Rive
Pi3 Configuration, Overclocking, Stability Testing & Cooling
Wed Apr 13, 2016 7:05 pm
The Pi3 has been pushed to it's manufacturing limitations, and it runs hot. With the Pi3, if you are expecting to get any kind of performance out of it, you are gonna need to set up some kind of cooling.
SoC hot!!!
Raspberry Pi 3 Thermal Photography
The BCM2837 system-on-chip (SoC) in the Raspberry Pi 3 gets far, far hotter than its predecessors. If you're planning to put the Pi 3 in a case, you're going to need to invest in a heatsink and make sure there's at least some ventilation
Source
Using my Pi3 as a test subject, for determining optimal cooling capabilities, optimization via overclocking, and running bench tests on that optimized Pi, I figured I would show it off firstly....
Screen Blanking and Lock Screen:
First thing i did though, was disable that annoying screen blanking. I set the Monitor to turn off, and go into power save mode when I wanted it to, and to use a keyboard shortcut to ScreenLock via Light-Locker. For more info, and Instructions on how to disable screen blanking, and enable screen locking (xscreensaver sucks), see: viewtopic.php?p=961360#p961360
My Pi3 desktop (I am partial to the Windows layout and "Start" buttons, and i like to switch between visual themes...I have three themes, Raspbian, Kali, and Veil) If you are gonna turn the Pi3 into an overclocked Desktop PC, make it look awesome! Right?
(If you want to customize and modify/change your look, or theme, see: viewtopic.php?p=969008#p969008)
KALI
VEIL
Raspbian
The easiest way I have found is get an oversized heatsink, and fan.... Cpuburn-a53 is designed to heat up the pi3, and I can run it with ease overclocked @ 1.3 Ghz, and thermals never exceed 50C. I can run Stress at 38C, Sysbench at 37C, and Idle at 26C... Whether you are overclocked or not, If you have an overheating issue, this is how to resolve it.
EDIT
1.3 GHz overclock failed on Linpack, so arm overclock reduced to a more stable 1.26 GHz.
The heatsink pictured below is custom machined for me by a friend (I have two of them), and is made of anodized aluminum. The outside dimensions are L.87" x W.96" x H.70", and the centered 'socket' on the bottom is L.66" x W.66" and .010" deep.
You may be able to order custom sized Aluminum heatsinks, for example:
https://store-ddfcc.mybigcommerce.com/c ... 0sehsi41h1
The cooling fan is 12v 70mm x 70mm x 10mm, and sells pretty much everywhere for around $4 - $7 or so. It runs quietly on the GPIO 5V rail.
The case is the "official" pi3 case, which runs $8. (fan itself is removable, and is held in place with Velcro-like fasteners. An 18 pack of Scotch 3M reclosable fasteners runs like $4)
Is the 12v fan quiet? Does it efficiently cool the pi3?
https://youtu.be/0bso6ucTuH8
Fan Push or Pull, which is better??? :?
see: viewtopic.php?p=963540#p963540
Overclocked "Hot Rod Pi3 Extreme"
Under the hood:
Stable Overclock (utilizing the below tests):
(add to /boot/config.txt above 'gpu_mem=') ;)
dtparam=sd_overclock=100
arm_freq=1260
core_freq=500
over_voltage=4
sdram_freq=575
sdram_schmoo=0x02000020
over_voltage_sdram_p=6
over_voltage_sdram_i=4
over_voltage_sdram_c=4
v3d_freq=500
h264_freq=333
GPU memory is set to 192 (gpu_mem=192) which seems to provide the best performance if using the pi3 as a desktop with monitor.
If you want to test your pi3:
Why should you care if your overclock is stable, or not?
Unstable overclocks can eventually lead to premature hardware failure, malfunctions, crashes and data loss, as well as sdcard corruption.
If your Pi3 should freeze up, or otherwise become unresponsive during tests, DO NOT remove power, instead reboot with 'alt'+"sysrq"+"b" ('sysrq' is also known as 'prtscr' key). Hard reboots (where you unplug power, then plug it back in again) can result in data corruption!
Two things before you start, make sure you have the proper power supply, and some kind of cooling capability... fan and/or heatsink (preferably both).
Power supply for Pi3 (power draw when idle): Source
5.19 V 1.141 W
0.22 A 00006 mAh
Get yourself the official Pi3 power supply (5.1V 2.5A), or the 5.25V 2.4A power supply
TOP (hit '1' to see all cores with loads):
top
SDBENCH:
(test the hdpharm and read/write performance of your hc-1/uhs-1 micro sdcard). Average is 50 MHz 20 MB/s Read; 12 MB/s Write, or with sd_overclock 100 MHz 40 MB/s Read; 20 MB/s Write.
open, and 'select all':
http://www.nmacleod.com/public/sdbench.sh
then:
sudo nano sdbench.sh
...and paste the text in, then save with Ctrl-X, Y, Enter.
Make it executable with...
sudo chmod +x sdbench.sh
Then run:
sudo ./sdbench.sh
MEMTESTER: (set "gpu_mem=" to 64 prior to run, and reboot after install)
(test your sdram, battery of tests will indicate pass/fail results. you want 'pass' across the board for 5 sequential loops. set 'gpu_mem' to 48 prior to test for optimal results)
sudo apt-get memtester
Run:
memtester 700m 5
SYSBENCH:
(basic cpu performance benchmark. prime number cruncher (up to 20000) with validation)
average stock Pi3 benchmark total time is 119.4716 seconds (faster is better).
sudo apt-get install sysbench
Run:
sysbench --num-threads=4 --test=cpu --cpu-max-prime=20000 --validate run
STRESS: (15 min test run)
(puts a near "real world" full CPU load on pi. If you throttle on this, do not attempt cpuburn-a53 as you are inadequately cooled
sudo apt-get install stress
Run:
while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& stress -c 4 -t 900s
CPUBURN-A53: !!Run cpuburn-a53 with caution if your pi3 insufficiently cooled!!
(Test is "PASSED" if you do not throttle back, or exceed 79C within a 15min span. Exceeding 79C, and overheating/throttling, OR Pi3 crash indicates a "FAIL". Will also verify whether your power supply is adequate or not). A properly cooled pi3 can run this between 50C-79C.
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
Run:
while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& ./cpuburn-a53
LINPACK Bench: (set "gpu_mem=" to 64 prior to run, and reboot after install)
(tests stability, performs computations, if you overclock, and it is flawed, test will fail or crash. set 'gpu_mem" to 48 prior to test for optimal results). Stock Pi3 at 1.2 GHz passes this at 6 Gflops (may require a small voltage boost in /config.txt "over_voltage=1"), a stable overclocked Pi3 at 1.26 GHz passes at around 6.6 Gflops (multiple back to back tests with same Gflop result to determine stability).
sudo apt-get install libmpich-dev
wget http://web.eece.maine.edu/~vweaver/junk/pi3_hpl.tar.gz
tar -xvzf pi3_hpl.tar.gz
chmod +x xhpl
Run:
./xhpl
BENCH AND TEST RESULTS:
Ambient 20C:
Sysbench 37C 114.4567s
pi@raspberrypi:~ $ while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& sysbench --num-threads=4 --test=cpu --cpu-max-prime=20000 --validate run
[1] 1239
frequency(45)=1260002000
temp=30.0'C
sysbench 0.4.12:  multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 4
Additional request validation enabled.
Doing CPU performance benchmark
Threads started!
frequency(45)=1260000000
temp=35.4'C
temp=35.4'C
temp=36.5'C
temp=36.5'C
temp=37.6'C
temp=37.6'C
frequency(45)=1259998000
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
    total time:                          114.4567s
    total number of events:              10000
    total time taken by event execution: 457.7026
    per-request statistics:
         min:                                 45.42ms
         avg:                                 45.77ms
         max:                                 90.88ms
         approx.  95 percentile:              46.32ms
Threads fairness:
    events (avg/stddev):           2500.0000/12.25
    execution time (avg/stddev):   114.4256/0.02
Linpack Passed Gflops 6.6
pi@raspberrypi:~ $ ./xhpl
HPLinpack 2.1  --  High-Performance Linpack benchmark  --   October 26, 2012
Written by A. Petitet and R. Clint Whaley,  Innovative Computing Laboratory, UTK
Modified by Piotr Luszczek, Innovative Computing Laboratory, UTK
Modified by Julien Langou, University of Colorado Denver
An explanation of the input/output parameters follows:
T/V    : Wall time / encoded variant.
N      : The order of the coefficient matrix A.
NB     : The partitioning blocking factor.
P      : The number of process rows.
Q      : The number of process columns.
Time   : Time in seconds to solve the linear system.
Gflops : Rate of execution for solving the linear system.
The following parameter values will be used:
N      :    8000
NB     :     256
PMAP   : Row-major process mapping
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
SWAP   : Mix (threshold = 64)
L1     : transposed form
U      : transposed form
EQUIL  : yes
ALIGN  : 8 double precision words
- The matrix A is randomly generated for each test.
- The following scaled residual check will be computed:
      ||Ax-b||_oo / ( eps * ( || x ||_oo * || A ||_oo + || b ||_oo ) * N )
- The relative machine precision (eps) is taken to be               1.110223e-16
- Computational tests pass if scaled residuals are less than                16.0
T/V                N    NB     P     Q               Time                 Gflops
WR02R2L2        8000   256     1     1              51.27              6.660e+00
HPL_pdgesv() start time Sun Apr 24 09:13:21 2016
HPL_pdgesv() end time   Sun Apr 24 09:14:12 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)=        0.0025941 ...... PASSED
Finished      1 tests with the following results:
              1 tests completed and passed residual checks,
              0 tests completed and failed residual checks,
              0 tests skipped because of illegal input values.
End of Tests.
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              51.47              6.634e+00
HPL_pdgesv() start time Sun Apr 24 09:14:53 2016
HPL_pdgesv() end time   Sun Apr 24 09:15:44 2016
End of Tests.
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              51.69              6.605e+00
HPL_pdgesv() start time Sun Apr 24 09:16:14 2016
HPL_pdgesv() end time   Sun Apr 24 09:17:06 2016
End of Tests.
Stress 38C
pi@raspberrypi:~ $ while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& stress --cpu 4
[1] 2333
stress: info: [2334] dispatching hogs: 4 cpu, 0 io, 0 vm, 0 hdd
frequency(45)=1260132000
temp=30.0'C
temp=34.9'C
temp=35.4'C
temp=36.5'C
temp=36.5'C
temp=37.0'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=38.1'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=38.1'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=38.6'C
temp=38.1'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.0'C
temp=38.1'C
temp=37.6'C
temp=38.1'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.0'C
temp=37.0'C
temp=37.6'C
temp=38.1'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=38.1'C
temp=38.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=37.6'C
temp=38.1'C
Cpuburn-a53 50C
pi@raspberrypi:~ $ while true; do vcgencmd measure_clock arm; vcgencmd measure_temp; sleep 10; done& ./cpuburn-a53
[1] 1244
temp=27.9'C
temp=41.9'C
temp=42.9'C
temp=45.1'C
temp=46.2'C
temp=46.2'C
temp=46.2'C
temp=46.7'C
temp=46.2'C
temp=47.2'C
temp=48.3'C
temp=48.3'C
temp=47.2'C
temp=48.3'C
temp=47.2'C
temp=47.8'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=47.2'C
temp=48.3'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=48.3'C
temp=47.2'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=47.8'C
temp=48.9'C
temp=47.2'C
temp=48.3'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=47.2'C
temp=48.3'C
temp=49.4'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=48.9'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.4'C
temp=50.5'C
temp=49.9'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.3'C
temp=47.2'C
temp=48.3'C
temp=47.8'C
temp=47.2'C
temp=48.3'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=50.5'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
temp=49.4'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=48.9'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=47.8'C
temp=47.8'C
temp=47.2'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.8'C
temp=47.2'C
temp=47.8'C
temp=47.8'C
temp=48.3'C
temp=48.9'C
temp=48.3'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=48.9'C
temp=48.9'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=48.3'C
temp=48.3'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=49.4'C
temp=50.5'C
temp=49.4'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=50.5'C
temp=50.5'C
temp=49.9'C
temp=49.9'C
temp=49.9'C
temp=48.9'C
temp=49.4'C
temp=49.4'C
temp=49.4'C
temp=49.9'C
temp=49.9'C
Top
top - 16:23:07 up 34 min,  1 user,  load average: 5.05, 5.61, 5.16
Tasks: 144 total,   5 running, 139 sleeping,   0 stopped,   0 zombie
%Cpu0  : 99.0 us,  1.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu1  :100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu2  : 98.7 us,  1.0 sy,  0.3 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu3  : 99.3 us,  0.7 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem:    948012 total,   834380 used,   113632 free,    36644 buffers
KiB Swap:   102396 total,        0 used,   102396 free.   533068 cached Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
 1112 pi        20   0    1680    340    284 R  99.0  0.0  25:26.65 cpuburn-a53
 1116 pi        20   0    1680     88     16 R  98.3  0.0  25:25.70 cpuburn-a53
 1114 pi        20   0    1680     84     16 R  97.0  0.0  25:27.84 cpuburn-a53
 1115 pi        20   0    1680     84     16 R  94.0  0.0  25:22.16 cpuburn-a53
 2026 pi        20   0  628616 144016 102956 S   3.6 15.2   2:01.88 chromium-b+
  656 root      20   0  120868  45204  19560 S   2.6  4.8   0:58.07 Xorg
 2251 pi        20   0  376288 113548  78804 S   2.0 12.0   0:24.44 chromium-b+
  882 pi        20   0   90292  23252  19640 S   1.3  2.5   0:18.04 lxpanel
 1019 pi        20   0   47152  19028  16080 S   1.0  2.0   0:05.88 lxterminal
  877 pi        20   0   21012  12028   9416 S   0.3  1.3   0:03.06 openbox
 1110 pi        20   0    5112   2524   2148 R   0.3  0.3   0:07.52 top
 2506 root      20   0       0      0      0 S   0.3  0.0   0:00.01 kworker/2:2
    1 root      20   0   22884   4028   2788 S   0.0  0.4   0:06.79 systemd
    2 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kthreadd
Sdbench
pi@raspberrypi:~ $ sudo ./sdbench.sh
[3;J
CONFIG:
CLOCK : 100.000 MHz
CORE  : 500 MHz, turbo=1
DATA  : 512 MB, /root/test.dat
HDPARM:
 Timing O_DIRECT disk reads: 126 MB in  3.01 seconds =  41.86 MB/sec
 Timing O_DIRECT disk reads: 124 MB in  3.03 seconds =  40.89 MB/sec
 Timing O_DIRECT disk reads: 122 MB in  3.02 seconds =  40.40 MB/sec
WRITE:
536870912 bytes (537 MB) copied, 25.5738 s, 21.0 MB/s
536870912 bytes (537 MB) copied, 22.3328 s, 24.0 MB/s
536870912 bytes (537 MB) copied, 23.7269 s, 22.6 MB/s
READ:
536870912 bytes (537 MB) copied, 12.8048 s, 41.9 MB/s
536870912 bytes (537 MB) copied, 12.3227 s, 43.6 MB/s
536870912 bytes (537 MB) copied, 12.3561 s, 43.4 MB/s
RESULT (AVG):
Overlay config                      core_freq   turbo   overclock_50    WRITE        READ        HDPARM
                                       500        1     100.000 MHz   21.51 MB/s   40.99 MB/s   41.06 MB/s
Memtester
(example of 1 loop)
pi@raspberrypi:~ $ memtester 700m 1
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 700MB (734003200 bytes)
got  700MB (734003200 bytes), trying mlock ...locked.
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
  Compare DIV         : ok
  Compare OR          : ok
  Compare AND         : ok
  Sequential Increment: ok
  Solid Bits          : ok
  Block Sequential    : ok
  Checkerboard        : ok
  Bit Spread          : ok
  Bit Flip            : ok
  Walking Ones        : ok
  Walking Zeroes      : ok
  8-bit Writes        : ok
  16-bit Writes       : ok
Done.
DNPNWO
pxgator
Re: [Solved] Pi3 overheating no more.
Wed Apr 13, 2016 7:19 pm
@Rive
Cool!!...(pun intended)...now we know what a hot rod extreme pi looks like.
P.S. I sent you another pm
So what's all this RPi stuff anyhow? Well folks, it's a feat of engineering from
the UK almost as remarkable as the De Havilland Mosquito and the Colossus.
Rive
Wed Apr 13, 2016 7:28 pm
pxgator wrote:@Rive
lol...I am gonna use that ;)
DNPNWO
Rive
Re: Overclocker Benching, Testing & Cooling
Mon Apr 25, 2016 4:37 am
Updated with how to install and run the following benchmarks and tests to check stability, cooling, and performance of the Pi3, and how to disable screen blanking, and configure and enable lock screen options using light-locker.
LIGHT-LOCKER
SDBENCH
SYSBENCH
STRESS
CPUBURN-A53
LINPACK
MEMTESTER
DNPNWO
loadbang
Re: Pi3 Configuration, Benching, Stability Testing & Cooling
Thu Apr 28, 2016 1:32 pm
Building a BOM for heatsink and fans for UK based people.
http://cpc.farnell.com/aavid-thermalloy ... dp/SC10762
23x23mm, a lot larger than 15x15mm of the CPU, will it fit fine?
http://cpc.farnell.com/ebm-papst/252-2n ... 0000009759
12v, it will fit, but pricey. Also worry the inrush current may be too much to use the 5V header on the Pi.
Thoughts? Any other good sources to buy HS&F?
Rive
Thu Apr 28, 2016 1:40 pm
loadbang wrote:Building a BOM for heatsink and fans for UK based people.
As for the fan current, should be fine. It isnt gonna run it at 12V...it will run it at 5V (or you can even try the 3V header). It is a tiny fan (25mm x 8mm)...approx 1/3 the size of the fan I use (70mm x 10mm @ approx 0.2 A), what are you mounting it on?
70mm x 10mm
as for the heatsink...
If you compare your specs (L .91" W .91" H .39" ) to the specs of the one in this image (L .87" W .96" H.70"), you will notice is only slightly longer. You may want to reconsider though, as the height is not much and thus provides less of a cooling area, which may render it less effective.
Imagine the heatsink in image shown below as more rectangular (instead of square)...slightly longer (+.04"), less wide (-0.5"), and less then half as high (-0.31").
There is room, so you can make the length work (if you offset it forward a little towards the USB/Ethernet). Measure the area around the SoC and see.
L .87" W .96" H.70"
http://postimg.org/image/uiwylrcr5/
DNPNWO
ag123
Re: Pi3 Configuration, Overclocking, Stability Testing & Coo
Wed Dec 21, 2016 3:42 pm
my own current trials
i found some rather good ideas including a case like this offered for sale on ebay
http://www.ebay.com/itm/Transparent-Cle ... 1727422137
not affliated with those case sellers but i'm looking for a thermal solution for pi 3 too
i'm using a heat sink similar to this
i used one that is somewhat oversized with dimensions 25mmx27mmx7mm
the thing would be that 1'd need to be careful not to short components around a somewhat large oversized heatsink
currently i'm making do with passive cooling - i.e. no fan
but i may instead get one of those boxes with fan like the above ebay link
i've done some tests
without a heat sink, pi 3 actually run fine for those 'single threaded' jobs
e.g. play h264 mp4 HD 1080p movies using omxplayer only reaches 52deg C
a single thread linpack stabilise at around 60deg C
http://www.netlib.org/benchmark/linpackc.new
gcc -O3 -o linpack linpack.c -lm -mfloat-abi=hard -mfpu=neon-vfpv4 -mcpu=cortex-a8
however, if 4 concurrent linpack is run it quickly reach about 82 deg C in less than a minute and the cpu throttles to 600mhz
after installing the heatsink, no fan - passive cooling
i've been able to run 4 concurrent linpack and the temperature gradually increase from 48deg - 79deg over 14 minutes
i terminate the experiment when the temperature reaches 79 deg
Sun 18 Dec 07:11:53 UTC 2016 @ raspberrypi
GPU => temp=48.3'C
CPU => 48'C
freq => frequency(45)=1200000000
Sun 18 Dec 07:26:09 UTC 2016 @ raspberrypi
GPU => temp=79.0'C
CPU => 78'C
freq => frequency(45)=1199998000
the experiment did not reach 'steady state' as temperature is continually rising but much more gradual compared without heatsink.
throughout the 14 minutes, i've got 4 concurrent linpack processes crunching 1000x1000 matrices non-stop and it does not throttle the frequency, frequency remains at 1.2Ghz for all that 14 minutes of intensive computation.
while linpack is a synthetic benchmark, i'd think it is quite possible to reach such temperatures realistically, examples may be cases of video transcoding if the transcoder runs concurrent parallel transcoding threads
then to further achieve 'steady state' i'd think a fan is needed. however, for the occasional high (concurrent parallel) loads i'd think passive cooling is still a rather sensible solution.
i used a 'big' heat sink and this keeps temperature low for a rather long time (14 mins) during the intense load. however, a large heat sink also tend to cool slower when load is removed due to the bulk
script for monitoring temperatures & frequencies
#!/bin/bash
cpu=$(</sys/class/thermal/thermal_zone0/temp)
echo "$(date) @ $(hostname)"
echo "-------------------------------------------"
echo "GPU => $(/opt/vc/bin/vcgencmd measure_temp)"
echo "CPU => $((cpu/1000))'C"
echo "freq => $(/opt/vc/bin/vcgencmd measure_clock arm)"
ejolson
Wed Dec 21, 2016 6:53 pm
ag123 wrote:while linpack is a synthetic benchmark, i'd think it is quite possible to reach such temperatures realistically, examples may be cases of video transcoding if the transcoder runs concurrent parallel transcoding threads
For me a synthetic benchmark is a short program that doesn't solve a real problem.
In a way solving a randomly generated system of linear equations is synthetic and takes about 100 lines of C code to fully implement. The fact that linear algebra computations occur in scientific computing has led to a multi-vendor effort to write performance-optimized code. The result typically runs 10 to 100 times faster but also takes significantly more lines. In this case hpl is around 34 thousand lines and after including the OpenBLAS subroutine library totals 3 million. Given how much performance improvement can be achieved, already optimized subroutine libraries are convenient when comparing the performance of computer hardware.
In addition to video encoding, another area where optimized subroutine libraries exist that could be used for benchmarking computer hardware is encryption. Note, however, that many of these algorithms were actually designed with the instruction sets of certain CPUs in mind, so the comparisons aren't always as fair.
We are even getting to the point where web browsers contain significant amounts of optimized code. This can be demonstrated by comparing the difference in speed of Chrome, Safari, Edge and Firefox when rendering complicated a JavaScript page on identical hardware. From the users point of view, the hardware is as fast as the fastest web browser which runs on it. A modern web browser for the Pi would simultaneously use all four cores and might generate enough heat to require a heatsink.
Currently most Pi 3's are running a 32-bit version of Raspbian that is binary compatible with the single core ARMv6 architecture. While such code runs slower than software optimized for the multi-core ARMv8 architecture, the advantage is that a heatsink is often not required to prevent throttling.
DonJuan692006
Re: Pi3 Configuration, Overclocking, Stability Testing & Cooling
Sat Sep 09, 2017 8:49 pm
I've been using a lot of the information from here for my own cooling testing project. I wanted to drop a little some scripts to help out with testing that I've been using
This one reformats the measure_temp output to display in Celsius and Fahrenheit.
#!/bin/bash
tm=`/opt/vc/bin/vcgencmd measure_temp`
tc=`echo $tm| cut -d '=' -f2 | sed 's/..$//'`
tf=$(echo "scale=2;((9/5) * $tc) + 32" |bc)
cs=`/opt/vc/bin/vcgencmd measure_clock arm`
echo temp = $tc\°C \($tf\°F\)
echo clock = $cs
This one for executing tests and grabbing the temps/clock without using an infinite loop.
trap 'pkill -P "$pid"' SIGINT	#to terminate stress if shell is cancelled
stress -c 4 -t 1800 &		#runs test as background process
pid=$!				#captures PID of test
while kill -0 $pid; do		#runs the loop until the PID of the test is gone (test finishes or script cancelled)
sleep 5
done
Sat Sep 09, 2017 9:04 pm
How about this one liner
awk '{print ((($1/5)*9)/1000)+32;}' /sys/devices/virtual/thermal/thermal_zone0/temp
DonJuan692006
Sat Sep 09, 2017 9:39 pm
It's only about halfway to the script I'm using.
DonJuan692006
Sun Sep 10, 2017 1:41 am
Hey Rive, don't want to jack your thread, but it's the one that consistently comes up when searching for Raspberry Pi cooling.
I set out on a quest to find a similar heatsink and managed to find one from here that fits and has supporting test data to show it's actually an efficient cooler. I was concerned with clearance between the bottom of the cooler and the board, so I picked up a hunk of copper from this fleBay sale. The surface of the plate was pretty wavy, so, after I cut out a 30x30mm chunk, I spent some time (read as about 3 hours) following the lapping process and got it pretty flat. I used Arctic Alumina thermal adhesive to fix the plate to the heatsink and then the heatsink assembly to the CPU. I've ran some tests and I'm pretty happy with the results. I'm using a LEGO case I built to help with funneling the air from my fan, more on that in this thread.
Running stress!
Average Temp - 34.66°C
pi@retropie:~ $ ./stress.sh
stress: info: [1026] dispatching hogs: 4 cpu, 0 io, 0 vm, 0 hdd
temp = 26.3°C (79.34°F)
clock = frequency(45)=600064000
temp = 31.1°C (87.98°F)
clock = frequency(45)=1300000000
clock = frequency(45)=1300002000
temp = 32.2°C (89.96°F)
temp = 32.7°C (90.86°F)
temp = 33.2°C (91.76°F)
temp = 33.8°C (92.84°F)
temp = 34.3°C (93.74°F)
clock = frequency(45)=1299998000
temp = 34.9°C (94.82°F)
temp = 35.4°C (95.72°F)
temp = 35.9°C (96.62°F)
Running CPUburn!
Average Temp - 42.85°C
pi@retropie:~ $ ./burn.sh
temp = 27.3°C (81.14°F)
clock = frequency(45)=1300134000
temp = 36.5°C (97.70°F)
temp = 38.1°C (100.58°F)
temp = 38.6°C (101.48°F)
temp = 39.2°C (102.56°F)
temp = 39.7°C (103.46°F)
temp = 40.2°C (104.36°F)
temp = 40.8°C (105.44°F)
temp = 41.3°C (106.34°F)
temp = 41.9°C (107.42°F)
temp = 42.4°C (108.32°F)
temp = 42.9°C (109.22°F)
temp = 43.5°C (110.30°F)
temp = 44.0°C (111.20°F)
temp = 44.5°C (112.10°F)
temp = 45.1°C (113.18°F)
