I resized Raspbian to 8GB and everything works without problems, thanks again for the help.procount wrote: ↑Wed Mar 13, 2019 6:41 pmThat suggests you have not allocated enough space to Raspbian. Try the recommended size of 8GB then it should be ok.
The OSes indicate a minimum size to install, but sometimes it is not really enough, especially if you want to update it later. I am contemplating adding a minimum recommended setting to each OS as a warning to overcome this.
I will experiment with the partition sizes to see how much i can shave off and still make it work, if not i will just keep it as it is.
And i think your idea of adding a minimum recommendation setting for each OS would be pretty good.
Edit: I resized Raspbian down to 7GB and it still works without problems, i think i will just keep it at 7, because making it any smaller makes no difference in the big picture for me.
