drekthrall
permanently running PWM
Mon Oct 26, 2015 4:47 pm
my simple python code :
#!/usr/bin/env python
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(25, GPIO.OUT)
p = GPIO.PWM(25,200)
p.start(50)
If I execute this script 25GPIO will turn on (on 50%) and immediately turn off. My LED just once blinked.
If I execute script like this :
GPIO.output(25, True)
The LED will be turned on "forever".
My question is how to run PWM "forever" without any loops like while ... ? Thanks for any response !
mahjongg
Re: permanently running PWM
Mon Oct 26, 2015 5:41 pm
You just turn PWM on, and it will run "forever" until you give a new PWM control, that turns it off.
B.Goode
Mon Oct 26, 2015 5:44 pm
mahjongg wrote:You just tun PWM on, and it will run "forever" until you give a new PWM control, that turns it off.
What happens when the controlling Python script terminates? Is that the end of 'forever'?
drekthrall
Mon Oct 26, 2015 5:58 pm
That is not working for me , i need to add time.sleep(x) to let PWM running for x seconds , after time.sleep ends PWM ends too :/
Mon Oct 26, 2015 6:08 pm
The software PWM is controlled by the python RPi.GPIOlibrary. As soon as your program terminates it will stop working. You can't do anything about that.
The hardware PWM would keep running independently of any program, but there is only one of those normally available.
drekthrall
Mon Oct 26, 2015 7:02 pm
rpdom wrote:The software PWM is controlled by the python RPi.GPIOlibrary. As soon as your program terminates it will stop working. You can't do anything about that.
Thanks ! That was very helpful for me ! Thanks for help :)
drekthrall
Mon Oct 26, 2015 7:07 pm
One more question please :D ... Is there any Raspberry pi ( 2 A,B ,B+ , ...) that has 2 (or more) HW PWM ? If no, is there any HW PWM module ?
joan
Mon Oct 26, 2015 7:55 pm
pigpio will let you use the two hardware PWM channels available on the A+/B+/Pi2/compute module. It well also let you run hardware timed PWM on the other GPIOs even when the Python script is terminated (as long as the pigpio daemon is left running).
drekthrall
Mon Oct 26, 2015 9:38 pm
joan wrote:pigpio will let you use the two hardware PWM channels available on the A+/B+/Pi2/compute module. It well also let you run hardware timed PWM on the other GPIOs even when the Python script is terminated (as long as the pigpio daemon is left running).
Thanks !
Only for sure Raspberry Pi 2 B has two hardware PWMs ?
joan
Mon Oct 26, 2015 9:42 pm
drekthrall wrote: ...
http://abyz.co.uk/rpi/pigpio/python.html#hardware_PWM
