13th May 2016
https://www.raspberrypi.org/blog/anothe ... e-raspbian
Main highlights:
Bluetooth
SD Card Copier
Linux Kernel 4.4
13th May 2016 Changes to the Raspbian Jessie Desktop
Re: 13th May 2016 Changes to the Raspbian Jessie Desktop
Is the new Raspbian image already on the download page? I only see the older Raspbian image from March 2016.
Same with
… list zero updates for me so far.
Is there a command to see if the Pi runs the recent Jessie? I know "uname -a", however it lists the kernel (4.1.19-v7) but not the word "Jessie". :-)
Same with
sudo apt-get update
sudo apt-get dist-upgrade
https://www.raspberrypi.org/downloads/raspbianFidelius wrote:Is the new Raspbian image already on the download page? I only see the older Raspbian image from March 2016.
Same with… list zero updates for me so far.Code: Select all
sudo apt-get update sudo apt-get dist-upgrade
RASPBIAN JESSIE
Full desktop image based on Debian Jessie
Version:May 2016
Release date:2016-05-10
Kernel version:4.4
Kudos, congratulations and thanks to @joan, a regular contributor here, for the inclusion of the pigpio library.
Thanks Fruitoftheloom, now the download page does allow to download the new version indeed.
Anybody already did an "sudo apt-get dist-upgrade" ?
Tried it, but the repo has not been updated yet.Fidelius wrote:Anybody already did an "sudo apt-get dist-upgrade" ?
Just try again later today or so.
DirkS, will do, thanks!
See https://www.raspberrypi.org/blog/anothe ... nt-1258088Fidelius wrote:DirkS, will do, thanks!
And they *have* caught up now
I came here to post exactly that.
'unable to locate package piclone'
Have to try again later?
You have to run 'sudo apt-get update' first.Forris wrote:'unable to locate package piclone'
I just installed it, so it's available now.
Apart from the desktop stuff there are some useful changes 'under the hood'.
Kernel + modules are split off from raspberrypi-bootloader into a separate package (raspberrypi-kernel)
And there is a new package with the kernel headers: raspberrypi-kernel-headers.
raspberrypi-bootloader now only contains bootcode.bin, start*.elf and fixup*.dat
Yes, I did that. The other 2 items installed ok, but not piclone (even tried it on it's own).DirkS wrote:You have to run 'sudo apt-get update' first.Forris wrote:'unable to locate package piclone'
LIVE UPDATE: Done it now!
- ShiftPlusOne
Well spotted. The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.DirkS wrote:Apart from the desktop stuff there are some useful changes 'under the hood'.
Another real gem, tucked away at the end of the write-up:
When flashing a new Raspbian image, the file system will automatically be expanded to use all the space on the card when it is first booted.
Is it possible to disable Wlan and Bluetooth on a Pi3 with this new Raspbian release?
Or do I still have to use the previous apporach which works well but is uneasy to handle:
/etc/modprobe.d/raspi-blacklist.conf
# Wlan
blacklist brcmfmac
blacklist brcmutil
# Bluetooth
blacklist btbcm
blacklist hci_uart
We have a raspberrypi-kernel-headers package now ??
- ShiftPlusOne
Unfortunately, it has a huge number of files and dpkg will calculate an md5 digest for each of them, so it takes forever to install.ghans wrote:We have a raspberrypi-kernel-headers package now ??
I googled that, it's a most welcome addition.ShiftPlusOne wrote:The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.
- ShiftPlusOne
Note that raspberrypi-kernel-headers would need to be installed first. Otherwise, dkms will try to pull in the wrong headers package.gregeric wrote:I googled that, it's a most welcome addition.ShiftPlusOne wrote:The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.
I am already running 4.4.9, is there an "apt-get install" just for the bt (replace blueman), and sd copier? I do not want to do a dist-upgrade.
Bluetooth
SD Card Copier
DNPNWO
I think you can do that with just update / upgrade and then install picloneRive wrote:I am already running 4.4.9, is there an "apt-get install" just for the bt (replace blueman), and sd copier? I do not want to do a dist-upgrade.
- ShiftPlusOne
Why not exactly? The theme bug you reported a while bag has been fixed.Rive wrote:I do not want to do a dist-upgrade.
When I "sudo poweroff" the Pi3, in contrast to former Raspbians the green (SD?) LED really turns off after some blinking, leaving only the red power LED on.
That's nice.
That's nice.
I am on the rpi-update (4.4.9), is the dist-upgrade the exact same?ShiftPlusOne wrote:Why not exactly? The theme bug you reported a while bag has been fixed.Rive wrote:I do not want to do a dist-upgrade.
DNPNWO
