The Linux CRDA framework controls whether you can tune to channels >11. Set this via iw (e.g. iw reg set US).lb wrote:Does the WiFi chipset support channel 13 (in regions where it is allowed)? I can't find any clear info on this.
Re: The Raspberry Pi 3 Model B Q&A thread
Rockets are loud.
https://astro-pi.org
Crazy idea perhaps, but...
I'm aware the Foundation has no 64 bit support/OS lined up and that'll not change for a while, as indicated by Eben. I'd like to try my hand at compiling something, here's my line of thought: booting the RPi3 from a 32 bit image, then use distcc and friends to build 64 bit packages on an external x86_64 system (Funtoo in my case). Create bootable image for SD-card, swap SD cards, boot into a 64 bit environment, re-do builds in native environment. Would that work, not having any experience with distcc nor image-making? Or should I just wait for a 64 bit image from either the Foundation or Funtoo?
If it's a viable path, I'd have to order that RPi3 kit PDQ!
(otherwise I'd wait for the initial surge to subside, cutting down on delivery times
I don't mind (it) getting shot down, but be gentle please
There is a config.txt option to boot the cores in 64 mode, so if you have a 64 bit kernel it might work. It's all the other stuff you need in 64 bit that might be a problem. Pi Cross compiler is available on github.Dutch_Master wrote:Crazy idea perhaps, but...
If it's a viable path, I'd have to order that RPi3 kit PDQ!(otherwise I'd wait for the initial surge to subside, cutting down on delivery times
Orders are being fulfilled pretty quickly - a lot were made up front.
Youtube performance is better than in rpi2 , https://goo.gl/yK5uBtKratos wrote:I have some questions about the Raspberry Pi 3:
6. How is YouTube performance?
Thanks for the help.
Kratos
Just for reference, I've launched the same video via Youtube in Epiphany Browser on a Pi2B and it plays back silky smooth here. Not that I'm trying to put you off buying a Pi3B if you want one.geev03 wrote:Youtube performance is better than in rpi2 , https://goo.gl/yK5uBt
Many thanks James. Funtoo uses a Debian based kernel (debian-sources-3.19 IIRC) but sadly only 32 bit ARM support for the RPi. The Subarches page for ARM lists several options for the RPi, but I assume I'd need the armv7a image for the A8 core the RPi3 has?
When I insert a µ-SD-card into my new Pi3's SD-card slot, it doesn't "click" like it does on the Pi2 when it (the SD-card) snaps-in.
Also I can't snap-out the µ-SD-card from the Pi3 like it does on the Pi2 by pressing it (the SD-card) a little bit more, but I have to pull it out from the Pi3's slot.
Whilst this works, I liked the Pi2 slot with its click for snapping-in and -out better, and I wonder if this is a "feature" of the Pi3 or some problem with my Pi3 ?
Aside it, the Pi3 is an amazingly fast machine and it nicely runs the Pi2's SD-card with its OS installation.
This was a conscious design change apparently, so it's not a fault on your Pi 3.Fidelius wrote:When I insert a µ-SD-card into my new Pi3's SD-card slot, it doesn't "click" like it does on the Pi2 when it (the SD-card) snaps-in.
The guys at Pimoroni reported that the most common failure on uSD Pis with springy slots was the springy slot failing. Also a lot of people found the uSD card flying out when they were holding the board to change connectors really annoying. They've redesigned the Pibow to provide a larger slot around the uSD card to get your fingers in to remove it.
Looks like from the Pi Zero onwards we're getting non-springy uSD slots.
Not a huge problem for me. I used to get quite annoyed as uSD cards flew across the room if I didn't remove them properly... (They always ended up under the sofa...)
Dear Noggin, thank you for this information. I too can live with it, but just wondered.
Is there any reason why /dev/input would not be properly populated when booting with / mounted from a USB hard disk ?
I've used the same process I've used before to create a root filesystem on a USB harddisk so that the SD card is only only used for the boot partition.
If I mount / from the SD card evey thing works fine.
If I mount / from the USB disk X comes up but the keyboard and mouse don't work. I found a hint in /var/log/Xorg.0.log that lead me to look in /dev/input
When it works:
When it doesn't work
It's not a PSU problem, in both cases all the partitions on the USB disk are accessible. No low voltage warnings are seen and the PSU is rated at 2.5A.
PeterO
When it works:
$ cat workingDevInput
pi@raspberrypi:/dev/input $ ls -lR
total 0
drwxr-xr-x 2 root root 120 Mar 1 16:07 by-id
drwxr-xr-x 2 root root 120 Mar 1 16:07 by-path
crw-rw---- 1 root input 13, 64 Mar 1 16:07 event0
crw-rw---- 1 root input 13, 65 Mar 1 16:07 event1
crw-rw---- 1 root input 13, 66 Mar 1 16:07 event2
crw-rw---- 1 root input 13, 63 Mar 1 16:07 mice
crw-rw---- 1 root input 13, 32 Mar 1 16:07 mouse0
./by-id:
total 0
lrwxrwxrwx 1 root root 9 Mar 1 16:07 usb-Logitech_USB_Trackball-event-mouse -> ../event2
lrwxrwxrwx 1 root root 9 Mar 1 16:07 usb-Logitech_USB_Trackball-mouse -> ../mouse0
lrwxrwxrwx 1 root root 9 Mar 1 16:07 usb-_USB_Keyboard-event-if01 -> ../event1
lrwxrwxrwx 1 root root 9 Mar 1 16:07 usb-_USB_Keyboard-event-kbd -> ../event0
./by-path:
total 0
lrwxrwxrwx 1 root root 9 Mar 1 16:07 platform-3f980000.usb-usb-0:1.2:1.0-event-kbd -> ../event0
lrwxrwxrwx 1 root root 9 Mar 1 16:07 platform-3f980000.usb-usb-0:1.2:1.1-event -> ../event1
lrwxrwxrwx 1 root root 9 Mar 1 16:07 platform-3f980000.usb-usb-0:1.4:1.0-event-mouse -> ../event2
lrwxrwxrwx 1 root root 9 Mar 1 16:07 platform-3f980000.usb-usb-0:1.4:1.0-mouse -> ../mouse0
total 0
./by-id:
total 0
./by-path:
total 0
pi@raspberrypi:dev/input $ ls -lR
total 0
drwxr-xr-x 2 root root 60 Mar 1 16:10 by-id
drwxr-xr-x 2 root root 60 Mar 1 16:10 by-path
crw-rw---- 1 root input 13, 63 Mar 1 16:10 mice
crw-rw---- 1 root input 13, 32 Mar 1 16:10 mouse0
./by-id:
total 0
lrwxrwxrwx 1 root root 9 Mar 1 16:10 usb-Logitech_USB_Trackball-mouse -> ../mouse0
./by-path:
total 0
lrwxrwxrwx 1 root root 9 Mar 1 16:10 platform-3f980000.usb-usb-0:1.4:1.0-mouse -> ../mouse0
PeterO
Sure, but some hardware isn't physically capable of operating at channels > 11. I assume you want to imply the Broadcom WiFi chipset can do it?jdb wrote:The Linux CRDA framework controls whether you can tune to channels >11. Set this via iw (e.g. iw reg set US).lb wrote:Does the WiFi chipset support channel 13 (in regions where it is allowed)? I can't find any clear info on this.
As described in viewtopic.php?f=29&t=138120 Bluetooth uses the PL011 UART by default, so only the Mini UART is free for use. However, it unfortunately has various restrictions.
Does Bluetooth need to use the PL011 UART for some special reason, or can we switch it to the Mini UART?
Gert's VGA666
has ceased to function.
I checked the overlays & thankfully it is present.
Any ideas please?
In the meantime I'll see if I can find a definitive list of used by RPi3 GPIO's.
Any ideas please?
Anyone?Kiefer wrote:Does the onboard wifi have an activity Led?
Cheers, Harry
There is something odd going on here. I tried recreating the root filesystem on the USB drive, but rather than take it directly from the ".img" file I took it from the partition on the SD card that had already been mounted successfully.PeterO wrote:Is there any reason why /dev/input would not be properly populated when booting with / mounted from a USB hard disk ?
PeterO
Now it seems to be working. I'll try and work out what had changed .
PeterO
I think I saw a green LED flickering whilst I was trying out the Wifi. Not sure if it is specifically a wireless indicator.Kiefer wrote:Anyone?Kiefer wrote:Does the onboard wifi have an activity Led?
Cheers, Harry
No.Kiefer wrote:Anyone?Kiefer wrote:Does the onboard wifi have an activity Led?
Cheers, Harry
Awesome. Just noticed the core_freq has been upped from 250mhz to 400mhz:
http://dietpi.com/downloads/misc/core_freq.png
DietPi.com - Lightweight justice for your Raspberry Pi. Optimized, simplified linux for everyone
DietPi's web hosting is powered by MyVirtualServer.com
My understanding from reading this thread is that I should be able to take the Raspbian SD card from a Pi 2 and plug it into a Pi3. However, just tried it and all I get is the rainbow screen.
- mikronauts
put it back into the RPi2, then:
sudo apt-get update
sudo apt-get upgrade
If that does not work on an RPi3, try:
sudo apt-get dist-upgrade
sudo apt-get update
tdenson wrote:My understanding from reading this thread is that I should be able to take the Raspbian SD card from a Pi 2 and plug it into a Pi3. However, just tried it and all I get is the rainbow screen.
Raspbian Jessie compatible with an update / upgrade as above..tdenson wrote:My understanding from reading this thread is that I should be able to take the Raspbian SD card from a Pi 2 and plug it into a Pi3. However, just tried it and all I get is the rainbow screen.
Raspbian Wheezy not compatible...
Dumb question, but how do I tell which of the above I am running ?fruitoftheloom wrote:Raspbian Jessie compatible with an update / upgrade as above..tdenson wrote:My understanding from reading this thread is that I should be able to take the Raspbian SD card from a Pi 2 and plug it into a Pi3. However, just tried it and all I get is the rainbow screen.
Like thistdenson wrote:Dumb question, but how do I tell which of the above I am running ?fruitoftheloom wrote:Raspbian Jessie compatible with an update / upgrade as above..tdenson wrote:My understanding from reading this thread is that I should be able to take the Raspbian SD card from a Pi 2 and plug it into a Pi3. However, just tried it and all I get is the rainbow screen.
pi@raspi3 ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
fruitoftheloom wrote:...
Actually, it's sort of compatible
I'm trying to work out why my vga666 display is a no-show on this RPi3 Jessie.
So, I've booted from my most recent (updated) "bouncing-menu" wheezy µSD card.
pi@p3 ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
pi@p3 ~ $
Hoping someone can help me!?
I've apt-get up(date/grade)d my Raspbian Jessie install on a Raspi 2 then inserted this card in a Raspi 3 and booted only to find the Raspi 3 still thinks it is a Raspi 2.
I'm wondering if the .dtb file isn't being picked up by the kernel perhaps... though I'm clutching at straws here.
Also, I'm suffering appalling wifi performance (perhaps due to Pi thinking it is a v2?). SSH'ing to the new Pi is extremely sluggish with up to 2-10 seconds latency in response to input.
Can anyone shed any light on this please?
vcgencmd version after apt-get upgrade:
output of vcgencmd measure_clock:
content of /boot/config.txt:
output of cat /proc/cpuinfo shows the CPU is ARMv7 rather than ARMv8:
I'm guessing that /proc/cpuinfo may be inaccurate due to the 32 bit build of Raspbian? However, the clock frequencies don't measure up do they?
Feb 29 2016 14:23:50
Copyright (c) 2012 Broadcom
version dea971b793dd6cf89133ede5a8362eb77e4f4ade (clean) (release)
for src in arm core h264 isp v3d uart pwm emmc pixel vec hdmi dpi; do echo -e "$src:\t$(vcgencmd measure_clock $src)" ;done
arm: frequency(45)=600000000
core: frequency(1)=249999000
h264: frequency(28)=250000000
isp: frequency(42)=250000000
v3d: frequency(43)=250000000
uart: frequency(22)=48000000
pwm: frequency(25)=0
emmc: frequency(47)=250000000
pixel: frequency(29)=148500000
vec: frequency(10)=0
hdmi: frequency(9)=163683000
dpi: frequency(4)=0
disable_overscan=0
gpu_mem=128
lcd_rotate=2
start_x=0
dtparam=i2c_arm=off
dtparam=spi=off
# Enable audio (added by raspberrypi-sys-mods)
dtparam=audio=on
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2709
Revision : a02082
Serial : 00000000########
