joe2act
No swap space?
Mon Aug 13, 2012 12:22 am
Normally Linux(e.g. Ubuntu) file system has swap space. However, I found that R-Pi with Raspbian Wheezy does not have swap space.
Why Raspbian has no swap ? for increasing the lifespan of the SD card?
How can Raspbian disable swap?
Thank you in advance.
bredman
Re: No swap space?
Mon Aug 13, 2012 8:23 am
Using swap on an SD card is not recommended for 2 reasons
1. An SD card can only sustain a limited number of writes in its lifetime.
2. Read/write access to an SD card is dreadfully slow.
You can enable swap if you like, it's your choice. Search this forum for the word "swapon".
RaTTuS
Re: No swap space?
Mon Aug 13, 2012 8:25 am
1st ) free -h
2nd) raspbian uses a small swapfile
3rd) raspbina has the swapiness set to very low
Covfefe
joe2act
Re: No swap space?
Mon Aug 13, 2012 9:44 pm
bredman wrote:Using swap on an SD card is not recommended for 2 reasons
Thank you for reply.
joe2act
Re: No swap space?
Mon Aug 13, 2012 10:12 pm
RaTTuS wrote:1st ) free -h
I typed your suggested command 'free -h'. I found that Raspbian Wheezy has a 99MB swap space.
However, if I use 'sudo fdisk -l' command, Raspbian lists two partitions: mmc0p1(FAT), and mmc0p2(ext4), and I found no Linux swap partition or space on SD card. Why Raspbian has two different swap spaces (one swap is 99MB in free -h, and another swap is none in fdisk -l)?
I checked manual for free and fdisk. The free command displays the total amount of free and used physical and swap memory in the system, as well as the buffers used by the kernel. The sudo fdisk -l commands lists the partitions on Linux system.
In my understanding, fdisk -l lists a physical disk swap space which dedicates to memory swap space. The free -h command shows a swap memory space. Is my understanding correct ?
jojopi
Re: No swap space?
Mon Aug 13, 2012 10:43 pm
joe2act wrote:Why Raspbian has two different swap spaces (one swap is 99MB in free -h, and another swap is none in fdisk -l)?
Because, as RaTTuS said, it uses a swapfile, not a partition. "cat /proc/swaps" for details.
"fdisk -l" is not a correct method to check whether a system is configured for swap. It cannot see swapfiles, or swap that may be inside any LVM or RAID partitions. Also the type code on partitions is not enforced, so it is possible to be swapping to a partition that appears in fdisk as some other type. Most importantly, even if fdisk does list a swap partition, that does not tell you whether the system is configured to use it...
carlosfm
Re: No swap space?
Mon Aug 13, 2012 10:46 pm
I would also like to know how to disable the swap file on raspbian, as I am using a swap partition.
A swap partition is always much faster than a file, and in this case they both reside on the same device (the SD card!).
Swap file(s) are Windoze stuff! :oops: :mrgreen:
Btw, I've never seen swap being used on my Raspbian.
vm.swappiness=1 takes care of this.
I just don't like swap files...
Do you Pi?
jojopi
Re: No swap space?
Mon Aug 13, 2012 11:25 pm
carlosfm wrote:I would also like to know how to disable the swap file on raspbian, as I am using a swap partition.
I will be amazed if you can construct a fair benchmark that can even measure a difference. Notice that swapping to a file does not update the file's timestamps, you are not allowed to truncate or write to the file while swapping to it, and you can not swap to a file that is sparse. In other words, the file is sealed off and treated exactly like a (slightly discontiguous) mini-partition.
To answer your question, "sudo update-rc.d dphys-swapfile disable" should stop the swapfile being enabled at boot.
RaTTuS
Re: No swap space?
Tue Aug 14, 2012 7:40 am
cat /etc/fstab
this will show you :-
# a swapfile is not a swap partition, so no using swapon|off from here on, use dphys-swapfile swap[on|off] for that
if you look in
/etc/init.d
you will see
cat /etc/init.d/dphys-swapfile
you can disable this from running so a swap file is never used, this means your program will just fail with out of memory error if it ever does need more than can be allocated
the raspbian swapiness is set so low it only gets used in emergencies.
you can disable the swap file and put a swap partition on an external HD if you want
swapping to a file for a partition on the SD card will not make any difference
having some swap space is useful. [YMMV]
Covfefe
carlosfm
Re: No swap space?
Tue Aug 14, 2012 9:11 am
I don't have proof, it's just a question of principle, but I'm not going to argue.
A swap file is contained inside a filesystem, while the swap partition is dedicated for this task.
If it was an HDD, it would make much more difference, as I can locate the swap partition at the very beginning of the disk, while a swap file resides somewhere in the filesystem, which we can not exactly control.
Oh, and thanks for your help. :mrgreen:
Do you Pi?
bredman
Re: No swap space?
Tue Aug 14, 2012 9:36 am
Some people were asking for the relevant commands...
To check the current swap status
swapon -s
To turn off all swap
sudo swapoff -a
To turn on swap as defined in /etc/fstab
sudo swapon -a
To turn on swap, using a specified file
sudo swapon /var/swap
carlosfm
Re: No swap space?
Tue Aug 14, 2012 6:57 pm
Well...
As recommended above, I excuted:
This has produced errors and nothing happened.
Then I've tried what I had tried before, withot success (executed as su):
dphys-swapfile swapoff
But when booting, the damn swap file was still being activated.
I've only managed to stop it by removing the executabe flag of the "/etc/init.d/dphy-swapfile" file.
No my raspbian loads with only my swap partiton (on the SD card) and it seems faster!
PS: this post was written on my Pi.
Do you Pi?
truehl
Re: No swap space?
Tue Aug 14, 2012 7:19 pm
Why not simply uninstall the dphys-swapfile package with:
apt-get purge dphys-swapfile
After doing this reboot and the swapfile and the piece of SW responsible for the swap has gone!
truehl
http://www.squeezeplug.de
jojopi
Re: No swap space?
Tue Aug 14, 2012 7:44 pm
carlosfm wrote:"sudo update-rc.d dphys-swapfile disable"
Are you serious? You are honestly not going to tell us what the errors said?
joe2act
Re: No swap space?
Tue Aug 14, 2012 7:47 pm
jojopi wrote:Because, as RaTTuS said, it uses a swapfile, not a partition. "cat /proc/swaps" for details.
In Raspbian, I found that 'free' and 'cat /proc/swaps' report same swap space, 102369KB.
pi@raspberrypi ~ $ cat /proc/swaps
Filename                                Type            Size    Used    Priority
/var/swap                               file            102396  12      -1
pi@raspberrypi ~ $ free
             total       used       free     shared    buffers     cached
Mem:        188080     176424      11656          0      33992     115532
-/+ buffers/cache:      26900     161180
Swap:                102396       12     102384
Linux raspberrypi 3.1.9+ #168 PREEMPT Sat Jul 14 18:56:31 BST 2012 armv6l GNU/Linux
The /etc/fstab also tell something interesting about swap space:
pi@raspberrypi ~ $ cat /etc/fstab
proc            /proc           proc    defaults          0       0
/dev/mmcblk0p1  /boot           vfat    defaults          0       0
/dev/mmcblk0p2  /               ext4    defaults,noatime  0       0
carlosfm
Re: No swap space?
Tue Aug 14, 2012 7:48 pm
Sorry jojopi, when I posted this I had already rebooted and didn't want to execute it again.
You can try it, it didn't work but it has made no harm, just a couple of warnings.
Do you Pi?
carlosfm
Re: No swap space?
Tue Aug 14, 2012 7:50 pm
truehl wrote:Why not simply uninstall the dphys-swapfile package with:
A much more elegant solution, no doubt. :mrgreen:
Do you Pi?
jojopi
Re: No swap space?
Tue Aug 14, 2012 8:11 pm
carlosfm wrote:You can try it, it didn't work but it has made no harm, just a couple of warnings.
But of course I did try it, prior to recommending. I can assure you it works when typed correctly on a not-otherwise-broken system. Did the errors look anything like:
update-rc.d: using dependency based boot sequencing
update-rc.d: error: cannot find a LSB script for you-misspelled-dphys-swapfile
or:
-bash: sudo update-rc.d dphys-swapfile disable all in quotes: command not found
carlosfm
Re: No swap space?
Tue Aug 14, 2012 8:14 pm
No, nothing like that.
It said something was empty, and something about the runlevel.
Btw, I've copied the command from your post (without quotes) and pasted in the terminal.
Hey, my system is not broken...
Do you Pi?
jackokring
Re: No swap space?
Tue Aug 14, 2012 8:24 pm
A swap partition is not always much faster than a swap file. It depends on the inode structure and what is in what swap page and how close on disk, or in the flash prefetch some sector is to the file data it relies on. This does of course imply the swap driver has to be optimal or close to to see the benefit of this effect.
Cheers Jacko
RaTTuS
Re: No swap space?
Wed Aug 15, 2012 10:57 am
and I would not expect it be be any quicker
if after a boot and
free
shows that swap is being used
then you may have other problems ;-p
Covfefe
jerrylamos
Re: No swap space?
Wed Aug 15, 2012 12:35 pm
So I put a swapfile on the SD card, Debian Wheezy, at 2x cache size 512 MB entered it into /etc/fstab and turned the Wheezy automatically generated swap file of about 110 MB off. Rebooted and Wheezy automatically put the swap file back again. How do I turn the swap file off other than manual command every time ?
Yes, what I do with Midori does challenge the 224 MB memory size and I haven't even found a way to play the Raspberry Pi Org's and MagPi's videos on the Pi. Attempts to run huge Gnash (lots! of packages to install) have hung up, and I haven't found a Raspberry Pi HTML5 package. Now smartphones using ARM processors play videos - why can't Pi?
RaTTuS
Re: No swap space?
Wed Aug 15, 2012 12:57 pm
Covfefe
jerrylamos
Re: No swap space?
Wed Aug 15, 2012 9:28 pm
RaTTuS wrote:apt-get purge dphys-swapfile
Thanks! Looked like it did something, freed up some disk space, and its still running.
joe2act
Re: No swap space?
Wed Aug 15, 2012 11:43 pm
Thanks to all.
In summary, Raspbian still has a swap file in file system, but Raspbian has no swap partition in SD card. The reason is SD card has limited read/write cycles. No swap partition in SD card can increase SD card life span.
