EchoEum
Help Request: wlan1 > wlan0 & eth0
Wed Jan 04, 2017 7:50 pm
I would like to route the connection from wlan1 to wlan0 and eth0.
I would rather use wlan0 to wlan1 and eth0 but haven't worked out the drivers for my Netgear3100m USB.
I have successfully followed guides for wlan1 to wlan0 and wlan1 to eth0 but am unable to get both to work at the same time.
These are the guides that I followed.
https://frillip.com/using-your-raspberr ... h-hostapd/
viewtopic.php?t=132674
I believe the issues is related to the "listen-address" in the /etc/dnsmasq.conf file but do not know how to resolve it.
It seems that both interfaces can't be listening to the same address.
Thanks in advance for any advice.
Cheers!
epoch1970
Re: Help Request: wlan1 > wlan0 & eth0
Wed Jan 04, 2017 10:43 pm
I don't really understand what you want to achieve.
What about bridging wlan0 and eth0 into a br0 interface? Then you could achieve "wlan1 > br0" and that would mean "wlan1 to br0 or any other machine behind it via Ethernet or wifi"
A Linux bridge is like a physical Ethernet switch, everything passes through it.
EchoEum
Wed Jan 04, 2017 11:49 pm
Thanks, I'll give that a go. I've never configured a br0 interface before. :) hadn't stumbled upon it yet with my google searching.
My end goal is to capture wifi and then rebroadcast is via a new Wifi access point and the eathernet port.
