ahoang68
@ symbol and " are mixed up
Thu Jul 06, 2017 7:32 pm
Hi there,
I have a new Raspberry PI3 and try it with 2 different wireless keyboards. I have the same issue. The @ (at symbol) and " (double quote) are mixed up. I wonder if anyone has the same issues or just me.
pcmanbob
Re: @ symbol and " are mixed up
Thu Jul 06, 2017 9:05 pm
Hi.
I believe raspbian defaults to a UK keyboard layout may be the keyboards you have are not UK layout and you need to change the keyboard setting in raspi-config.
pi_everalm
Thu Jul 06, 2017 10:10 pm
Typically this is seen if you are using a UK physical keyboard but a US logical keyboard mapping
davidcoton
Thu Jul 06, 2017 11:05 pm
pi_everalm wrote:Typically this is seen if you are using a UK physical keyboard but a US logical keyboard mapping
or vice-versa.
Imperf3kt
Contact: Twitter
Thu Jul 06, 2017 11:14 pm
I have this same issue and it is random. One boot it was switched, then I closed my terminal and reopened it and they weren't.
I've given up trying to set a locale and just keep a text file with ~ in it as I cannot find that on the keyboard at all when it does this.
55:55:44:44:4C
52:4C:52:42:41
davidcoton
Thu Jul 06, 2017 11:21 pm
It's not the locale that affects the keyboard mapping, because you might want to use a keyboard that does not match the rest of your locale. IIRC there is a specific selection in raspi-config to let the keyboard driver know the physical layout of your keyboard (which is actually more than locale information anyway).
Imperf3kt
Contact: Twitter
Thu Jul 06, 2017 11:35 pm
Doesn't explain why the keyboard switches between the two symbols by merely closing a terminal, then opening it again.
55:55:44:44:4C
52:4C:52:42:41
davidcoton
Fri Jul 07, 2017 12:13 am
Imperf3kt wrote:Doesn't explain why the keyboard switches between the two symbols by merely closing a terminal, then opening it again.
That is not the OP's issue. Your experience is not necessarily related. (OP has not reported random switches, just consistently wrong setting.)
Have you tried to configure the keyboard, not just the locale?
alphanumeric
Fri Jul 07, 2017 10:03 am
I have my keyboard set to the correct English US, but when in a terminal window the @ (at symbol) and " (double quote) are swapped. Everywhere else seems fine. This is a recent development for me. Normally setting my keyboard to EN US fixes it and I'm good to go.
SeeGreatness
Sat Jul 08, 2017 3:04 pm
have you tryed running
sudo raspi-config
and then entering localisation
and then change keyboard layout
and just do the "happy hacking keyboard"
pcmanbob
Sat Jul 08, 2017 3:56 pm
SeeGreatness wrote:have you tryed running
sudo raspi-config
running that on my 2 of my pi's running jessie lite
returns these options
change locale
change timezone
change wifi country
no mention of keyboard in raspi-config that I can find.
one pi has initial build date of 2016-05-10 but has had dis-upgrade run several times
the other has initial build date of 2017-06-21 and never updated as far I remember
Ernst
Sat Jul 08, 2017 4:16 pm
sudo raspi-config
change locale
change timezone
change wifi country
To be able to change the keyboard you have to be working on a local connected keyboard :)
raspi-config will not give you the option if you use ssh to connect to the pi.
The road to insanity is paved with static ip addresses
Sat Jul 08, 2017 5:25 pm
Try: sudo dpkg-reconfigure keyboard-configuration in an LXterminal window or from the command line
pcmanbob
Sat Jul 08, 2017 8:04 pm
Thanks for that, must admit 99.9% of the time I connect to my pi's via ssh so its been a long time since I had to change a keyboard layout so things have probably change since the last time, shame the info on raspberry.org does not match the current raspi-config.
