k.elliott
Re: mini perl
Thu Dec 29, 2011 9:36 pm
Is anyone else interested in compiling perl for the Rpi device?
piglet
Re: mini perl
Thu Dec 29, 2011 9:49 pm
I'm pretty sure it's already been done – earlier this week someone posted a list of programming languages they've tested on the alpha board, and PERL was noted.
I can't remember the thread though
Re: mini perl
Thu Dec 29, 2011 11:06 pm
Check out the Wiki - there is a list of tested languages on there on there - its not complete though  -  I am sure many other will work.
Warringer
Re: mini perl
Fri Dec 30, 2011 2:56 pm
Should be possible to compile just about any language on/for the Pi. Everything you can also compile for a x86/x64 Linux.
k.elliott
Re: mini perl
Fri Dec 30, 2011 3:47 pm
Thank you very much, you have made me very happy... Daddy loves him some perl
Blars
Re: mini perl
Sat Dec 31, 2011 3:25 am
It runs Debian, and Debian uses perl quite a bit in many places.  You can't install debian without perl, but many of the standard perl libraries arn't installed unless needed.  (If you install anything other than a minimal debian, you probably wind up with the perl libraries.)
foo
Re: mini perl
Sat Dec 31, 2011 6:20 am
Not all JIT/native code compiled languages though.  That leaves things like SBCL (the best Lisp compiler) out, since they don't have an ARM back-end yet.
