eben
An nbench challenge
Fri Jul 27, 2012 6:18 am
I'm going to put together a blog post fairly soon comparing our performance with various other single-board computers. On the CPU side, I'm intending to use nbench, as results for other systems are widely available. I don't want to sell Raspberry Pi short, so I'm appealing for help to find the build options and compiler choice which yield the best results using the Raspbian wheezy image.
I'm primarily interested in two configurations: stock (arm_freq=700, core_freq=250, sdram_freq=400) and maximum (arm_freq=1000, core_freq=500, sdram_freq=400), but it would also be interesting to see the effect of setting sdram_freq=500. If you're not prepared to overvolt your board, you may wish to only submit results for the "stock" configuration. As a starting point, you can find Jesse's Arch Linux results here.
As an incentive, I'm offering a shiny pibow to the fastest reproducible result for the "stock" configuration.
antiloquax
Re: An nbench challenge
Fri Jul 27, 2012 7:21 am
Hi Eben,
I haven't used nbench before - I will have a go later.
In the meantime, I thought I'd share the results of a simple benchmarking I did, comparing the Squeezed Puppy release with Arch in a couple of configurations.
I ran this command to do a very simple benchmark.
(from a console, not within X)
time echo "scale=2000;4*a(1) | bc -l
With the over-voltage overclock (over_voltage=6, arm_freq=1000, core_freq=500, sdram_freq=500, the "real" time was:
15.774 secs.
With the "safe" overclock, (arm - 850, sdram - 500, gpu - 250), I got:
22.339s
With no overclocking:
22.464s
As a quick comparison, I ran the test on my Arch installation (this is using the same "safe" overclock) and got:
20.489s
glxgears test
Puppy
"Safe" overclock: best reading was 19.170 fps
No overclock: 19.077 fps
Over-voltage: 26.994 fps
Over-voltage with swapon - 29.103
Arch result (This was in the "safe" overclock settings, with swapon):
31.844 fps
eppe
Fri Jul 27, 2012 9:18 am
Let's start with this as a base, here are my raspbian results.
TEST                : Iterations/sec.  : Old Index   : New Index
                    :                  : Pentium 90* : AMD K6/233*
NUMERIC SORT        :           200.4  :       5.14  :       1.69
STRING SORT         :          31.472  :      14.06  :       2.18
BITFIELD            :      8.8785e+07  :      15.23  :       3.18
FP EMULATION        :          45.509  :      21.84  :       5.04
FOURIER             :          2056.4  :       2.34  :       1.31
ASSIGNMENT          :          2.3939  :       9.11  :       2.36
IDEA                :          669.29  :      10.24  :       3.04
HUFFMAN             :          414.53  :      11.49  :       3.67
NEURAL NET          :          3.1213  :       5.01  :       2.11
LU DECOMPOSITION    :           72.68  :       3.77  :       2.72
==========================ORIGINAL BYTEMARK RESULTS==========================
INTEGER INDEX       : 11.448
FLOATING-POINT INDEX: 3.534
Baseline (MSDOS*)   : Pentium* 90, 256 KB L2-cache, Watcom* compiler 10.0
==============================LINUX DATA BELOW===============================
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
C compiler          : gcc-4.7.real
libc                : libc-2.13.so
MEMORY INDEX        : 2.539
INTEGER INDEX       : 3.121
FLOATING-POINT INDEX: 1.960
Baseline (LINUX)    : AMD K6/233*, 512 KB L2-cache, gcc 2.7.2.3, libc-5.4.38
antiloquax
Fri Jul 27, 2012 9:35 am
Here's my results for the stock settings on Raspbian:
nbench_stock_rasbian
This is with over-clocking to 1000. Sdram speed was 400 (RPi would not boot when set to 500).
nbench_1ghz
antiloquax
Fri Jul 27, 2012 10:34 am
Here's the results when sdram increased to 450
1ghz_sdram_450
antiloquax
Fri Jul 27, 2012 11:05 am
Oh, I tried again at 500 for sdram and it booted. Here's the output.
sdram_500
eben
Fri Jul 27, 2012 2:23 pm
Can you share the compiler flags you used to get these results, and maybe the resulting binaries? Some initial thoughts:
  • gcc 4.7 seems to make a significant difference versus 4.6
  • We do well versus Cortex A8 on floating point, less well on memory and integer
PIstolero
Location: paradise city, where the grass is green and the girls are pretty
Fri Jul 27, 2012 3:30 pm
Still waiting for my Pi so I' ve done the benchmark in Qemu (ARM emulator) on a Notebook with Core2duo T5600, 4GB, Opensuse 12.1 64bit and Qemu 1.1.1 compiled from sources booting the Raspian image. The virtual Raspian has 192MB RAM.
Good to know that my real RPI will be a lot faster :)
BYTEmark* Native Mode Benchmark ver. 2 (10/95)
Index-split by Andrew D. Balsa (11/97)
Linux/Unix* port by Uwe F. Mayer (12/96,11/97)
NUMERIC SORT        :          122.36  :       3.14  :       1.03
STRING SORT         :          13.466  :       6.02  :       0.93
BITFIELD            :      4.4703e+07  :       7.67  :       1.60
FP EMULATION        :           21.81  :      10.47  :       2.41
FOURIER             :          422.14  :       0.48  :       0.27
ASSIGNMENT          :          2.5424  :       9.67  :       2.51
IDEA                :
** WARNING: The current test result is NOT 95 % statistically certain.
** WARNING: The variation among the individual results is too large.
                    :          192.04  :       2.94  :       0.87
HUFFMAN             :
                    :          230.33  :       6.39  :       2.04
NEURAL NET          :
                    :         0.45295  :       0.73  :       0.31
LU DECOMPOSITION    :
                    :          15.395  :       0.80  :       0.58
INTEGER INDEX       : 5.985
FLOATING-POINT INDEX: 0.653
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
C compiler          : gcc version 4.6.3 (Debian 4.6.3-8+rpi1)
libc                : libc-2.13.so
MEMORY INDEX        : 1.553
INTEGER INDEX       : 1.451
FLOATING-POINT INDEX: 0.362
* Trademarks are property of their respective holder.
antiloquax
Fri Jul 27, 2012 4:10 pm
eben wrote:Can you share the compiler flags you used to get these results, and maybe the resulting binaries? Some initial thoughts:
Okay, I just ran with the gcc that came with my downloaded raspbian (4.6.3).
I didn't pass any flags, just ran "make".
I am happy to run some tests again, if you can give me idiot-proof instructions :oops:
I am now doing an apt-get install gcc-4.7 :mrgreen:
gritz
Fri Jul 27, 2012 5:47 pm
I don't wish to toss a spanner in the works here, but haven't sufficient Pi already been purchased by people who have misunderstood it's purpose - i.e. it's a low cost computer to facilitate education in schools, not a firebreathing multicore desktop replacement?
Surely posting benchmarks on steroids might be counterproductive, especially regarding the "I never bother to RTFM" crowd. By all means benchmark it in a series of real-world situations, but I feel that wringing the snot out of it (and possibly invalidating the warranty) is totally missing the point.
eben
Fri Jul 27, 2012 5:54 pm
Maybe worth adding
-mcpu=arm1176jzf-s -mtune=arm1176jzf-s
to the CFLAGS in the Makefile, and trying -O2 and -Os instead of -O3.
In case you hadn't guessed, I'm travelling without a Raspberry Pi, otherwise I'd be playing with this myself as well :)
eben
Fri Jul 27, 2012 5:57 pm
gritz wrote:Surely posting benchmarks on steroids might be counterproductive, especially regarding the "I never bother to RTFM" crowd. By all means benchmark it in a series of real-world situations, but I feel that wringing the snot out of it (and possibly invalidating the warranty) is totally missing the point.
The aim is to bring some data to bear on some of the claims being made by vendors of other low-cost computing devices (particularly the various ~$70 Android stick computers). There's a lazy assumption that a Cortex-class processor will automatically wipe the floor with an ARM11, which isn't really borne out either by benchmarks or real-world performance measurements.
You might conclude from my interest in performance at 1GHz, and from the fact that we've posted videos showing our overclocked performance, that we are currently investigating the possibility of running the chip at that speed without invalidating the warranty.
antiloquax
Fri Jul 27, 2012 6:21 pm
gritz wrote: ... I feel that wringing the snot out of it (and possibly invalidating the warranty) is totally missing the point.
But it's fun ...
@Eben - yes, I've just been having a look at the -O3 flag and wondering about -Ofast?
I'll try the options you mentioned.
mark
khh
Fri Jul 27, 2012 8:17 pm
I've tried the two suggested modes, all with stock settings all build with gcc-4.7
CFLAGS = -s -static -Wall -O3 -fomit-frame-pointer -mcpu=arm1176jzf-s -mtune=arm1176jzf-s
CFLAGS = -s -static -Wall -O2 -Os -fomit-frame-pointer -mcpu=arm1176jzf-s -mtune=arm1176jzf-s
-O3 does better across the board.
edit: Tried -Ofast as well. Pretty close to -O3, better in some worse in some.
CFLAGS = -s -static -Wall -Ofast -fomit-frame-pointer -mcpu=arm1176jzf-s -mtune=arm1176jzf-s
eppe
Fri Jul 27, 2012 8:55 pm
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
libc                : libc-2.13.so
Raspbian in single user mode, every possible daemon not running, compiled with gcc4.7
CFLAGS = -s -static -Wall -Ofast -funroll-loops -fomit-frame-pointer -march=armv6 -mfpu=vfp -mfloat-abi=hard
eben
Fri Jul 27, 2012 9:38 pm
@eppe - are you sure those numbers are right? They seem identical to your baseline at the top of the page.
antiloquax
Fri Jul 27, 2012 10:18 pm
I've had a go with the arm1176jzf-s flags and -O2 (GCC 4.7)
Looks like I should run it with O3 as well, as per khh points above. I'll run that tomorrow!
arm flags and -O2
portets
Sat Jul 28, 2012 4:40 am
My test results(without booting into X):
NUMERIC SORT        :          312.96  :       5.14  :       1.69
STRING SORT         :          44.147  :      14.06  :       2.18
BITFIELD            :      9.8046e+07  :      15.23  :       3.18
FP EMULATION        :          61.606  :      21.84  :       5.04
FOURIER             :          3250.4  :       2.34  :       1.31
ASSIGNMENT          :          4.1339  :       9.11  :       2.36
IDEA                :          924.83  :      10.24  :       3.04
HUFFMAN             :          569.97  :      11.49  :       3.67
NEURAL NET          :          4.5010  :       5.01  :       2.11
LU DECOMPOSITION    :          123.28  :       3.77  :       2.72
INTEGER INDEX       : 16.073
FLOATING-POINT INDEX: 9.552
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
libc                : libc-2.13.so
MEMORY INDEX        : 3.524
INTEGER INDEX       : 4.420
FLOATING-POINT INDEX: 3.079
compiled with gcc-4.7 and:
CFLAGS = -s -static -Wall -O3 -fomit-frame-pointer -funroll-loops -Wno-write-strings -Wno-sign-compare -mfloat-abi=hard -mfpu=vfp -mcpu=arm1176jzf-s -mtune=arm1176jzf-s -march=armv6zk
clocks were:
arm_freq=950
sdram_freq=500
core_freq=500
with no overvolt.
ukscone
Sat Jul 28, 2012 7:31 am
best i can get so far (after 2 hours of twiddling) on stock raspi e.g. no overclocking
pi@welham ~/nbench-byte-2.2.3 $ ./nbench
NUMERIC SORT        :          219.84  :       5.64  :       1.85
STRING SORT         :          32.083  :      14.34  :       2.22
BITFIELD            :      7.3163e+07  :      12.55  :       2.62
FP EMULATION        :          44.582  :      21.39  :       4.94
FOURIER             :          2299.2  :       2.61  :       1.47
ASSIGNMENT          :          2.6495  :      10.08  :       2.61
IDEA                :          686.54  :      10.50  :       3.12
HUFFMAN             :           417.5  :      11.58  :       3.70
NEURAL NET          :           3.202  :       5.14  :       2.16
LU DECOMPOSITION    :           80.64  :       4.18  :       3.02
INTEGER INDEX       : 11.500
FLOATING-POINT INDEX: 3.830
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
libc                : libc-2.13.so
MEMORY INDEX        : 2.478
INTEGER INDEX       : 3.204
FLOATING-POINT INDEX: 2.124
ukscone
Sat Jul 28, 2012 7:49 am
correction. these are my current best results (two runs)
NUMERIC SORT        :           221.2  :       5.67  :       1.86
STRING SORT         :          32.002  :      14.30  :       2.21
BITFIELD            :      7.2979e+07  :      12.52  :       2.61
FP EMULATION        :          44.427  :      21.32  :       4.92
FOURIER             :          2292.8  :       2.61  :       1.46
ASSIGNMENT          :          2.6616  :      10.13  :       2.63
IDEA                :          686.55  :      10.50  :       3.12
HUFFMAN             :          417.33  :      11.57  :       3.70
NEURAL NET          :          3.2018  :       5.14  :       2.16
LU DECOMPOSITION    :           81.04  :       4.20  :       3.03
INTEGER INDEX       : 11.503
FLOATING-POINT INDEX: 3.833
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
libc                : libc-2.13.so
MEMORY INDEX        : 2.477
INTEGER INDEX       : 3.206
FLOATING-POINT INDEX: 2.126
NUMERIC SORT        :           221.8  :       5.69  :       1.87
STRING SORT         :           32.03  :      14.31  :       2.22
BITFIELD            :      7.3253e+07  :      12.57  :       2.62
FP EMULATION        :          44.476  :      21.34  :       4.92
FOURIER             :            2301  :       2.62  :       1.47
ASSIGNMENT          :          2.6596  :      10.12  :       2.62
HUFFMAN             :          417.66  :      11.58  :       3.70
NEURAL NET          :          3.2015  :       5.14  :       2.16
LU DECOMPOSITION    :          80.296  :       4.16  :       3.00
INTEGER INDEX       : 11.516
FLOATING-POINT INDEX: 3.825
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
libc                : libc-2.13.so
MEMORY INDEX        : 2.480
INTEGER INDEX       : 3.209
FLOATING-POINT INDEX: 2.122
antiloquax
Sat Jul 28, 2012 8:43 am
portets wrote:My test results(without booting into X):
clocks were:
arm_freq=950
sdram_freq=500
core_freq=500
with no overvolt.
Impressive.
jojopi
Sat Jul 28, 2012 9:09 am
Nobody yet appears to have matched the stock-clocked results that Dom reported on the first Raspbian boots in April: http://pastebin.com/2NZqH2yY
You can not use -Ofast for benchmarks, without a proof that it does not change their computation results. The option violates the relevant standards in ways that can break valid programs, which is why it is not on by default. You might as well prelink a library that lies about how much time is elapsing, or use a compiler that detects benchmarks and converts them to no-ops.
I see very little effect from the various optimizations that are not already implied by -O3, and many of them improve some tests and worsen others. So why not keep it simple and pay attention to bigger factors instead:
fbset -g 704 400 704 400 16
echo on |sudo tee /proc/dwc_sof/SOF_reduction
make CC="gcc-4.7" CFLAGS="-s -static -O3 -funroll-loops" clean nbench
./nbench
NUMERIC SORT        :           226.2  :       5.80  :       1.91
STRING SORT         :           33.28  :      14.87  :       2.30
BITFIELD            :      9.3479e+07  :      16.03  :       3.35
FP EMULATION        :          48.222  :      23.14  :       5.34
FOURIER             :          2373.8  :       2.70  :       1.52
ASSIGNMENT          :          2.9115  :      11.08  :       2.87
IDEA                :          701.95  :      10.74  :       3.19
HUFFMAN             :           437.9  :      12.14  :       3.88
NEURAL NET          :          3.7924  :       6.09  :       2.56
LU DECOMPOSITION    :           82.12  :       4.25  :       3.07
INTEGER INDEX       : 12.445
FLOATING-POINT INDEX: 4.121
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9+
libc                : libc-2.13.so
MEMORY INDEX        : 2.809
INTEGER INDEX       : 3.349
FLOATING-POINT INDEX: 2.285
Incidentally, the best I could manage on a Pentium II 300 is below. On this basis, you could revise your PC comparison up quite a bit.
NUMERIC SORT        :          114.87  :       2.95  :       0.97
STRING SORT         :          9.5392  :       4.26  :       0.66
BITFIELD            :      5.0838e+07  :       8.72  :       1.82
FP EMULATION        :          17.152  :       8.23  :       1.90
FOURIER             :          3209.7  :       3.65  :       2.05
ASSIGNMENT          :          2.9528  :      11.24  :       2.91
IDEA                :          508.01  :       7.77  :       2.31
HUFFMAN             :          239.62  :       6.64  :       2.12
NEURAL NET          :          3.7654  :       6.05  :       2.54
LU DECOMPOSITION    :          111.84  :       5.79  :       4.18
INTEGER INDEX       : 6.560
FLOATING-POINT INDEX: 5.039
CPU                 : GenuineIntel Pentium II (Klamath) 300MHz
L2 Cache            : 512 KB
OS                  : Linux 3.1.0-7.fc16.i686
C compiler          : gcc version 4.6.3 20120306 (Red Hat 4.6.3-2) (GCC)
libc                : libc-2.14.90.so
MEMORY INDEX        : 1.519
INTEGER INDEX       : 1.732
FLOATING-POINT INDEX: 2.795
AndrewS
Sat Jul 28, 2012 11:22 am
eben wrote:In case you hadn't guessed, I'm travelling without a Raspberry Pi
Sacrilege! I'd assumed you'd have one surgically implanted by now... :lol:
Sat Jul 28, 2012 11:31 am
[I'm not entering the challenge. Feel free to use any information here to help]
I'm using the two numbers following:
(not quite sure what the difference between these and the lower numbers below are, but they all seem to scale up and down as expected)
On stock frequency. Using:
CFLAGS = -s -static -Wall -O3 -fomit-frame-pointer -funroll-loops -mcpu=arm1176jzf-s -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard
INTEGER INDEX : 11.059
FLOATING-POINT INDEX: 3.441
Disable framebuffer (I used tvservice -o):
INTEGER INDEX : 11.199
FLOATING-POINT INDEX: 3.595
Also add disable_l2cache_writealloc=1 to config.txt
INTEGER INDEX : 11.219
FLOATING-POINT INDEX: 3.635
Also build with gcc 4.7.1
INTEGER INDEX : 11.505
FLOATING-POINT INDEX: 3.847
Also built with SOF reduction (echo on | sudo tee /proc/dwc_sof/SOF_reduction)
INTEGER INDEX : 12.081
FLOATING-POINT INDEX: 4.179
And also with overclock (arm_freq=1000, core_freq=500, sdram_freq=500)
INTEGER INDEX : 17.039
FLOATING-POINT INDEX: 5.882
Also with kernel_cutdown.img:
INTEGER INDEX : 17.676
FLOATING-POINT INDEX: 6.247
NUMERIC SORT        :          354.16  :       9.08  :       2.98
STRING SORT         :          47.983  :      21.44  :       3.32
BITFIELD            :      1.0657e+08  :      18.28  :       3.82
FP EMULATION        :          67.199  :      32.25  :       7.44
FOURIER             :          3649.9  :       4.15  :       2.33
ASSIGNMENT          :          4.6711  :      17.77  :       4.61
IDEA                :          1003.1  :      15.34  :       4.56
HUFFMAN             :          621.12  :      17.22  :       5.50
NEURAL NET          :           5.104  :       8.20  :       3.45
LU DECOMPOSITION    :          138.28  :       7.16  :       5.17
CPU                 :
L2 Cache            :
OS                  : Linux 3.1.9-cutdown+
libc                : libc-2.13.so
MEMORY INDEX        : 3.880
INTEGER INDEX       : 4.856
FLOATING-POINT INDEX: 3.465
