DEFINES += enable_webrtc=1
# get resources for high dpi and touch
GYP_DEFINES += use_aura=1
GYP_DEFINES += enable_hidpi=1
GYP_DEFINES += enable_touch_ui=1
# add support and stubbed implementation of widevine (needed for EME)
GYP_DEFINES += enable_widevine=1 enable_pepper_cdms=1
# Prefer gcc/g++ over clang until clang is better tested in Ubuntu.
GYP_DEFINES += clang=0
#GYP_DEFINES += use_ozone=1 ozone_auto_platforms=0 ozone_platform_mir=1 ozone_platform_wayland=0
#GYP_DEFINES += ozone_platform_mir=1
# Intentional configuration, not bug work-arounds.
ifeq (arm,$(DEB_HOST_ARCH_CPU))
GYP_DEFINES += \
	arm_neon=1 \
	target_arch=arm \
	use_cups=1 \
	$(NULL)
 ifeq (armel,$(DEB_HOST_ARCH))
GYP_DEFINES += \
	v8_use_arm_eabi_hardfloat=true \
	arm_float_abi=hard \
	arm_thumb=0 \
	armv7=1 \
	$(NULL)
 endif
 ifeq (armhf,$(DEB_HOST_ARCH))
GYP_PARAMS += -DUSE_EABI_HARDFLOAT
# ARN Neon optional flag is off because it causes build errors, AND testing
# /proc/cpuinfo contents can't work with a sandbox anyway.
GYP_DEFINES += \
	arm_neon_optional=0 \
	arm_fpu=neon-vfpv4 \
	arm_thumb=1 \
	armv7=1 \
	arm_version=7 \
	$(NULL)
 endif
endif
ifeq (amd64,$(DEB_HOST_ARCH))
GYP_DEFINES += target_arch=x64
endif
ifeq (i386,$(DEB_HOST_ARCH))
GYP_DEFINES += target_arch=ia32
# SEGV on component builds, 2013-05
GYP_DEFINES += use_allocator=none
# Some mobile CPUs don't support SSE instructions. SIGILL. 2014-08
GYP_DEFINES += disable_sse2=1
endif
# Do this for every architecture. More than 4GB of memory is too much to expect
# of builders.
COMPONENT_SHARED_LIB_BUILD := 1
ifeq (1,$(COMPONENT_SHARED_LIB_BUILD))
BROWSER_GYP_DEFINES += component=shared_library
FFMPEG_GYP_DEFINES += component=shared_library
endif
# Webkit library is enormous. Exclude for now.
GYP_DEFINES += remove_webcore_debug_symbols=1
# Don't let dh_installinit install *.default in /etc/default
DEB_DH_INSTALLINIT_ARGS += --noscripts --onlyscripts
# Don't let scour touch the svg files
DEB_DH_SCOUR_ARGS += -Xsvg
DEB_DH_BUILDDEB_ARGS += -- -Z $(BINARY_PACKAGE_COMPRESSION)
ifneq (0,$(WANT_DEBUG))
BUILD_TYPE := Debug
else
BUILD_TYPE := Release
# Add symbols
GYP_DEFINES += linux_dump_symbols=1
GYP_DEFINES += logging_like_official_build=1
endif
BUILD_ARGS := -v
BUILD_ARGS += -C $(DEB_TAR_SRCDIR)/out/$(BUILD_TYPE)
# Shared libraries
ifeq (1,$(WANT_SHARED_LIBS))
GYP_DEFINES += library=shared_library
endif
#post-patches::
#	sed -i 's^\("/usr/lib/nss"\)^/*REM \1 REM*/"/usr/lib/$(DEB_HOST_MULTIARCH)/nss"/**/^' $(DEB_TAR_SRCDIR)/crypto/nss_util.cc
#	perl $(CURDIR)/debian/enable-dist-patches.pl $(DEBIAN_DIST_VERSION) $(CURDIR)/debian/patches/series
subst_files = \
	debian/$(DEBIAN_NAME).sh \
	$(NULL)
# FFmpeg-mt
# Don't build it as part of chromium. Build it separately twice, once with
# the Chrome branding to gain the extra codecs, and once without branding.
# The ffmpeg_branding variable controls which codecs are built inside the ffmpeg lib.
# By default, ffmpeg_branding equals to "Chromium" and only builds the ogg/vorbis/theora codecs.
# When set to "Chrome", it also builds aac/ac3/mpeg4audio/h264/mov/mp3
DEB_DH_SHLIBDEPS_ARGS_$(DEBIAN_CODECS_NAME) := -l$(CURDIR)/debian/$(DEBIAN_CODECS_NAME)/$(LIB_DIR)
DEB_DH_SHLIBDEPS_ARGS_$(DEBIAN_CODECS_NAME)-extra := -l$(CURDIR)/debian/$(DEBIAN_CODECS_NAME)-extra/$(LIB_DIR)
BROWSER_GYP_DEFINES += \
	proprietary_codecs=1 \
	$(NULL)
FFMPEG_GYP_DEFINES += \
	use_system_vpx=0 \
	release_extra_cflags=-g \
	$(NULL)
FFMPEG_STD_GYP_DEFINES   = $(NULL)
FFMPEG_EXTRA_GYP_DEFINES = ffmpeg_branding=Chrome
# Precise doesn't set some settings.
ifeq (,$(filter 12.04%,$(UBUNTU_DIST)))
# enable compile-time dependency on gnome-keyring
GYP_DEFINES += use_gnome_keyring=1 linux_link_gnome_keyring=1
# controlling the use of GConf (the classic GNOME configuration
# and GIO, which contains GSettings (the new GNOME config system)
GYP_DEFINES += use_gconf=1 use_gio=1
endif
# Build chrome and chrome_sandbox, and chromedriver
BUILD_TARGETS := \
	pdf \
	chrome \
	chrome_sandbox \
	chromedriver \
	$(NULL)
# Needed to preserve the suid and make the sandbox happy
DEB_FIXPERMS_EXCLUDE := chrome-sandbox
ifneq (,$(GOOGLEAPI_APIKEY_$(DISTRIBUTION)))
GYP_DEFINES += \
	google_api_key='$(GOOGLEAPI_APIKEY_$(DISTRIBUTION))' \
	google_default_client_id='$(GOOGLEAPI_CLIENTID_$(DISTRIBUTION))' \
	google_default_client_secret='$(GOOGLEAPI_CLIENTSECRET_$(DISTRIBUTION))'
else
$(warning Google API info is not set in build variables GOOGLEAPI_APIKEY_$(DISTRIBUTION) GOOGLEAPI_CLIENTID_$(DISTRIBUTION) GOOGLEAPI_CLIENTSECRET_$(DISTRIBUTION))
endif
ifneq ($(DEB_HOST_ARCH),$(DEB_BUILD_ARCH))
CROSS_BUILD = PKG_CONFIG_PATH=/usr/lib/$(DEB_HOST_MULTIARCH)/pkgconfig:/usr/$(DEB_HOST_MULTIARCH)/lib/pkgconfig CXX=$(DEB_HOST_GNU_TYPE)-g++ CC=$(DEB_HOST_GNU_TYPE)-gcc AR=$(DEB_HOST_GNU_TYPE)-ar AS=$(DEB_HOST_GNU_TYPE)-as CPP=$(DEB_HOST_GNU_TYPE)-cpp LD=$(DEB_HOST_GNU_TYPE)-ld
else
CROSS_BUILD = CC=$$(which gcc-4.8 gcc |head -1) CXX=$$(which g++-4.8 g++ |head -1)
endif
### Official interfaces.
# Debian Policy §4.9
binary binary-arch binary-indep build build-arch build-indep clean install install-arch install-indep patch:
	@set -eux
	dh --sourcedirectory=$(DEB_TAR_SRCDIR) --builddirectory=$(DEB_TAR_SRCDIR)/out/$(BUILD_TYPE)-chromium --with quilt $@
# BZR build-deb rule
get-packaged-orig-source: URL=https://commondatastorage.googleapis.com/chromium-browser-official/chromium-$(ORIG_VERSION).tar.xz
get-packaged-orig-source: SUMURL=https://commondatastorage.googleapis.com/chromium-browser-official/chromium-$(ORIG_VERSION).tar.xz.hashes
get-packaged-orig-source: DEST_FILENAME=chromium-browser_$(ORIG_VERSION).orig.tar.xz
	@set -eux
	wget --continue --progress=dot:mega $(URL)
	diff -u <(wget -O - -q $(SUMURL); echo) <(for crypto in md5 sha1 sha224 sha256 sha384 sha512; do echo -n "$$crypto  "; $${crypto}sum 'chromium-$(ORIG_VERSION).tar.xz'; done)
	mv "chromium-$(ORIG_VERSION).tar.xz" "$(DEST_FILENAME)"
get-orig-source:
	@set -eux
	test "$(ORIG_VERSION)" || { echo "Set ORIG_VERSION" to use this rule.; exit 1; }
	ORIG_VERSION=$(ORIG_VERSION) $(MAKE) get-packaged-orig-source
### Below here, rules that support those above required ones.  "override_dh_"*
### are of course DH customizations.
override_dh_auto_configure:
	# Don't configure here. We configure and build many times in 'build'.
# There are three things to build. Standard and ffmpeg full.
override_dh_auto_build: build-stamp build-stamp-ffmpeg-extra
override_dh_fixperms:
	dh_fixperms --exclude $(DEB_FIXPERMS_EXCLUDE)
override_dh_builddeb:
	dh_builddeb -- -Zxz
override_dh_installman:
	# install does this
override_dh_install-arch: local-install-arch compare-arch
override_dh_install-indep: local-install-indep compare-indep
override_dh_shlibdeps:
	dh_shlibdeps -l$(CURDIR)/debian/chromium-browser/usr/lib/chromium-browser/libs/ |grep -v "dpkg-shlibdeps: warning: can't extract name and version from library name" || true
local-install-arch: S_CR_PATH := apps/chromium/current
local-install-arch: SNAPPY_ROOT := debian/snappy/$(S_CR_PATH)
local-install-arch: PKG_DIRS := $(addprefix debian/,$(shell dh_listpackages))
local-install-arch: TRASH := .deps gen obj.host obj.target \*.lock obj build.\* .landmines mksnapshot.ia32 protoc pyproto re2c resources xdg-mime yasm \*.TOC \*.stamp product_logo_\*png gen\* lib/\* lib libvpx_obj_int_extract .ninja\* chrome-wrapper \*.breakpad.\* java_mojo dump_syms
local-install-arch:
	@set -eux
	# Two stages: Install out of source tree. Copy to packaging.
	mkdir -p                                                          $(CURDIR)/debian/tmp-std/$(LIB_DIR)/libs
	mv -v $(SRC_DIR)/out/$(BUILD_TYPE)-chromium/lib/libffmpeg.so      $(CURDIR)/debian/tmp-std/$(LIB_DIR)/libs
	mkdir -p                                                          $(CURDIR)/debian/tmp-extra/$(LIB_DIR)/libs
	mv -v $(SRC_DIR)/out/$(BUILD_TYPE)-ffmpeg-extra/lib/libffmpeg.so  $(CURDIR)/debian/tmp-extra/$(LIB_DIR)/libs
endif
	mkdir -p $(CURDIR)/debian/tmp/$(LIB_DIR)
	(cd $(SRC_DIR)/out/$(BUILD_TYPE)-chromium; tar cf - . $(foreach excl,$(TRASH),--exclude=$(excl) );) | (cd debian/tmp/$(LIB_DIR); tar xvf -;)
	mkdir -p debian/tmp/$(LIB_DIR)/libs
	cp $(SRC_DIR)/out/$(BUILD_TYPE)-chromium/lib/*.so debian/tmp/$(LIB_DIR)/libs/
endif
	(cd $(SRC_DIR)/out/$(BUILD_TYPE)-chromium; tar cf - xdg-settings;) | (cd debian/tmp/$(LIB_DIR); tar xvf -;)
ifneq ($(SNAPPY_PKGR_TO_USE),)
	mkdir -p $(SNAPPY_ROOT)/private/libs
	mkdir -p $(SNAPPY_ROOT)/meta
endif
	# Icons
	cp -a $(DEB_TAR_SRCDIR)/chrome/app/theme/chromium/product_logo_48.png debian/chromium-browser/usr/share/pixmaps/chromium-browser.png
	for size in 22 24 32 48 64 128 256 ; do \
	  if test -f "$(DEB_TAR_SRCDIR)/chrome/app/theme/chromium/product_logo_$$size.png"; then \
	    dh_installdirs --package=chromium-browser usr/share/icons/hicolor/$${size}x$${size}/apps ; \
	    cp -a $(DEB_TAR_SRCDIR)/chrome/app/theme/chromium/product_logo_$$size.png  \
	      debian/chromium-browser/usr/share/icons/hicolor/$${size}x$${size}/apps/chromium-browser.png ; \
	  else \
	    echo "There is no size $${size} icon. We expected one."; \
	  fi; \
	done
	cp -a debian/chromium-browser.svg debian/chromium-browser/usr/share/icons/hicolor/scalable/apps
	cp -a debian/chromium-browser.svg $(SNAPPY_ROOT)/meta/chromium.svg
endif
	##### Copy installed to package ####
	(cd debian/tmp/$(LIB_DIR); tar cf - . --exclude=chromedriver;) | (cd debian/chromium-browser/$(LIB_DIR); tar xvf -;)
	(cd debian/tmp/$(LIB_DIR); tar cf - .;) | (cd $(SNAPPY_ROOT)/private; tar xvf -;)
endif
	# prev missed "libs"
	(cd debian/tmp/$(LIB_DIR)/libs; tar cf - .;) | (cd debian/chromium-browser/$(LIB_DIR)/libs/; tar xvf -;)
	(cd debian/tmp/$(LIB_DIR)/libs; tar cf - .;) | (cd $(SNAPPY_ROOT)/private/libs; tar xvf -;)
	(cd debian/tmp-extra/$(LIB_DIR); tar cf - .;) | (cd $(SNAPPY_ROOT)/private; tar xvf -;)
endif
	# Set the directory for looking up component libraries.
	find $(SNAPPY_ROOT)/private/libs             -type f -name \*.so             -execdir chrpath --replace "\$$ORIGIN" {} \;
	find $(SNAPPY_ROOT)/private      -maxdepth 1 -type f -name \*.so             -execdir chrpath --replace "\$$ORIGIN/libs" {} \;
	find $(SNAPPY_ROOT)/private      -maxdepth 1 -type f             -executable -execdir chrpath --replace "\$$ORIGIN/libs" {} \;
endif
	find debian/*/$(LIB_DIR)/libs             -type f -name \*.so             -execdir chrpath --replace "\$$ORIGIN" {} \;
	find debian/*/$(LIB_DIR)      -maxdepth 1 -type f -name \*.so             -execdir chrpath --replace "\$$ORIGIN/libs" {} \;
	find debian/*/$(LIB_DIR)      -maxdepth 1 -type f             -executable -execdir chrpath --replace "\$$ORIGIN/libs" {} \;
endif
	# Launcher script
	cp -a debian/chromium-browser.sh debian/chromium-browser/usr/bin/chromium-browser
	cp -a debian/chromium-browser.sh $(SNAPPY_ROOT)/chromium
endif
	chmod 755 debian/chromium-browser/usr/bin/chromium-browser
	chmod 755 $(SNAPPY_ROOT)/chromium
	sed -i -e 's,$(LIB_DIR),$(S_CR_PATH)/private,' $(SNAPPY_ROOT)/chromium
endif
	# Preferences
	cp -a debian/chromium-browser.default debian/chromium-browser/etc/chromium-browser/default
	# Rename the binary from chrome to chromium-browser, this is required as
	# chromium dereferences all symlinks before starting its children making
	# the Gnome System Monitor confused with icons
	mv debian/chromium-browser/$(LIB_DIR)/chrome debian/chromium-browser/$(LIB_DIR)/chromium-browser
	mv $(SNAPPY_ROOT)/private/chrome $(SNAPPY_ROOT)/private/chromium-browser
endif
	# "you have to change the underscore from the build target into a hyphen".
	# https://code.google.com/p/chromium/wiki/LinuxSUIDSandbox
	mv debian/chromium-browser/$(LIB_DIR)/chrome_sandbox debian/chromium-browser/$(LIB_DIR)/chrome-sandbox
	mv $(SNAPPY_ROOT)/private/chrome_sandbox $(SNAPPY_ROOT)/private/chrome-sandbox
endif
	chmod 4755 debian/chromium-browser/$(LIB_DIR)/chrome-sandbox
	chmod 4755 $(SNAPPY_ROOT)/private/chrome-sandbox
endif
	# Manpage is for wrong program name, and it's in a weird place.  Use and destroy.
	mkdir -p debian/chromium-browser/usr/share/man/man1
	mv debian/chromium-browser/$(LIB_DIR)/chrome.1 debian/chromium-browser/usr/share/man/man1/chromium-browser.1
	gzip -f -9 debian/chromium-browser/usr/share/man/man1/chromium-browser.1
	# NaCL may be blacklisted, so only include it when it's been built
ifeq (,$(filter disable_nacl=1,$(GYP_DEFINES)))
	cp -a $(SRC_DIR)/out/$(BUILD_TYPE)-chromium/libppGoogleNaClPluginChrome.so debian/chromium-browser/$(LIB_DIR)/
	cp -a $(SRC_DIR)/out/$(BUILD_TYPE)-chromium/nacl_irt_* debian/chromium-browser/$(LIB_DIR)/
endif
	# Locales: only keep en-US in the main deb
	# Discard everything except en-US
	find debian/chromium-browser/$(LIB_DIR)/locales debian/chromium-browser/$(LIB_DIR)/remoting_locales -type f \! -name en-US.pak -print -delete
	# this should find almost nothing
	find debian/chromium-browser/$(LIB_DIR) -type f -name \*.pak -print
	# we need space on the CD, so remove duplicates of the doc files
	# (See LP: #194574 as for why we don't let cdbs do it)
	@for doc in copyright AUTHORS changelog.Debian.gz ; do \
	  F=debian/$(DEBIAN_NAME)/usr/share/doc/$(DEBIAN_NAME)/$$doc ; \
	  for file in `find $(addsuffix /usr/share/doc,$(filter-out debian/$(DEBIAN_NAME),$(PKG_DIRS))) -type f -name $$doc -print`; do \
	    cmp -s $$file $$F ; \
	    if [ $$? -eq 0 ] ; then \
	      rm -f $$file ; \
	      echo "  symlinking $$doc in '"`echo $$file | awk 'BEGIN{ FS="/"} { print $$2 }'`"' to file in '$(DEBIAN_NAME)'" ; \
	      ( cd `dirname $$file` ; ln -s ../$(DEBIAN_NAME)/$$doc ) ; \
	    fi ; \
	  done ; \
	done
endif
	dh_install -a
	dh_listpackages -a |grep -v -- -dbg |while read pkg; do dh_strip --package=$$pkg --dbg-package=$${pkg}-dbg; done
	DEB_HOST_ARCH="$(DEB_HOST_ARCH)" SNAPPY="$(SNAPPY_ROOT)" make -f debian/generate-snappy.mk
	find $(SNAPPY_ROOT) -type f -exec strip {} \;
	pushd $(SNAPPY_ROOT)/private/libs && for try in 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20; do LC_ALL=C ldd *.so ../*.so ../*.a ../chromium-browser |grep -v " => not found" |grep " => " |cut -d\( -f1 |sort |uniq |while read want arrow foundat; do test -f "$$want" || test -z "$$foundat" || cp -v "$$foundat" ./; done; done
	-popd
	cd ..; $(SNAPPY_PKGR_TO_USE) build $(CURDIR)/$(SNAPPY_ROOT) || true
endif
local-install-indep:
	@set -eux
	dh_install -i
	install --directory debian/chromium-browser/etc/chromium-browser/customizations
	install --owner=root --mode=0644 --no-target-directory debian/chromium-browser-customization-example debian/chromium-browser/etc/chromium-browser/customizations/00-example
	find debian/chromium-browser-l10n/$(LIB_DIR)/remoting_locales debian/chromium-browser-l10n/$(LIB_DIR)/locales -name en-US.pak -print -delete
override_dh_clean:
	@set -eux
	test -d chrome
	rm -rf $(SRC_DIR)/out
	dh_clean debian/chromium-browser.sh debian/*-stamp debian/stamp-* debian/tmp-* build-stamp* $(subst_files) $(FFMPEG_SRC_DIR)/yasm
	rm -rf debian/snappy
	find $(SRC_DIR) \( -name \*.pyc -o -name \*.pyo -name \*.o \) -delete
	find $(SRC_DIR) -regex '.*/\([^/]*\)/\1[^/]*\.\(Makefile\|\(target\|host\)\.mk\)' -delete
	set +x
	echo
	echo VERIFICATION:
	cd ..; for crypto in md5 sha1 sha224 sha256 sha384 sha512; do $${crypto}sum 'chromium-browser_$(DEBIAN_UPSTREAM_VERSION).orig.tar.xz' |sed -e 's/-browser//' -e "s/^/$${crypto}  /"; done
	echo VERIFICATION-
	echo Compare to https://commondatastorage.googleapis.com/chromium-browser-official/chromium-$(DEBIAN_UPSTREAM_VERSION).tar.xz.hashes
	echo
debian/chromium-browser.sh: debian/chromium-browser.sh.in
	@set -eux
	### configure
	sed -e 's/@BUILD_DIST@/$(DEBIAN_DIST_NAME) $(DEBIAN_DIST_VERSION)/g' \
    -e 's/@BUILD_DIST_NAME@/$(DEBIAN_DIST_NAME)/g' \
    -e 's/@BUILD_DIST_VERSION@/$(DEBIAN_DIST_VERSION)/g' \
    -e 's/@UPSTREAM_VERSION@/$(DEBIAN_UPSTREAM_VERSION)/g' \
# This is really configure+build in one step. b depends on c.
build-stamp: GYP_ENV = GYP_GENERATORS=ninja
build-stamp: GYP_ENV += GYP_DEFINES="$(GYP_DEFINES) $(BROWSER_GYP_DEFINES)"
build-stamp: debian/chromium-browser.sh
	@set -eux
	test ! -e $(SRC_DIR)/out/$(BUILD_TYPE)
	# Upstream changes often. Fail when they introduce a config flag we don't know about.
	-diff --ignore-case --suppress-common-lines --unified=0 debian/known_gyp_flags <(sed -e "/: *'<(/{ s,.*'<(,,g; s,).*,,; p; }" -e d build/common.gypi | LC_ALL=C sort -u |grep -v '^\(win_\|mac_\|android_\|.san\|..san\|msvs_\|ios_\|goma_\|windows_\|wix_\|directx_\)') || echo This seems bad.
	cd $(SRC_DIR) && $(GYP_ENV) $(CROSS_BUILD) build/gyp_chromium build/all.gyp $(GYP_PARAMS)
	### build
	while sleep 1200; do echo "#  I ATEN'T DEAD"; done& $(BUILD_DEFINES) $(NINJA) $(BUILD_ARGS) $(BUILD_TARGETS) && { kill \%1; sleep 1; echo; true; } || { kill \%1; exit 1; sleep 2; echo; false; }
	mv $(SRC_DIR)/out/$(BUILD_TYPE) $(SRC_DIR)/out/$(BUILD_TYPE)-chromium
	touch $@
build-stamp-ffmpeg-%: GYP_DEFINES += $(FFMPEG_EXTRA_GYP_DEFINES) $(FFMPEG_GYP_DEFINES)
build-stamp-ffmpeg-%: GYP_ENV = GYP_GENERATORS=ninja
build-stamp-ffmpeg-%: GYP_ENV += GYP_DEFINES="$(GYP_DEFINES)"
build-stamp-ffmpeg-%: TARGET := lib/libffmpeg.so
	@set -eux
	### configure
	### build
	$(NINJA) $(BUILD_ARGS) $(TARGET)
	mkdir -p debian/tmp-$*/$(LIB_DIR)
	mv -v $(SRC_DIR)/out/$(BUILD_TYPE) $(SRC_DIR)/out/$(BUILD_TYPE)-ffmpeg-$*
	touch $@
# These are (leading-slash-less) files that are created by upstream builder,
# but intentionally not packaged.  The should match very specifically so we
# know they only match things we should ignore. No false negatives, plz.
# When composing a match, it has to be escaped for nonquoted shell expression
# first, then escaped for Make. No expression can contain a space, as it's
# used later to join expressions in alternation; a dot should suffice.
# Useful: https://code.google.com/p/chromium/codesearch#search/q=package:chromium
## webkit tests
#BUILT_UNUSED_MATCH  = ^usr/lib/chromium-browser/AHEM____.TTF$$
#BUILT_UNUSED_MATCH += ^usr/lib/chromium-browser/fonts.conf$$
#BUILT_UNUSED_MATCH += ^usr/lib/chromium-browser/libTestNetscapePlugIn.so$$
#BUILT_UNUSED_MATCH += ^usr/lib/chromium-browser/plugins/libTestNetscapePlugIn.so$$
#BUILT_UNUSED_MATCH += ^usr/lib/chromium-browser/ImageDiff$$
## xdg-utils install dep
#BUILT_UNUSED_MATCH += ^usr/lib/chromium-browser/xdg-settings$$
BUILT_UNUSED_MATCH += ^usr/lib/chromium-browser/xdg-mime$$
INDEP_MATCH = ^usr/lib/chromium-browser/.\*\(?\!\<pseudo-\)locales/.\*.pak$$
PACKAGED_NOT_FROM_TREE_MATCH  = ^usr/share/applications/chromium-browser.desktop$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/apport/package-hooks/chromium-browser.py$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/doc/chromium-browser/README.source$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/doc/chromium-browser/TODO.Debian$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/doc/chromium-browser/copyright.problems.gz$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/doc/.\*/buildinfo_.\*.gz$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/gnome-control-center/default-apps/chromium-browser.xml$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/.\*/chromium-browser.png$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/.\*/chromium-browser.svg$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/doc/.\*/copyright$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/share/doc/.\*/changelog.Debian.gz$$
PACKAGED_NOT_FROM_TREE_MATCH += ^usr/bin/chromium-browser$$
PACKAGED_NOT_FROM_TREE_MATCH += ^etc/chromium-browser/default$$
PACKAGED_NOT_FROM_TREE_MATCH += ^etc/chromium-browser/customizations/00-example$$
# Expressions to map filenames in the comparison logic so that a rename in
# packaging is correctly handled.  No expression contains a space.  Each should
# be able to be used as a SED expression.  This changes file names in
# pre-packaging listing. All of this is done AFTER removing items
# BUILD_UNUSED_MATCH .  Quote for regexp, then shell, then Make.
#  Man pages are moved, renamed, compressed.
RENAMED_FILE  = s,^usr/lib/chromium-browser/chrome.1\$$,usr/share/man/man1/chromium-browser.1.gz,
#  Sandbox name is wrong. Upstream builder deficiency.
RENAMED_FILE += s,^usr/lib/chromium-browser/chrome_sandbox$$,usr/lib/chromium-browser/chrome-sandbox,
#  Executable name is different.
RENAMED_FILE += s,^usr/lib/chromium-browser/chrome$$,usr/lib/chromium-browser/chromium-browser,
compare-indep: INDEP_MATCH = ^usr/lib/chromium-browser/.\*\(?\!\<pseudo-\)locales/.\*.pak$$
compare-indep: SPACE := $(eval) $(eval)
compare-indep:
	@set -eux; \
	T=$$(mktemp -d -t chromium-comparisons-XXXXXXX); \
	test "$${T}"; \
	test -d $${T}; \
	find debian/tmp debian/tmp-extra -type f |cut -d/ -f3- >$${T}/unfiltered-built; \
	grep -E \($(subst $(SPACE),\|,$(INDEP_MATCH))\) $${T}/unfiltered-built $(foreach expr,$(RENAMED_FILE), |sed -r -e $(expr))  |grep -v /en-US.pak | LC_ALL=C sort >$${T}/built; \
	dh_listpackages -i |while read pkgname; do find debian/$${pkgname} -type f; done |grep -v /DEBIAN |cut -d/ -f3- |grep -v ^usr/lib/debug/ | LC_ALL=C sort >$${T}/unfiltered-packaged; \
	grep -E \($(subst $(SPACE),\|,$(INDEP_MATCH))\) $${T}/unfiltered-packaged |grep -v /en-US.pak >$${T}/packaged || true; \
	if ! diff -U0 $${T}/built $${T}/packaged; then  \
	  echo " => Found indep differences, please investigate. $${T}/built $${T}/packaged" ; \
	  exit 1; \
	fi; \
	rm -r $${T}
compare-arch: INDEP_MATCH = ^usr/lib/chromium-browser/.\*\locales/.\*.pak$$
compare-arch: PKG_DIRS := $(addprefix debian/,$(shell dh_listpackages -a))
compare-arch: SPACE := $(eval) $(eval)
compare-arch:
	@set -eux; \
	T=$$(mktemp -d -t chromium-comparisons-XXXXXXX);\
	test "$${T}"; \
	test -d $${T};\
	DUPES=`find $(PKG_DIRS) -type f -print | grep -v /DEBIAN/ | cut -d/ -f3- | LC_ALL=C sort | uniq -c | grep -vE '^ *2 .*/libs/libffmpeg.so$$' | grep -vE '^  *1 '` || true; \
	if [ "Z$$DUPES" != Z ] ; then \
	  echo " => Found duplicates:\n $$DUPES" ; \
	  exit 1 ; \
	fi; \
	find debian/tmp debian/tmp-extra debian/tmp-std -type f |cut -d/ -f3- >$${T}/unfiltered-built ;\
	grep -vE \($(subst $(SPACE),\|,$(BUILT_UNUSED_MATCH))\) $${T}/unfiltered-built $(foreach expr,$(RENAMED_FILE), |sed -r -e $(expr)) |grep -vE \($(subst $(SPACE),\|,$(INDEP_MATCH))\) | LC_ALL=C sort >$${T}/built ;\
	find $(PKG_DIRS) -type f |grep -v /DEBIAN |cut -d/ -f3- |grep -v ^usr/lib/debug/ | LC_ALL=C sort >$${T}/unfiltered-packaged ;\
	grep -vE \($(subst $(SPACE),\|,$(PACKAGED_NOT_FROM_TREE_MATCH))\) $${T}/unfiltered-packaged |grep -vE \($(subst $(SPACE),\|,$(INDEP_MATCH))\) >$${T}/packaged ;\
	  echo " => Found archdep differences, please investigate. $${T}/built $${T}/packaged" ; \
	  exit 1; \
	fi; \
	for expr in $(BUILT_UNUSED_MATCH); do if ! grep -E $$expr $${T}/unfiltered-built >/dev/null; then echo "Warning: Unused built matcher: $$expr in $${T}/unfiltered-built "; fi; done; \
	for expr in $(PACKAGED_NOT_FROM_TREE_MATCH); do if ! grep -E $$expr $${T}/unfiltered-packaged >/dev/null; then echo "Warning: Unused packaged matcher: $$expr"; fi; done; \
	rm -r $${T};
# Translations
# New langs with enough coverage to land in official builds
# (leave empty to accept all new lang)
patch-translations: GRIT_WHITELISTED_LANGS ?= ca@valencia eu gl ug gd
patch-translations: TRANSLATIONS_TOOLS_BRANCH  := http://bazaar.launchpad.net/~chromium-team/chromium-browser/chromium-translations-tools.head
patch-translations: TRANSLATIONS_EXPORT_BRANCH := http://bazaar.launchpad.net/~chromium-team/chromium-browser/chromium-translations-exports.head
patch-translations: GRIT_TEMPLATES := chrome/app/chromium_strings.grd chrome/app/generated_resources.grd components/policy/resources/policy_templates.grd ui/strings/ui_strings.grd webkit/glue/resources/webkit_resources.grd
patch-translations: OTHER_GRIT_TEMPLATES := ui/strings/app_locale_settings.grd chrome/app/resources/locale_settings.grd chrome/app/resources/locale_settings_linux.grd
patch-translations: MAPPED_GRIT_TEMPLATES := --map-template-names ui/strings/ui_strings.grd=ui/strings/app_strings.grd
patch-translations: GRIT_CONVERTER_FLAGS := --create-patches translations-patches --import-gettext ../translations-export --export-grit $${T}/translations-grit --build-gyp-file build/common.gypi --other-grd-files $$(echo $(OTHER_GRIT_TEMPLATES) | tr ' ' ',') $(MAPPED_GRIT_TEMPLATES)
ifeq (1,$(WANT_ONLY_WHITELISTED_NEW_LANGS))
patch-translations: GRIT_CONVERTER_FLAGS += --whitelisted-new-langs $$(echo $(GRIT_WHITELISTED_LANGS) | tr ' ' ',')
endif
patch-translations: PATCH_FILE := launchpad_translations.patch
patch-translations:
	@set -eux
	ls $(GRIT_TEMPLATES)
	ls $(OTHER_GRIT_TEMPLATES)
	T=$$(mktemp --directory --tmpdir=.. -t chromium-launchpad-translations-XXXXXXX)
	test "$${T}"
	test -d $${T}
	test -d $${T}/translations-tools || bzr export $${T}/translations-tools $(TRANSLATIONS_TOOLS_BRANCH)
	test -d $${T}/translations-export || bzr export $${T}/translations-export $(TRANSLATIONS_EXPORT_BRANCH)
	( cd $(DEB_TAR_SRCDIR); $${T}/translations-tools/chromium2pot.py $(GRIT_CONVERTER_FLAGS) $$(ls $(GRIT_TEMPLATES)); )
	quilt delete "$(PATCH_FILE)" || true
	quilt new "$(PATCH_FILE)"
	( cd $${T}/translations-grit && find * -type f ) |while read updatedfile; do \
		quilt add -P "$(PATCH_FILE)" $(DEB_TAR_SRCDIR)/"$$updatedfile"; \
		cp $${T}/translations-grit/"$$updatedfile" $(DEB_TAR_SRCDIR)/"$$updatedfile"; \
	done
	{ echo "Description: Contributed translations from Launchpad. "; echo; } |quilt header -r "$(PATCH_FILE)"
	quilt refresh -pab --no-timestamps "$(PATCH_FILE)";
	echo "Patch needs committing."
.PHONY: binary binary-arch binary-indep build build-arch build-indep clean install install-arch install-indep patch get-packaged-orig-source gos override_dh_* local-install-* patch-translations compare-*
# needed for easy job control, e.g, kill %1
SHELL := /bin/bash
# This changes state for ALL rules in the makefile.
.ONESHELL:
.DEFAULT: build-stamp build-stamp-ffmpeg-extra
Then run
dpkg-buildpackage
In the chromium folder
I may have missed something.
Tue Oct 27, 2015 8:58 pm
If you're running on a 2B you can use /usr/bin/make -j 6 -f in your shebang line (number of cores plus 2) to run your make in parallel.
Also why aren't you building Chrome 46?
kusti8
Tue Oct 27, 2015 9:01 pm
DougieLawson wrote:If you're running on a 2B you can use /usr/bin/make -j 6 -f in your shebang line (number of cores plus 2) to run your make in parallel.
It is running in parallel on default.
The reason I'm not building 46, is because as far as I can see there is no Ubuntu package for it. It's much easier since the Ubuntu package already has all of the patches.
Tue Oct 27, 2015 9:27 pm
Have you set any overclocking options using sudo raspi-config? You may get reduced wall-clock elapsed time by doing that.
kusti8
Tue Oct 27, 2015 9:28 pm
DougieLawson wrote:Have you set any overclocking options using sudo raspi-config? You may get reduced wall-clock elapsed time by doing that.
No, I haven't though of that, but I've already started the second build, so it's a little too late.
Tue Oct 27, 2015 9:48 pm
Cancel it. After your reboot for overclocking it should restart from where it leaves off (unless you're doing it in /tmp).
kusti8
Tue Oct 27, 2015 9:50 pm
DougieLawson wrote:Cancel it. After your reboot for overclocking it should restart from where it leaves off (unless you're doing it in /tmp).
Thing is I think dpkg-buildpackage cleans before starting again, but it hasn't got that far, so I think I'm going to try it.
fsa317
Wed Oct 28, 2015 2:53 pm
Hi, after following the steps, when I try to run Chromium i get "Illegal Instruction".
Here's what I saw during the install:
pi@magicmirror ~/chrome $ sudo dpkg -i chromium-browser-l10n_45.0.2454.85-0ubuntu0.15.04.1.1181_all.deb chromium-browser_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb
Selecting previously unselected package chromium-browser-l10n.
(Reading database ... 118204 files and directories currently installed.)
Preparing to unpack chromium-browser-l10n_45.0.2454.85-0ubuntu0.15.04.1.1181_all.deb ...
Unpacking chromium-browser-l10n (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Preparing to unpack chromium-browser_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb ...
Unpacking chromium-browser (45.0.2454.85-0ubuntu0.15.04.1.1181) over (45.0.2454.85-0ubuntu0.14.04.1.1097) ...
Setting up chromium-browser (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Setting up chromium-browser-l10n (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Processing triggers for gnome-menus (3.13.3-6) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for man-db (2.7.0.2-5) ...
pi@magicmirror ~/chrome $ uname -a
Linux magicmirror 4.1.7+ #817 PREEMPT Sat Sep 19 15:25:36 BST 2015 armv6l GNU/Linux
Any ideas?
ShiftPlusOne
Wed Oct 28, 2015 3:09 pm
fsa317 wrote:Hi, after following the steps, when I try to run Chromium i get "Illegal Instruction".
Any ideas?
pi 1 rather than pi 2?
Wed Oct 28, 2015 3:10 pm
Any ideas?
What model of Raspberry Pi seems like a B+, this version of Chromium is ONLY for the RPi 2B ARMv7
Written in the first post
THIS IS THE ONLY WAY TO GET CHROMIUM ON JESSIE!
THIS WILL ONLY WORK ON A Pi2!
fsa317
Wed Oct 28, 2015 7:25 pm
Yea, its a B+ (1) running on Jessie. Is there a way to get any version of chromium working on a B+ w/ Jessie?
kusti8
Wed Oct 28, 2015 7:27 pm
fsa317 wrote:Yea, its a B+ (1) running on Jessie. Is there a way to get any version of chromium working on a B+ w/ Jessie?
You may be able to use the older one in the Wheezy repo, but that's v22. For now, if you have a Pi1, just stick with Wheezy if you need Chromium.
KevinA
Wed Oct 28, 2015 7:54 pm
THANKS !
Without Chrome to sync my bookmarks and favorites I'm lost.
I truly hope they get it out and add chromium to the repository, soon..
kusti8
Wed Oct 28, 2015 7:57 pm
KevinA wrote:THANKS !
They won't ads this version to the repo because it only works on Pi2 (ARMv7) and Raspbian is designed to work on both versions. The problem is that any version past I think v27 won't work on a Pi1 (armv6). OSs made for ARMv7 like Ubuntu where this is from have it in their repo, but unless the Foundation makes a Pi2 repo only this won't be in the repo. But these steps aren't too complicated.
fsa317
Wed Oct 28, 2015 8:16 pm
I'm trying to use websockets (ws://) protocol - I'm trying to see if this is supported in v22 of chromium? Any idea how I could do this before reinstalling with Wheezy.
Wed Oct 28, 2015 8:17 pm
Yes Kusti8 Chromium 28 went to blink browser engine hence why development against ARMv6 stopped.
Debian themselves do not offer Chromium Browser for ARMv7 ARMHF.
kusti8
Wed Oct 28, 2015 8:46 pm
I just did a Google which suggested it was added in v4, so it should work in v22.
kusti8
Wed Nov 04, 2015 12:07 am
It's compiled. :D
Now if I have some time tomorrow (which I should) I'll be able to test it. This build is with NEON support and hopefully GPU support.
kusti8
Thu Nov 05, 2015 1:58 pm
kusti8 wrote:It's compiled. :D
There is no improvement and no GPU support. I'm giving up now, I have other things to do, and Chromium works fine as it is.
yvinay10
Tue Nov 17, 2015 1:15 pm
I get the obsolete error always. Any plausible solution?
kusti8
Tue Nov 17, 2015 8:32 pm
yvinay10 wrote:I get the obsolete error always. Any plausible solution?
Can you please be more specific? What error specifically does it say? This is on a Pi2?
yvinay10
Thu Nov 19, 2015 10:38 am
pi@black ~ $ sudo apt-get install chromium-browser
Reading package lists... Done
Building dependency tree
Package chromium-browser is not available, but is referred to by another package.
E: Package 'chromium-browser' has no installation candidate
This one. On RasPi 2
Thu Nov 19, 2015 10:45 am
yvinay10 wrote:pi@black ~ $ sudo apt-get install chromium-browser
Please read how to manually install Chromium 45 for Raspbian Jessie on a RPi 2B, it is the first post in this thread:
viewtopic.php?f=63&t=121195&start=0
kusti8
Thu Nov 19, 2015 12:06 pm
As FoTL said, but just to explain a little, Jessie removed Chromium, so currently the only way to get it is with my guide, which is the first post in this thread.
