Folk at raspberrypi have been busy and now we have pure USB boot, with no SD card required - take a look at
https://github.com/raspberrypi/document ... des/msd.md
Just trying it now....
STICKY: USB boot now working on Pi3
Re: USB boot now working on Pi3
Still beta, but sounds like it is working based on recent updates.
https://github.com/raspberrypi/document ... /README.md
Proceed at your own risk, or contact Gordon to officially join the beta program.IMPORTANT
This is preliminary information used by the beta testers for the development of the bootcode for mass storage and ethernet boot, but it is currently incorrect and not working. If you'd like to join the beta test then please send your email to @gsholling on Twitter and I'll invite you to the Slack channel which we're using to discuss this...
Ok, have it working now ableit with no wifi - I'll get on the beta
Woah. That is the most awesome thing ive seen all day. Would this work with a pi 2
This signature intentionally left blank.
Not without SD on pi2 - the USB bootcode is in the 2837 of the pi3
https://www.raspberrypi.org/magpi/pi-3-interview/
Yup that works, boot time's a bit slow though...
https://youtu.be/Rn8YdD4RVNI
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
twitter @sahajsarup
skype srics1996
- Jim Manley
- Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
I think I found a few things that are going to trip up less sophisticated folks if this isn't going to ultimately be encapsulated in a script or GUI utility. I'll let Gordon know I'd like to help with the beta, but that may take a day or three to get signed up, so in the meantime:
A should be added after and the partition table printout, once the table has been verified.
If a USB device with any existing partitions is connected, the system will mount them, e.g., /dev/sda1 for an existing FAT partition on a Raspbian distro installed via NOOBS. Even though you say you're starting with a clean slate, I'm sure someone is going to do this without understanding that it's happening.
Any random USB stick is almost certainly going to have something on it, possibly with multiple partitions. I would include a stronger caveat that the drive must be partitioned and had its distro created from the Raspbian running from the (micro-)SD card used to boot the Pi 3.
It should also be noted to more pedestrian users that the entire process has to be done using a Pi 3, because I was being a bit lazy and just wanted to see if it would work, so I did everything on Pi 2B, except for the final boot-up, which was done on a Pi 3. I haven't repeated it to see if it's the actual proximal cause, but when I booted a Pi 3 with the resulting USB stick, the Pi 3 didn't know that it had a WiFi interface built-in. That's probably because the Pi 2 didn't, so the Pi 3 booted from the USB drive and apparently didn't automagically load the driver and configure the associated files for the built-in WiFi interface. Yes, we all know why this is, but a less expert user won't, and while this sequence makes no sense to us here, or anyone who follows the directions to a tee, guess what kinds of crazy things non-expert users do right away?
Other than that, it works as advertised and I'm a very happy camper! Thanks to The Team!
A
(parted) quit
(parted) print
The best things in life aren't things ... but, a Pi comes pretty darned close!
Doesn't absolutely have to - I didn't. I just burned a new raspbian .img to the USB drive as that's quicker.Jim Manley wrote: I would include a stronger caveat that the drive must be partitioned and had its distro created from the Raspbian running from the (micro-)SD card used to boot the Pi 3.
All that's necessary on the USB drive is that :
- it has the new bootfile.bin and start.elf files on the fat32 partition
- cmdline.txt & /etc/fstab both reference /dev/sda2 instead of /dev/mmcblk0p2 - this step is normal for those of us already running usb root
and you have to have booted the pi3 at least once with the program_usb_boot_mode=1 line in config.txt
You did nothing wrong, the lack of wifi is a bug in the current USB boot firmware (yes, its beta)It should also be noted to more pedestrian users that the entire process has to be done using a Pi 3, because I was being a bit lazy and just wanted to see if it would work, so I did everything on Pi 2B, except for the final boot-up, which was done on a Pi 3. I haven't repeated it to see if it's the actual proximal cause, but when I booted a Pi 3 with the resulting USB stick, the Pi 3 didn't know that it had a WiFi interface built-in. That's probably because the Pi 2 didn't, so the Pi 3 booted from the USB drive and apparently didn't automagically load the driver and configure the associated files for the built-in WiFi interface.
I've now got net boot to work, wifi doesn't work either, but no big deal. Now trying to get iscsi boot with no sd card working.
Does not work an an external (mechanical) hard drive, didn't try it with a externally powered usb hub tho. I am guessing since max_usb_current is NOT a default setting and can only be read from config.txt, and config.txt in this case resides in the hdd... It never boots!
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Check with Jim Manley on that. Last I heard from him, he was using a WD Pi Drive successfully with USB boot.ric96 wrote:Does not work an an external (mechanical) hard drive, didn't try it with a externally powered usb hub tho. I am guessing since max_usb_current is NOT a default setting and can only be read from config.txt, and config.txt in this case resides in the hdd... It never boots!
yup, that should work, its meant to run at around 400-600mA, ie without max_usb_currentW. H. Heydt wrote:Check with Jim Manley on that. Last I heard from him, he was using a WD Pi Drive successfully with USB boot.ric96 wrote:Does not work an an external (mechanical) hard drive, didn't try it with a externally powered usb hub tho. I am guessing since max_usb_current is NOT a default setting and can only be read from config.txt, and config.txt in this case resides in the hdd... It never boots!
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
It is my understanding that the RPi 3B has the default setting of max_usb_current (1.2A) set in hardware. So no need to use that command in config.txt anymore unless you have a B+ or 2B.ric96 wrote:yup, that should work, its meant to run at around 400-600mA, ie without max_usb_currentW. H. Heydt wrote:Check with Jim Manley on that. Last I heard from him, he was using a WD Pi Drive successfully with USB boot.ric96 wrote:Does not work an an external (mechanical) hard drive, didn't try it with a externally powered usb hub tho. I am guessing since max_usb_current is NOT a default setting and can only be read from config.txt, and config.txt in this case resides in the hdd... It never boots!
Not trying to derail the thread but curious about a couple things now that this is possible:
1. Will booting from an external device possibly improve file system corruption issues currently experienced using an SD card when power is interrupted?
2. If booting from an external device, could the SD card slot now be used for storage?
Henry
Henry
+1 the RPi 3B is 1200mA by defaultklricks wrote: It is my understanding that the RPi 3B has the default setting of max_usb_current (1.2A) set in hardware. So no need to use that command in config.txt anymore unless you have a B+ or 2B.
Though as always a very good PSU/USB Cable is a must.....
Maybe...henryhanselscott wrote:1. Will booting from an external device possibly improve file system corruption issues currently experienced using an SD card when power is interrupted?
yes, SD is still accessable as /dev/mmcblk0p1 - but now you can hot swap it without worrying about the OS2. If booting from an external device, could the SD card slot now be used for storage?
Interesting indeed.
I expect general system responsiveness to be improved, even on a rotating HDD. Any hints about that?
IF you use a device that doesn't do wear leveling (e.g. an HDD), then it should reduce, but not eliminate the problem as there will be less time when the filesystem isn't in a consistent state, plus most of the inconsistencies have a decent chance of being fixed by fsck.henryhanselscott wrote: 1. Will booting from an external device possibly improve file system corruption issues currently experienced using an SD card when power is interrupted?
Note that this is *reduce* the issue, not eliminate it.
It is, but you can do that (USB root filesystem) on any pi without this new USB bootepoch1970 wrote:Interesting indeed.
-this is all about removing any reliance on SD even for pre-boot
Fun fact, ~15 seconds to rainbow screen vs almost immediately when using sd card.
Ps. Anyone having trouble with Bluetooth?
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
I noticed that, but not 15 seconds, about 6-7 for me - do you have multiple USB devices plugged in, or a hub?ric96 wrote:Fun fact, ~15 seconds to rainbow screen vs almost immediately when using sd card.
Delays are by design, see below for the many boot process delays:
If enabled: Check primary SD for bootcode.bin
Success - Boot
Fail - timeout (5 SECONDS)
If enabled: Check secondary SD
Sucess - Boot
If OTG pin == 0
Enable USB, wait for valid USB 2.0 devices ( 2 SECONDS )
Device found:
If device type == hub
Recurse for each port
If device type == (mass storage or LAN9500)
Store in list of devices
Recurse through each MSD
If bootcode.bin found boot
Recurse through each LAN9500
DHCP / TFTP boot
else (Device mode boot)
Enable device mode and wait for host PC to enumerate
and that first 5 second delay can be eliminated entirely if you don't need occasional SD boot:
If there is no SD card inserted the SD boot mode takes five seconds to fail.
To reduce this and fall back to USB more quickly, you can either insert an SD card with nothing on it or use the program_gpio_bootmode OTP to only enable USB.
- startrek.steve
so...
what are the benefits of a full USB boot?
I was thinking speed, but not looking that way...
Steve
Steve
Pi 2 running LibreElec Krypton, Pi 2 running Wheezy Desktop, Pi 1 headless Wheezy, downloading Radio, Pi 1 running Picore headless Media Server, Pi Zero to be an Old Time Radio Project. Pi 3 testing. Pi Zero W downloading Radio shows headless.
Hard Drives have greater read/write life then do SD Cards / Flash Drives..startrek.steve wrote:so...
Steve
Please read the docs.
I don't know whether just having USB mass storage enabled is faster than, but at least it would avoid some of the timeouts.
By default this is SD card boot followed by USB device boot. Subsequently, the boot ROM checks to see if program_gpio_bootmode OTP bit is set, if it is then it reads either GPIOs 22-26 or 39-43 (depending on the value of program_gpio_bootpos) and uses those bits to disable boot modes. This means it is possible to use a hardware switch to switch between different boot modes if there are more than one available.
So you can control which boot devices to check via GPIOs, or only enable certain modes in the OTP in the first place.If there is no SD card inserted the SD boot mode takes five seconds to fail. To reduce this and fall back to USB more quickly, you can either insert an SD card with nothing on it or use the program_gpio_bootmode OTP to only enable USB.
Now this, i like, good old jumper days...6by9 wrote: So you can control which boot devices to check via GPIOs, or only enable certain modes in the OTP in the first place.
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
