repo
Re: No Wifi connection to Pi Zero W after Raspbian update
Mon Mar 05, 2018 8:55 pm
gnulove wrote:
Sun Mar 04, 2018 12:02 pm
If this entry is missing in the /etc/wpa_supplicant.conf:
scan_ssid=1
this is what I wrote earlier but latest update fixes wifi problems without need to add scan_ssid.
looks like they updated broadcom drivers few days ago.
unfortunately wifi fix breaks now bluetooth, my gues next update they will break wifi again but will fix bluetooth so drama can continue.
[src/libout123/modules/alsa.c:126] error: initialize_device(): cannot set hw params
[src/libout123/libout123.c:562] error: failed re-opening of device after pause
[0:00] Decoding of sample.mp3 finished.
ALSA lib bluealsa-pcm.c:679:(_snd_pcm_bluealsa_open) Couldn't get BlueALSA transport: Interrupted system call
[src/libout123/modules/alsa.c:178] error: cannot open device default
or try this with example.mp3 from raspberrypi.org and player will hang
omxplayer -o alsa example.mp3
carriba
Contact: ICQ
Tue Mar 06, 2018 12:34 pm
i found a workaround/fix for this Problem in another German speaking forum: https://forum-raspberrypi.de/forum/thre ... /?pageNo=4. It is assumed there, that the problem occures when the SSID is hidden, not send.
scan_ssid=1
the old firmware isn't affected, but the new FW crashes the system!
So, to be able to update your Raspbian, just make sure that you add given line into your /etc/wpa_supplicant.conf before you update, and you should have no more problems with this. It worked flawlessly in my case. Best regards and happy hacking (-:
According to the cited reference above, this did seem to have resolved the issue for a RPi 3 B device, however did not cure the problem for RPI 0 W device as experimented with viewtopic.php?f=63&t=204882&start=75#p1278383.
Tue Mar 06, 2018 12:50 pm
We rolled back the wireless firmware to an earlier version because of issues with it. apt update will get that earlier version.
I'm currently testing a fix, so hopefully we will be able to go back to the newer firmware in the near future. This should fix a multitude of things, but breath holding not recommended.
Earlton2
Fri Mar 09, 2018 10:37 pm
Without wishing to add to the fine details, after updating I too have seen a loss of WiFi communication to another Pi Zero W providing an access point.
I am presently logged on to my Pi(AP) from a Win7 laptop (PuTTY) and a Samsung Galaxy (Terminus); but...
Pi(m) Zero W after updating gives me wlan0 "carrier lost" with wpa_ pointing at Pi(AP); however...
Pi(m) Zero W after updating will happily connect wlan0 when wpa_ points at my Hitron router.
I've worked my way there and back on most (if not more) of the suggestions here-in, but doubt I could answer any questions as to where I'm presently at in the great scheme of things.
Pi(m) Zero W - stretch 9.3 4.9.59+ armV61
Pi(AP) Zero W - stretch 9.3 4.9.59+ armV61
Pi(m) is also connected to my router via a usb Eth0 and has been logging midnight temperature reports for over two weeks.
Earlton2
Sat Mar 17, 2018 1:45 am
More grist for the mill: This may be of interest if you've gotten this far:
robinndi: Can't get vanilla wifi to work on Stretch
viewtopic.php?p=1282878#p1280343
Sat Mar 17, 2018 7:41 am
Please update to the latest version Raspbian, that has the latest wireless fixes. Might help.
SteveDee
Sat Mar 24, 2018 7:28 am
@carriba: thank you for your time and patience in pushing this issue.
I received a ZeroW yesterday morning (my Pi #16 but my first ZeroW) and spent most of the day trying to get internal wifi to cooperate. The board worked fine with a USB wifi dongle attached, so I was coming around to the idea that the board needed to be returned.
I eventually stumbled upon this thread. By your 5th post you had presented enough information (& demonstrated your competence) to indicate that there was a software problem (e.g. a working board that stopped after a straightforward update/upgrade, but would still run with an earlier software version, & so on).
I admire your tenacity. And thanks to James for the fix.
AVVD
Wed Apr 11, 2018 4:58 pm
I've got the same problem after an upgrade of my upgrade from a fresh 2018-03-13-raspbian-stretch-lite.img
Wifi worked before the upgrade.
After a reboot, wifi doesn't work but if (via serial console) I launch:
# /sbin/wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
Successfully initialized wpa_supplicant
wlan0: Trying to associate with <my_router_mac_addr> (SSID='<MY_SSID>' freq=2412 MHz)
wlan0: Associated with <my_router_mac_addr>
wlan0: WPA: Key negotiation completed with <my_router_mac_addr> [PTK=CCMP GTK=CCMP]
wlan0: CTRL-EVENT-CONNECTED - Connection to <my_router_mac_addr> completed [id=0 id_str=]
##<Ctrl+C>##
nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
^Cp2p-dev-wlan0: CTRL-EVENT-TERMINATING
wlan0: CTRL-EVENT-DISCONNECTED bssid=<my_router_mac_addr> reason=3 locally_generated=1
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wifi works and I can ping my pi-zw from another computer until I break the process.
Here the list of upgraded packages:
# cat /var/log/dpkg.log | grep upgrade
2018-04-11 15:49:27 upgrade base-files:armhf 9.9+rpi1+deb9u3 9.9+rpi1+deb9u4
2018-04-11 15:49:32 upgrade libwbclient0:armhf 2:4.5.12+dfsg-2+deb9u1 2:4.5.12+dfsg-2+deb9u2
2018-04-11 15:49:34 upgrade samba-common:all 2:4.5.12+dfsg-2+deb9u1 2:4.5.12+dfsg-2+deb9u2
2018-04-11 15:49:35 upgrade libssl1.0.2:armhf 1.0.2l-2+deb9u2 1.0.2l-2+deb9u3
2018-04-11 15:49:37 upgrade libssl1.1:armhf 1.1.0f-3+deb9u1 1.1.0f-3+deb9u2
2018-04-11 15:49:40 upgrade curl:armhf 7.52.1-5+deb9u4 7.52.1-5+deb9u5
2018-04-11 15:49:40 upgrade libcurl3:armhf 7.52.1-5+deb9u4 7.52.1-5+deb9u5
2018-04-11 15:49:41 upgrade libcurl3-gnutls:armhf 7.52.1-5+deb9u4 7.52.1-5+deb9u5
2018-04-11 15:49:42 upgrade libicu57:armhf 57.1-6+deb9u1 57.1-6+deb9u2
2018-04-11 15:49:50 upgrade linux-libc-dev:armhf 4.9.51-1+rpi3 4.9.82-1+deb9u3+rpi1
2018-04-11 15:49:56 upgrade openssl:armhf 1.1.0f-3+deb9u1 1.1.0f-3+deb9u2
2018-04-11 15:49:57 upgrade raspberrypi-sys-mods:armhf 20180312 20180328+1
2018-04-11 15:50:10 upgrade libraspberrypi-doc:armhf 1.20180313-1 1.20180328-1
2018-04-11 15:50:18 upgrade libraspberrypi-dev:armhf 1.20180313-1 1.20180328-1
2018-04-11 15:50:21 upgrade raspberrypi-kernel:armhf 1.20180313-1 1.20180328-1
2018-04-11 15:51:51 upgrade libraspberrypi-bin:armhf 1.20180313-1 1.20180328-1
2018-04-11 15:51:53 upgrade libraspberrypi0:armhf 1.20180313-1 1.20180328-1
2018-04-11 15:51:55 upgrade raspberrypi-bootloader:armhf 1.20180313-1 1.20180328-1
2018-04-11 15:52:02 upgrade raspi-config:all 20180228 20180406+1
I've created a systemd service to workaround this issue
carriba
Contact: ICQ
Sat Apr 21, 2018 7:09 pm
It seems I have a Deja-vu: Just flashed the "2018-03-13-raspbian-stretch-lite.img" image, and my Pi Zero W can boot up and connect to a "hidden" WLAN AP (an AP that does not broadcast its SSID) and everything works fine with the usual "wpa_supplicant.conf" text file with the following similar contents:
update_config=1
country=GB
network={
	ssid="MyWifiNetworkSSID"
	psk="password"
	key_mgmt=WPA-PSK
Here an extract of the /var/log/syslog relevant entries:
Mar 13 22:53:37 raspberrypi dhcpcd[329]: wlan0: starting wpa_supplicant
Mar 13 22:53:37 raspberrypi dhcpcd-run-hooks[365]: wlan0: starting wpa_supplicant
Mar 13 22:53:37 raspberrypi systemd-udevd[256]: Process '/sbin/crda' failed with exit code 249.
Mar 13 22:53:38 raspberrypi dhcpcd[329]: wlan0: waiting for carrier
Mar 13 22:53:38 raspberrypi dhcpcd[329]: wlan0: carrier acquired
Mar 13 22:53:38 raspberrypi dhcpcd[329]: DUID 00:01:00:01:22:3b:12:f2:b8:27:eb:db:f4:0a
Mar 13 22:53:38 raspberrypi dhcpcd[329]: wlan0: IAID eb:db:f4:0a
Mar 13 22:53:38 raspberrypi dhcpcd[329]: wlan0: adding address fe80::c2a:aa5b:68ac:26b8
Mar 13 22:53:39 raspberrypi dhcpcd[329]: wlan0: carrier lost
Mar 13 22:53:39 raspberrypi dhcpcd[329]: wlan0: deleting address fe80::c2a:aa5b:68ac:26b8
Mar 13 22:54:05 raspberrypi dhcpcd[329]: timed out
Mar 13 22:54:05 raspberrypi dhcpcd[329]: forked to background, child pid 459
Mar 13 22:54:05 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Mar 13 22:54:05 raspberrypi systemd[1]: Reached target Network.
Mar 13 22:54:21 raspberrypi dhcpcd[459]: wlan0: carrier acquired
Mar 13 22:54:21 raspberrypi kernel: [   61.626606] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mar 13 22:54:21 raspberrypi dhcpcd[459]: wlan0: IAID eb:db:f4:0a
Mar 13 22:54:21 raspberrypi dhcpcd[459]: wlan0: adding address fe80::19ae:89fe:a68d:ebf7
Mar 13 22:54:21 raspberrypi dhcpcd[459]: wlan0: soliciting an IPv6 router
Mar 13 22:54:21 raspberrypi dhcpcd[459]: wlan0: soliciting a DHCP lease
Mar 13 22:54:21 raspberrypi dhcpcd[459]: wlan0: offered 192.168.0.52 from 192.168.0.254
Mar 13 22:54:22 raspberrypi dhcpcd[459]: wlan0: probing address 192.168.0.52/24
Mar 13 22:54:23 raspberrypi avahi-daemon[265]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::19ae:89fe:a68d:ebf7.
Mar 13 22:54:23 raspberrypi avahi-daemon[265]: New relevant interface wlan0.IPv6 for mDNS.
Mar 13 22:54:23 raspberrypi avahi-daemon[265]: Registering new address record for fe80::19ae:89fe:a68d:ebf7 on wlan0.*.
Mar 13 22:54:26 raspberrypi dhcpcd[459]: wlan0: leased 192.168.0.52 for 864000 seconds
Mar 13 22:54:26 raspberrypi avahi-daemon[265]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.52.
Mar 13 22:54:26 raspberrypi dhcpcd[459]: wlan0: adding route to 192.168.0.0/24
Mar 13 22:54:26 raspberrypi dhcpcd[459]: wlan0: adding default route via 192.168.0.254
Mar 13 22:54:26 raspberrypi avahi-daemon[265]: New relevant interface wlan0.IPv4 for mDNS.
Mar 13 22:54:26 raspberrypi avahi-daemon[265]: Registering new address record for 192.168.0.52 on wlan0.IPv4.
Apr 21 17:48:52 raspberrypi systemd[1]: Time has been changed
Apr 21 17:48:52 raspberrypi systemd-timesyncd[209]: Synchronized to time server 151.80.44.158:123 (0.debian.pool.ntp.org).
Apr 21 17:48:55 raspberrypi dhcpcd[459]: wlan0: no IPv6 Routers available
Now, when doing today the usual "sudo apt-get update ; sudo apt-get -y upgrade", my Pi Zero W device does not seem to connect to the "hidden" WLAN AP anymore. Nothing has changed on the WLAN AP device! With a Wifi scanner application I can even not find the Pi Zero W device in my local network.
The packages that have been updated are the following:
The following packages will be upgraded:
  base-files curl dhcpcd5 libcurl3 libcurl3-gnutls libicu57 libperl5.24 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
  libssl1.0.2 libssl1.1 libwbclient0 linux-libc-dev openssl perl perl-base perl-modules-5.24 raspberrypi-bootloader raspberrypi-kernel
  raspberrypi-sys-mods raspi-config samba-common
24 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 89.1 MB of archives.
I plugged in an Ethernet dongle on the USB OTG port of the Pi Zero W device, and skimmed through the /var/log/syslog file and have found the following relevant entries:
Apr 21 18:25:57 raspberrypi dhcpcd[219]: wlan0: starting wpa_supplicant
Apr 21 18:25:57 raspberrypi systemd-udevd[106]: Process '/sbin/crda' failed with exit code 249.
Apr 21 18:25:57 raspberrypi dhcpcd-run-hooks[304]: wlan0: starting wpa_supplicant
Apr 21 18:25:58 raspberrypi kernel: [   15.878748] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Apr 21 18:25:58 raspberrypi kernel: [   15.878787] brcmfmac: power management disabled
Apr 21 18:25:58 raspberrypi dhcpcd[219]: wlan0: waiting for carrier
Apr 21 18:25:58 raspberrypi dhcpcd[219]: wlan0: carrier acquired
Apr 21 18:25:58 raspberrypi dhcpcd[219]: DUID 00:01:00:01:22:3b:12:f2:b8:27:eb:db:f4:0a
Apr 21 18:25:58 raspberrypi dhcpcd[219]: wlan0: IAID eb:db:f4:0a
Apr 21 18:25:58 raspberrypi dhcpcd[219]: wlan0: adding address fe80::c2a:aa5b:68ac:26b8
Apr 21 18:25:58 raspberrypi dhcpcd[219]: wlan0: carrier lost
Apr 21 18:25:58 raspberrypi dhcpcd[219]: wlan0: deleting address fe80::c2a:aa5b:68ac:26b8
Apr 21 18:26:25 raspberrypi dhcpcd[219]: timed out
Apr 21 18:26:25 raspberrypi dhcpcd[219]: forked to background, child pid 348
Apr 21 18:26:25 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Apr 21 18:26:25 raspberrypi systemd[1]: Reached target Network.
And no further entries that the WLAN adapter of the Pi Zero W device could have been connected successfully :-(
It seems to me that a regression has been introduced here with the latest update that the WLAN interface of a PI Zero W device can no longer subscribe to a WLAN AP hiding / not advertising its SSID.
Any observations from others?
davidcoton
Sat Apr 21, 2018 8:09 pm
Try adding "scan_ssid=1" in the network section of wpa_supplicant.
carriba
Contact: ICQ
Sun Apr 22, 2018 12:36 pm
Adding this option, this time it did do the job as demonstrated with the /var/log/syslog entries:
Apr 22 12:23:11 raspberrypi systemd-udevd[104]: Process '/sbin/crda' failed with exit code 249.
Apr 22 12:23:11 raspberrypi dhcpcd[248]: wlan0: starting wpa_supplicant
Apr 22 12:23:11 raspberrypi dhcpcd-run-hooks[308]: wlan0: starting wpa_supplicant
Apr 22 12:23:11 raspberrypi kernel: [   16.027042] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Apr 22 12:23:11 raspberrypi kernel: [   16.027319] brcmfmac: power management disabled
Apr 22 12:23:11 raspberrypi dhcpcd[248]: wlan0: waiting for carrier
Apr 22 12:23:11 raspberrypi dhcpcd[248]: wlan0: carrier acquired
Apr 22 12:23:12 raspberrypi dhcpcd[248]: DUID 00:01:00:01:22:3b:12:f2:b8:27:eb:db:f4:0a
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: IAID eb:db:f4:0a
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: adding address fe80::c2a:aa5b:68ac:26b8
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: carrier lost
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: deleting address fe80::c2a:aa5b:68ac:26b8
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: carrier acquired
Apr 22 12:23:12 raspberrypi kernel: [   17.016501] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: adding address fe80::19ae:89fe:a68d:ebf7
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: rebinding lease of 192.168.0.52
Apr 22 12:23:12 raspberrypi dhcpcd[248]: wlan0: probing address 192.168.0.52/24
Apr 22 12:23:13 raspberrypi dhcpcd[248]: wlan0: soliciting an IPv6 router
