step1041
Using VNC to connect to RPi, shows LXDE instead of XFCE4
Sun Aug 05, 2012 5:27 am
When I VNC from my Mac to the Raspberry Pi running Raspian with both LXDE and XFCE4 installed it will only show me the LXDE environment instead of the XFCE4 screen that I am using. Is there anyway of changing this? I am using the Thight VNC Server on the RPi and Chicken of the VNC client on the Mac.
linuxgx
Re: Using VNC to connect to RPi, shows LXDE instead of XFCE4
Sun Aug 05, 2012 6:54 am
VNC should be logging into your active session. Also OSX has a built in VNC viewer that is much better than chicken. Just click run in finder and then connect to server.
Type in - VNC://RPIs_IP_ADRESS
lewmur
Sun Aug 05, 2012 12:39 pm
linuxgx wrote:VNC should be logging into your active session. Also OSX has a built in VNC viewer that is much better than chicken. Just click run in finder and then connect to server.
Nope. TightVNC starts its own session. It will bring up LXDE even if you haven't started an xserver session. I haven't checked the tightVNC's config file but there might be a way to change it there.
step1041
Sun Aug 05, 2012 9:04 pm
Yeah I noticed that if a LXDE isn't started it will by default open one for you. If I have an XFCE4 session started, it will still open a LXDE session beside it. I also tried using the built in VNC application in Mac OS X and it doesn't seem to be working. I wonder if it is something that was taken out of Mountain Lion.
