harish49477`
how to install b9 application on raspbian jessie
Tue Feb 28, 2017 5:00 pm
HI ktb, I wanted to run this dual screen project so that i can use my b9 3d printer using raspberry pi 3 and i also failed to install the b9 application on raspbian jessie. Can u help in installing (https://github.com/yuenar/B9Creator-QT5.X) pls
ktb
Re: how to install b9 application on raspbian jessie
Tue Feb 28, 2017 5:02 pm
Sure. I have to run some errands. BBL.
ktb
Wed Mar 01, 2017 1:59 pm
Small update: no good news yet.
I've tried a few different approaches to getting that application to build, so far without success on the PI3B.
I did get the application to run on x86_64 Ubuntu 17.04 with Qt 5.7.1. It spits out a bunch of warnings/errors, but still seems to work. I don't have the required printer hardware, so who knows? I don't think this software was ever written for or tested on any ARM Linux SBC, certainly not any Raspberry Pi models. Is there a reason that you thought it would or should work on a Raspberry Pi? I have my doubts that you're ever going to get support here -- https://github.com/yuenar/B9Creator-QT5.X/issues/1
Beyond getting this to build (if I'm eventually successful), I don't think I can be of any further help in making sure it actually works for you. However, I do accept hardware donations. :)
Have you read through the following threads?
https://www.b9c.com/forum/viewtopic.php?f=21&t=869
https://www.b9c.com/forum/viewtopic.php?t=140
Have you tried TinyPrint?
https://github.com/YggdrasiI/TinyPrint
TinyPrint was apparently written with Raspberry Pi support in mind.
I'm currently trying to get B9Creator-QT5.X to build using Qt 5.7.1 from Raspbian Stretch. If I fail, you're on your own as far as B9Creator-QT5.X is concerned.
harish49477`
Wed Mar 01, 2017 2:48 pm
its a big update as i was looking for ur feedback on this application, i am glad to know u worked on it
http://b9creator.pbworks.com/w/page/698 ... 20Software
this link also gives so details abt the installation of the application but not on raspberrypi3 and Thanks for going through all the effort
ktb
Wed Mar 01, 2017 5:06 pm
You're welcome.
Thanks for the link.
I did get past the problem captured in the screenshot from that GitHub issue.
I tried to switch out GL headers for GLES headers, but that wasn't a solution -- seemingly due to a bunch of usage of GLU stuff in the project (maybe other issues too). I think that with some effort the project could be ported to GLES, but I'm not interested in doing that.
I wonder if building Qt from source might help (and not configuring it with -opengl es2), but building Qt on a Pi has never been fun (it's not fun on a desktop/laptop either, IMO). The last time I built Qt on a Pi, it took well over a day to finish and it wasn't even a full QT5 build.
Beyond that, I keep hitting errors such as:
/usr/include/GL/glext.h:468: error: conflicting declaration ‘typedef ptrdiff_t GLsizeiptr’
 typedef ptrdiff_t GLsizeiptr;
/usr/include/GLES3/gl31.h:73: previous declaration as ‘typedef khronos_ssize_t GLsizeiptr’
 typedef khronos_ssize_t GLsizeiptr;
/usr/include/GL/glext.h:469: error: conflicting declaration ‘typedef ptrdiff_t GLintptr’
 typedef ptrdiff_t GLintptr;
/usr/include/GLES3/gl31.h:74: previous declaration as ‘typedef khronos_intptr_t GLintptr’
 typedef khronos_intptr_t GLintptr;
I even tried hacky things like modifying the types in those headers so they match.
Unless anybody has some brilliant ideas, suggestions or can point out some obvious errors I'm making I think I'm gonna call this effort a failure and be done with it.
harish49477`
Wed Mar 01, 2017 5:39 pm
thanks for ur time n effort.
i found a link abt the /usr/include/GL/glext.h:468: error kindly go-through onces
http://stackoverflow.com/questions/3956 ... del-b-v1-2
ktb
Thu Mar 02, 2017 12:47 am
harish49477` wrote:thanks for ur time n effort.
Unfortunately, that's not really the same problem. I also ran into errors similar to those with one of the other approaches I took.
ktb
Fri Mar 03, 2017 8:35 pm
To quote my deplorable president, this update is INCREDIBLY TERRIFIC! It's YUGE!
B9Creator cross-compiled on Ubuntu 17.04 and running on Raspbian Stretch with Qt 5.7.1 (-platform xcb, 60 FPS), vc4-fkms-v3d and the 7" Touchscreen Display!
I have notes for the whole process in case you're interested.
harish49477`
Sat Mar 04, 2017 3:29 am
wow really that a great news indeed. pls do share the notes for the whole process im interested and eager to try it out
ktb
Sat Mar 04, 2017 10:15 am
I hope this works for you. I tried to give as much information as possible without writing a completely new tutorial for you.
### B9Creator on Raspberry Pi 3 B
### Let me preface this by saying that I do not have much experience with Qt.
### It may be possible to improve the configuration and approach I took here,
### but this is what worked for me after over 20 attempts just to get Qt to
### finish building successfully. My previous approach to get B9Creator running
### on the Raspberry Pi 3 B involved porting the GL code to GLES, but after
### completely converting two of the files in the project to GLES, I got tired
### of working on it. Being that I have no use for this software and was just
### treating this as a small challenge, I decided porting the code wasn't worth
### it and instead tried to see if I could get the existing GL code working.
### I used guides and information at the following links to get this done:
### - https://www.ics.com/blog/configuring-qt-creator-raspberry-pi
### - https://wiki.qt.io/RaspberryPi2EGLFS
### - https://wiki.qt.io/Building_Qt_5_from_Git
### - http://doc.qt.io/qt-5/linux-requirements.html
### - http://doc.qt.io/qt-5/configure-options.html
### - and other Qt documentation
### - I used raspberrypi.local to connect to my Raspberry Pi 3 B, but you can
###   use an IP address instead.
# 1. Install Qt on the cross-compile host system
## - Qt 5.7.1 with qtcreator packages installed from APT on Ubuntu 17.04 x86_64
# 2. Install and configure Raspbian on a micro SD card for the Raspberry Pi 3 B
## - I began with Raspbian Jessie (2017-01-11-raspbian-jessie.img)
## - I ran rpi-update (kernel 4.9.9-v7+) and upgraded to Raspbian Stretch
## - I tested the vc4-fkms-v3d overlay with the official 7" Touchscreen Display
## - I installed Qt build dependencies on the Raspberry Pi 3 B (You'll have to
##   figure out which packages you need, refer to the online Qt build docs and
##   compare your Qt configure output to my configure output included below in
##   step 4.)
## - My cmdline.txt:
video=HDMI-1:640x480M@60m video=DSI-1:800x480M@60m net.ifnames=0 dwc_otg.lpm_enable=0 console=tty1 fbcon=rotate:2 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
## - My config.txt:
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=sd_overclock=63
dtparam=audio=on
audio_pwm_mode=2
enable_uart=1
lcd_rotate=2
ignore_lcd=0
#gpu_mem=32
gpu_mem=128
#dtoverlay=vc4-kms-v3d,cma-256,rpi-ft5406
dtoverlay=vc4-fkms-v3d,cma-192,rpi-ft5406
arm_freq=1200
arm_freq_min=600
core_freq=250
core_freq_min=250
h264_freq=300
isp_freq=250
v3d_freq=500
avoid_pwm_pll=1
sdram_freq=450
sdram_schmoo=0x02000020
over_voltage=2
over_voltage_sdram=2
decode_MPG2=0x3ab16f03
decode_WVC1=0x438a78fb
# 3. Create sysroot and download the toolchain on the cross-compile host system:
## - Commands on Ubuntu 17.04 x86_64 host:
mkdir ~/raspi
cd ~/raspi
mkdir sysroot sysroot/usr sysroot/opt
rsync -avz pi@raspberrypi.local:/lib sysroot
rsync -avz pi@raspberrypi.local:/usr/include sysroot/usr
rsync -avz pi@raspberrypi.local:/usr/lib sysroot/usr
rsync -avz pi@raspberrypi.local:/opt/vc sysroot/opt
wget https://raw.githubusercontent.com/riscv/riscv-poky/master/scripts/sysroot-relativelinks.py
chmod +x sysroot-relativelinks.py
./sysroot-relativelinks.py sysroot
git clone https://github.com/raspberrypi/tools
## - I'm not sure if the following is necessary, but it helped get past an
##   error on one of my Qt compile attempts
cd sysroot/usr/include/EGL
ln -s ../../../opt/vc/include/EGL/eglext_brcm.h eglext_brcm.h
cd ../../../..
# 4. Build a cross-compiled Qt 5.7.1 for Raspberry Pi 3 B on the host system
wget http://download.qt.io/official_releases/qt/5.7/5.7.1/single/qt-everywhere-opensource-src-5.7.1.tar.gz
tar xzf qt-everywhere-opensource-src-5.7.1.tar.gz
cd qt-everywhere-opensource-src-5.7.1
./configure -release -opengl desktop -device linux-rpi3-vc4-g++ -device-option CROSS_COMPILE=~/raspi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- -sysroot ~/raspi/sysroot -opensource -confirm-license -prefix /usr/local/qt5pi -extprefix ~/raspi/qt5pi -hostprefix ~/raspi/qt5 -v -nomake examples -nomake tests -no-use-gold-linker -skip webchannel -skip webengine -skip wayland -skip multimedia -skip winextras -skip websockets -skip webview -skip location -skip script
#    Configure summary
# Building on:   linux-g++ (x86_64, CPU features: mmx sse sse2)
# Building for:  devices/linux-rpi3-vc4-g++ (arm, CPU features: neon)
# Platform notes:
#             - Also available for Linux: linux-clang linux-kcc linux-icc linux-cxx
# qmake vars .......... styles += mac fusion windows QT_LIBS_DBUS = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -ldbus-1 QT_CFLAGS_DBUS = -I/home/ktb/raspi/sysroot/usr/include/dbus-1.0 -I/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf/dbus-1.0/include QT_HOST_CFLAGS_DBUS = -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include QT_CFLAGS_GLIB = -pthread -I/home/ktb/raspi/sysroot/usr/include/glib-2.0 -I/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf/glib-2.0/include QT_LIBS_GLIB = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -lgthread-2.0 -pthread -lglib-2.0 QT_CFLAGS_PULSEAUDIO = -D_REENTRANT -I/home/ktb/raspi/sysroot/usr/include/glib-2.0 -I/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf/glib-2.0/include QT_LIBS_PULSEAUDIO = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -lpulse-mainloop-glib -lpulse -lglib-2.0 QMAKE_CFLAGS_FONTCONFIG = -I/home/ktb/raspi/sysroot/usr/include/freetype2 QMAKE_LIBS_FONTCONFIG = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -lfontconfig -lfreetype QMAKE_INCDIR_LIBUDEV =  QMAKE_LIBS_LIBUDEV = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -ludev QMAKE_INCDIR_XKBCOMMON_EVDEV =  QMAKE_LIBS_XKBCOMMON_EVDEV = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -lxkbcommon QMAKE_LIBINPUT_VERSION_MAJOR = 1 QMAKE_LIBINPUT_VERSION_MINOR = 6 QMAKE_INCDIR_LIBINPUT =  QMAKE_LIBS_LIBINPUT = -L/home/ktb/raspi/sysroot/usr/lib/arm-linux-gnueabihf -linput QMAKE_X11_PREFIX = /usr DEFINES += QT_NO_XKB QMAKE_XKB_CONFIG_ROOT = /usr/share/X11/xkb sql-drivers =  sql-plugins =  sqlite sqlite2 tds qmake switches .........
# Build options:
#   Configuration .......... accessibility accessibility-atspi-bridge alsa audio-backend c++11 clock-gettime clock-monotonic compile_examples concurrent cross_compile cups dbus dbus-linked doubleconversion egl eglfs eglfs_egldevice eglfs_gbm egl_x11 enable_new_dtags evdev eventfd fontconfig full-config gbm getaddrinfo getifaddrs glib gstreamer-1.0 iconv inotify ipv6ifname kms large-config largefile libinput libudev linuxfb medium-config minimal-config mremap mtdev neon opengl openssl openvg png poll_ppoll posix_fallocate precompile_header pulseaudio qpa qpa reduce_exports release rpath shared small-config system-freetype system-harfbuzz system-jpeg system-png system-zlib threadsafe-cloexec tslib xcb xcb-glx xcb-plugin xcb-render xcb-xlib xinput2 xkbcommon-evdev xkbcommon-qt xlib xrender
#   Build parts ............ libs
#   Mode ................... release
#   Using sanitizer(s)...... none
#   Using C++ standard ..... c++11
#   Using gold linker....... no
#   Using new DTAGS ........ yes
#   Using PCH .............. yes
#   Using LTCG ............. no
#   Target compiler supports:
#     Neon ................. yes
# Qt modules and options:
#   Qt D-Bus ............... yes (linked to dbus-1)
#   Qt Concurrent .......... yes
#   Qt GUI ................. yes
#   Qt Widgets ............. yes
#   Large File ............. yes
#   QML debugging .......... yes
#   Use system proxies ..... no
# Support enabled for:
#   Accessibility .......... yes
#   ALSA ................... yes
#   CUPS ................... yes
#   DoubleConversion........ yes (bundled copy)
#   Evdev .................. yes
#   FontConfig ............. yes
#   FreeType ............... yes (system library)
#   Glib ................... yes
#   GStreamer .............. yes (1.0)
#   GTK platformtheme ...... no
#   HarfBuzz ............... yes (system library)
#   Iconv .................. yes
#   ICU .................... no
#   Image formats:
#     GIF .................. yes (plugin, using bundled copy)
#     JPEG ................. yes (plugin, using system library)
#     PNG .................. yes (in QtGui, using system library)
#   libinput................ yes
#   Logging backends:
#     journald ............... no
#     syslog   ............... no
#   mtdev .................. yes (system library)
#   Networking:
#     getaddrinfo .......... yes
#     getifaddrs ........... yes
#     IPv6 ifname .......... yes
#     libproxy.............. no
#     OpenSSL .............. yes (loading libraries at run-time)
#   OpenGL / OpenVG:
#     EGL .................. yes
#     OpenGL ............... desktop
#     OpenVG ............... yes-auto
#   PCRE ................... system
#   pkg-config ............. yes
#   PulseAudio ............. yes
#   QPA backends:
#     DirectFB ............. no
#     EGLFS ................ yes
#       EGLFS i.MX6 ........ no
#       EGLFS i.MX6 Wayland. no
#       EGLFS EGLDevice .... yes
#       EGLFS GBM .......... yes
#       EGLFS Mali ......... no
#       EGLFS Raspberry Pi . no
#       EGLFS X11 .......... yes
#     LinuxFB .............. yes
#     Mir client............ no
#     XCB .................. yes (system library)
#       EGL on X ........... yes
#       GLX ................ yes
#       MIT-SHM ............ yes
#       Xcb-Xlib ........... yes
#       Xcursor ............ yes (loaded at runtime)
#       Xfixes ............. yes (loaded at runtime)
#       Xi2 ................ yes
#       Xrandr ............. yes (loaded at runtime)
#       Xrender ............ yes
#       XKB ................ no
#       XShape ............. yes
#       XSync .............. yes
#   Session management ..... yes
#   SQL drivers:
#     DB2 .................. no
#     InterBase ............ no
#     MySQL ................ no
#     OCI .................. no
#     ODBC ................. no
#     PostgreSQL ........... no
#     SQLite 2 ............. yes (plugin)
#     SQLite ............... yes (plugin, using bundled copy)
#     TDS .................. yes (plugin)
#   tslib .................. yes
#   udev ................... yes
#   xkbcommon-x11........... yes (bundled copy, XKB config root: /usr/share/X11/xkb)
#   xkbcommon-evdev......... yes
#   zlib ................... yes (system library)
# NOTE: Qt is using double for qreal on this system. This is binary incompatible against Qt 5.1.
# Configure with '-qreal float' to create a build that is binary compatible with 5.1.
# Qt is now configured for building. Just run 'make'.
# Once everything is built, you must run 'make install'.
# Qt will be installed into /usr/local/qt5pi
# Prior to reconfiguration, make sure you remove any leftovers from
# the previous build.
make -j4
make install
cp qtbase/bin/rcc ~/raspi/qt5pi/bin/
cd ..
# 5. Install Qt from the cross-compile host system to the Pi.
rsync -avz qt5pi pi@raspberrypi.local:/usr/local
# 6. Build an example on the cross-compile host and install it on the Pi
cd qt-everywhere-opensource-src-5.7.1/qtbase/examples/opengl/qopenglwidget
~/raspi/qt5/bin/qmake
make
scp qopenglwidget pi@raspberrypi.local:/home/pi
# 7. On the Pi3B, Update the shared library cache with the qt5pi directory location:
echo /usr/local/qt5pi/lib | sudo tee /etc/ld.so.conf.d/qt5pi.conf
sudo ldconfig
# 8. Set some Qt environment variables and run qopenglwidget (in /home/pi) on the Raspberry Pi 3 B.
export QT_LOGGING_RULES=qt.qpa.*=true
export QT_QPA_PLATFORM=xcb
./qopenglwidget
## Note: You can also use "-platform xcb" when running your applications
### Refer to the instructions from step 5 "Configure Qt Creator" and on at
### https://www.ics.com/blog/configuring-qt-creator-raspberry-pi for
### instructions on configuring Qt Creator on the cross-compile host in order
### to build B9Creator on the cross-compile host system,  and then deploy and run
### it on the Raspberry Pi 3 B
