Today, I bought a brand new microSD card and have flashed the Raspbian Stretch image of November 2017. And see there, I can reproduce the problem: with fresh new image, Wifi connection works with a Raspbery Pi Zero W; after an OS package update done today, no Wifi access, sic!
In the following posts, I will paste the relevant log files and steps undertaken so that you see how I come up to this siutation. Here the lists of posts:
1/ Contents of the
/var/log/syslog after 1st boot of Raspbian (based on the November 2017 image).
2/ Contents of the
/var/log/kern.log after 1st boot of Raspbian (based on the November 2017 image), followed by a listing of the OS packages updated.
3/ Contents of the
/var/log/syslog after a reboot & 2nd boot of Raspbian (after OS packages update).
4/ Contents of the
/var/log/kern.log after reboot & 2nd boot of Raspbian (after OS packages update).
And here the contents of the
/var/log/syslog after 1st boot of Raspbian (based on the November 2017 image):
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Linux version 4.9.59+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] cma: Reserved 8 MiB at 0x1b400000
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Memory policy: Data cache writeback
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] On node 0 totalpages: 114688
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Normal zone: 1008 pages used for memmap
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Normal zone: 0 pages reserved
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Normal zone: 114688 pages, LIFO batch:31
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] pcpu-alloc: [0] 0
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113680
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait net.ifnames=0 biosdevname=0 logo.nologo plymouth.ignore-serial-consoles
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] Virtual kernel memory layout:
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] vmalloc : 0xdc800000 - 0xff800000 ( 560 MB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] .text : 0xc0008000 - 0xc05d7a48 (5951 kB)
Nov 29 02:56:33 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Nov 29 02:56:33 raspberrypi systemd-udevd[129]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting udev Coldplug all Devices...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Load/Save Random Seed.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Nov 29 02:56:33 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Set the console keyboard layout.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Nov 29 02:56:33 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Show Plymouth Boot Screen...
Nov 29 02:56:33 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 149 (plymouthd).
Nov 29 02:56:33 raspberrypi systemd[1]: Started Show Plymouth Boot Screen.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Encrypted Volumes.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Paths.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Nov 29 02:56:33 raspberrypi systemd[1]: Found device /dev/serial1.
Nov 29 02:56:33 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/7b7fce4f-01.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/7b7fce4f-01...
Nov 29 02:56:33 raspberrypi systemd-fsck[172]: fsck.fat 4.1 (2017-01-24)
Nov 29 02:56:33 raspberrypi systemd-fsck[172]: /dev/mmcblk0p1: 146 files, 42656/83705 clusters
Nov 29 02:56:33 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/7b7fce4f-01.
Nov 29 02:56:33 raspberrypi systemd[1]: Mounting /boot...
Nov 29 02:56:33 raspberrypi systemd[1]: Mounted /boot.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Local File Systems.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Set console font and keymap...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Commit a transient machine-id on disk...
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] .init : 0xc0841000 - 0xc08a4000 ( 396 kB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] .data : 0xc08a4000 - 0xc091ef48 ( 492 kB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] .bss : 0xc091ef48 - 0xc09d4648 ( 726 kB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Nov 29 02:56:33 raspberrypi kernel: [ 0.000000] NR_IRQS:16 nr_irqs:16 16
Nov 29 02:56:33 raspberrypi kernel: [ 0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Nov 29 02:56:33 raspberrypi kernel: [ 0.000076] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Nov 29 02:56:33 raspberrypi kernel: [ 0.000176] bcm2835: system timer (irq = 27)
Nov 29 02:56:33 raspberrypi kernel: [ 0.000648] Console: colour dummy device 80x30
Nov 29 02:56:33 raspberrypi kernel: [ 0.001440] console [tty1] enabled
Nov 29 02:56:33 raspberrypi kernel: [ 0.001496] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Nov 29 02:56:33 raspberrypi kernel: [ 0.060364] pid_max: default: 32768 minimum: 301
Nov 29 02:56:33 raspberrypi kernel: [ 0.060831] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.060903] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.062199] Disabling memory control group subsystem
Nov 29 02:56:33 raspberrypi kernel: [ 0.062408] CPU: Testing write buffer coherency: ok
Nov 29 02:56:33 raspberrypi kernel: [ 0.062511] ftrace: allocating 21715 entries in 64 pages
Nov 29 02:56:33 raspberrypi kernel: [ 0.180835] Setting up static identity map for 0x8200 - 0x8238
Nov 29 02:56:33 raspberrypi kernel: [ 0.182903] devtmpfs: initialized
Nov 29 02:56:33 raspberrypi kernel: [ 0.192859] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Nov 29 02:56:33 raspberrypi kernel: [ 0.193377] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Nov 29 02:56:33 raspberrypi kernel: [ 0.193478] futex hash table entries: 256 (order: -1, 3072 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.194786] pinctrl core: initialized pinctrl subsystem
Nov 29 02:56:33 raspberrypi kernel: [ 0.196304] NET: Registered protocol family 16
Nov 29 02:56:33 raspberrypi kernel: [ 0.198937] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Nov 29 02:56:33 raspberrypi kernel: [ 0.208697] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Nov 29 02:56:33 raspberrypi kernel: [ 0.208791] hw-breakpoint: maximum watchpoint size is 4 bytes.
Nov 29 02:56:33 raspberrypi kernel: [ 0.208929] Serial: AMBA PL011 UART driver
Nov 29 02:56:33 raspberrypi kernel: [ 0.211870] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Nov 29 02:56:33 raspberrypi kernel: [ 0.212699] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Nov 29 02:56:33 raspberrypi kernel: [ 0.262642] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Nov 29 02:56:33 raspberrypi kernel: [ 0.265388] SCSI subsystem initialized
Nov 29 02:56:33 raspberrypi kernel: [ 0.265716] usbcore: registered new interface driver usbfs
Nov 29 02:56:33 raspberrypi kernel: [ 0.265888] usbcore: registered new interface driver hub
Nov 29 02:56:33 raspberrypi kernel: [ 0.266130] usbcore: registered new device driver usb
Nov 29 02:56:33 raspberrypi kernel: [ 0.270895] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
Nov 29 02:56:33 raspberrypi kernel: [ 0.273029] clocksource: Switched to clocksource timer
Nov 29 02:56:33 raspberrypi kernel: [ 0.327248] VFS: Disk quotas dquot_6.6.0
Nov 29 02:56:33 raspberrypi kernel: [ 0.327452] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.327826] FS-Cache: Loaded
Nov 29 02:56:33 raspberrypi kernel: [ 0.328234] CacheFiles: Loaded
Nov 29 02:56:33 raspberrypi kernel: [ 0.347644] NET: Registered protocol family 2
Nov 29 02:56:33 raspberrypi kernel: [ 0.349067] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.349226] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.349360] TCP: Hash tables configured (established 4096 bind 4096)
Nov 29 02:56:33 raspberrypi kernel: [ 0.349496] UDP hash table entries: 256 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.349563] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 0.349923] NET: Registered protocol family 1
Nov 29 02:56:33 raspberrypi kernel: [ 0.350733] RPC: Registered named UNIX socket transport module.
Nov 29 02:56:33 raspberrypi kernel: [ 0.350810] RPC: Registered udp transport module.
Nov 29 02:56:33 raspberrypi kernel: [ 0.350849] RPC: Registered tcp transport module.
Nov 29 02:56:33 raspberrypi kernel: [ 0.350885] RPC: Registered tcp NFSv4.1 backchannel transport module.
Nov 29 02:56:33 raspberrypi kernel: [ 0.352198] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Nov 29 02:56:33 raspberrypi kernel: [ 0.354880] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Nov 29 02:56:33 raspberrypi kernel: [ 0.375624] FS-Cache: Netfs 'nfs' registered for caching
Nov 29 02:56:33 raspberrypi kernel: [ 0.377454] NFS: Registering the id_resolver key type
Nov 29 02:56:33 raspberrypi kernel: [ 0.377564] Key type id_resolver registered
Nov 29 02:56:33 raspberrypi kernel: [ 0.377608] Key type id_legacy registered
Nov 29 02:56:33 raspberrypi kernel: [ 0.382095] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Nov 29 02:56:33 raspberrypi kernel: [ 0.382564] io scheduler noop registered
Nov 29 02:56:33 raspberrypi kernel: [ 0.382629] io scheduler deadline registered (default)
Nov 29 02:56:33 raspberrypi kernel: [ 0.383251] io scheduler cfq registered
Nov 29 02:56:33 raspberrypi kernel: [ 0.389165] BCM2708FB: allocated DMA memory 5b500000
Nov 29 02:56:33 raspberrypi kernel: [ 0.389298] BCM2708FB: allocated DMA channel 0 @ dc80d000
Nov 29 02:56:33 raspberrypi kernel: [ 0.397591] Console: switching to colour frame buffer device 82x26
Nov 29 02:56:33 raspberrypi kernel: [ 0.409204] bcm2835-rng 20104000.rng: hwrng registered
Nov 29 02:56:33 raspberrypi kernel: [ 0.412736] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Nov 29 02:56:33 raspberrypi kernel: [ 0.420400] vc-sm: Videocore shared memory driver
Nov 29 02:56:33 raspberrypi kernel: [ 0.448392] brd: module loaded
Nov 29 02:56:33 raspberrypi kernel: [ 0.464326] loop: module loaded
Nov 29 02:56:33 raspberrypi kernel: [ 0.467600] Loading iSCSI transport class v2.0-870.
Nov 29 02:56:33 raspberrypi kernel: [ 0.471669] usbcore: registered new interface driver smsc95xx
Nov 29 02:56:33 raspberrypi kernel: [ 0.475131] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Nov 29 02:56:33 raspberrypi kernel: [ 0.706946] Core Release: 2.80a
Nov 29 02:56:33 raspberrypi kernel: [ 0.710376] Setting default values for core params
Nov 29 02:56:33 raspberrypi kernel: [ 0.713791] Finished setting default values for core params
Nov 29 02:56:33 raspberrypi kernel: [ 0.917508] Using Buffer DMA mode
Nov 29 02:56:33 raspberrypi kernel: [ 0.920729] Periodic Transfer Interrupt Enhancement - disabled
Nov 29 02:56:33 raspberrypi kernel: [ 0.923961] Multiprocessor Interrupt Enhancement - disabled
Nov 29 02:56:33 raspberrypi kernel: [ 0.927199] OTG VER PARAM: 0, OTG VER FLAG: 0
Nov 29 02:56:33 raspberrypi kernel: [ 0.930456] Dedicated Tx FIFOs mode
Nov 29 02:56:33 raspberrypi kernel: [ 0.934325] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Nov 29 02:56:33 raspberrypi kernel: [ 0.940827] FIQ FSM acceleration enabled for :
Nov 29 02:56:33 raspberrypi kernel: [ 0.940827] Non-periodic Split Transactions
Nov 29 02:56:33 raspberrypi kernel: [ 0.940827] Periodic Split Transactions
Nov 29 02:56:33 raspberrypi kernel: [ 0.940827] High-Speed Isochronous Endpoints
Nov 29 02:56:33 raspberrypi kernel: [ 0.940827] Interrupt/Control Split Transaction hack enabled
Nov 29 02:56:33 raspberrypi kernel: [ 0.956927] dwc_otg: Microframe scheduler enabled
Nov 29 02:56:33 raspberrypi kernel: [ 0.957063] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
Nov 29 02:56:33 raspberrypi kernel: [ 0.960442] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
Nov 29 02:56:33 raspberrypi kernel: [ 0.963732] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Nov 29 02:56:33 raspberrypi kernel: [ 0.967077] dwc_otg 20980000.usb: DWC OTG Controller
Nov 29 02:56:33 raspberrypi kernel: [ 0.970286] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Nov 29 02:56:33 raspberrypi kernel: [ 0.973617] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Nov 29 02:56:33 raspberrypi kernel: [ 0.976836] Init: Port Power? op_state=1
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Raise network interfaces...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Set console font and keymap.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Commit a transient machine-id on disk.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target NFS client services.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Remote File Systems.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Network Time Synchronization...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Network Time Synchronization.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target System Time Synchronized.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target System Initialization.
Nov 29 02:56:33 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Nov 29 02:56:33 raspberrypi systemd[1]: apt-daily.timer: Adding 9h 41min 39.545783s random time.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Daily apt download activities.
Nov 29 02:56:33 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 40min 52.889776s random time.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Timers.
Nov 29 02:56:33 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Nov 29 02:56:33 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Sockets.
Nov 29 02:56:33 raspberrypi systemd[1]: Reached target Basic System.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting LSB: Resize the root filesystem to fill partition...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Regenerate SSH host keys...
Nov 29 02:56:33 raspberrypi systemd[1]: Started Regular background program processing daemon.
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Check for v3d driver...
Nov 29 02:56:33 raspberrypi cron[241]: (CRON) INFO (pidfile fd = 3)
Nov 29 02:56:33 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Nov 29 02:56:33 raspberrypi cron[241]: (CRON) INFO (Running @reboot jobs)
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Login Service...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Copy user wpa_supplicant.conf...
Nov 29 02:56:33 raspberrypi dd[239]: 1+0 records in
Nov 29 02:56:33 raspberrypi dd[239]: 1+0 records out
Nov 29 02:56:33 raspberrypi dd[239]: 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.402791 s, 10.2 kB/s
Nov 29 02:56:33 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Nov 29 02:56:33 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.systemd1'
Nov 29 02:56:33 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting System Logging Service...
Nov 29 02:56:33 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Nov 29 02:56:33 raspberrypi thd[274]: Found socket passed from systemd
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Successfully dropped root privileges.
Nov 29 02:56:33 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: avahi-daemon 0.6.32 starting up.
Nov 29 02:56:33 raspberrypi liblogging-stdlog: [origin software="rsyslogd" swVersion="8.24.0" x-pid="273" x-info="http://www.rsyslog.com"] start
Nov 29 02:56:33 raspberrypi systemd[1]: Started Check for v3d driver.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Successfully called chroot().
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Successfully dropped remaining capabilities.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: No service file found in /etc/avahi/services.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Network interface enumeration completed.
Nov 29 02:56:33 raspberrypi avahi-daemon[272]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 1870407412.
Nov 29 02:56:33 raspberrypi kernel: [ 0.979989] Init: Power Port (0)
Nov 29 02:56:33 raspberrypi kernel: [ 0.983507] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Nov 29 02:56:33 raspberrypi kernel: [ 0.986776] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Nov 29 02:56:33 raspberrypi kernel: [ 0.989933] usb usb1: Product: DWC OTG Controller
Nov 29 02:56:33 raspberrypi kernel: [ 0.993161] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
Nov 29 02:56:33 raspberrypi kernel: [ 0.996377] usb usb1: SerialNumber: 20980000.usb
Nov 29 02:56:33 raspberrypi kernel: [ 1.000714] hub 1-0:1.0: USB hub found
Nov 29 02:56:33 raspberrypi kernel: [ 1.004055] hub 1-0:1.0: 1 port detected
Nov 29 02:56:33 raspberrypi kernel: [ 1.008027] dwc_otg: FIQ enabled
Nov 29 02:56:33 raspberrypi kernel: [ 1.008038] dwc_otg: NAK holdoff enabled
Nov 29 02:56:33 raspberrypi kernel: [ 1.008043] dwc_otg: FIQ split-transaction FSM enabled
Nov 29 02:56:33 raspberrypi kernel: [ 1.008063] Module dwc_common_port init
Nov 29 02:56:33 raspberrypi kernel: [ 1.008567] usbcore: registered new interface driver usb-storage
Nov 29 02:56:33 raspberrypi kernel: [ 1.012240] mousedev: PS/2 mouse device common for all mice
Nov 29 02:56:33 raspberrypi kernel: [ 1.017284] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Nov 29 02:56:33 raspberrypi kernel: [ 1.021089] bcm2835-cpufreq: min=700000 max=1000000
Nov 29 02:56:33 raspberrypi kernel: [ 1.024941] sdhci: Secure Digital Host Controller Interface driver
Nov 29 02:56:33 raspberrypi kernel: [ 1.028102] sdhci: Copyright(c) Pierre Ossman
Nov 29 02:56:33 raspberrypi kernel: [ 1.031635] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Nov 29 02:56:33 raspberrypi kernel: [ 1.037487] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Nov 29 02:56:33 raspberrypi kernel: [ 1.040966] sdhci-pltfm: SDHCI platform and OF driver helper
Nov 29 02:56:33 raspberrypi kernel: [ 1.044951] ledtrig-cpu: registered to indicate activity on CPUs
Nov 29 02:56:33 raspberrypi kernel: [ 1.048512] hidraw: raw HID events driver (C) Jiri Kosina
Nov 29 02:56:33 raspberrypi kernel: [ 1.052128] usbcore: registered new interface driver usbhid
Nov 29 02:56:33 raspberrypi kernel: [ 1.055553] usbhid: USB HID core driver
Nov 29 02:56:33 raspberrypi kernel: [ 1.060187] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Nov 29 02:56:33 raspberrypi kernel: [ 1.065690] [vc_sm_connected_init]: start
Nov 29 02:56:33 raspberrypi kernel: [ 1.076314] [vc_sm_connected_init]: end - returning 0
Nov 29 02:56:33 raspberrypi kernel: [ 1.080362] Initializing XFRM netlink socket
Nov 29 02:56:33 raspberrypi kernel: [ 1.083901] NET: Registered protocol family 17
Nov 29 02:56:33 raspberrypi kernel: [ 1.087440] Key type dns_resolver registered
Nov 29 02:56:33 raspberrypi kernel: [ 1.092628] registered taskstats version 1
Nov 29 02:56:33 raspberrypi kernel: [ 1.105171] uart-pl011 20201000.serial: cts_event_workaround enabled
Nov 29 02:56:33 raspberrypi kernel: [ 1.108748] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Nov 29 02:56:33 raspberrypi kernel: [ 1.118074] sdhost: log_buf @ db513000 (5b513000)
Nov 29 02:56:33 raspberrypi kernel: [ 1.193110] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Nov 29 02:56:33 raspberrypi kernel: [ 1.199361] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Nov 29 02:56:33 raspberrypi kernel: [ 1.202994] mmc-bcm2835 20300000.mmc: DMA channel allocated
Nov 29 02:56:33 raspberrypi kernel: [ 1.236321] random: fast init done
Nov 29 02:56:33 raspberrypi kernel: [ 1.280262] mmc0: host does not support reading read-only switch, assuming write-enable
Nov 29 02:56:33 raspberrypi kernel: [ 1.287446] of_cfs_init
Nov 29 02:56:33 raspberrypi kernel: [ 1.290999] of_cfs_init: OK
Nov 29 02:56:33 raspberrypi kernel: [ 1.298914] mmc0: new high speed SDHC card at address 0001
Nov 29 02:56:33 raspberrypi kernel: [ 1.306097] mmcblk0: mmc0:0001 00000 29.8 GiB
Nov 29 02:56:33 raspberrypi kernel: [ 1.311926] mmcblk0: p1 p2
Nov 29 02:56:33 raspberrypi kernel: [ 1.324853] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 1.331158] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Nov 29 02:56:33 raspberrypi kernel: [ 1.337886] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 1.341469] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Nov 29 02:56:33 raspberrypi kernel: [ 1.346360] devtmpfs: mounted
Nov 29 02:56:33 raspberrypi kernel: [ 1.349917] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 1.354749] Freeing unused kernel memory: 396K
Nov 29 02:56:33 raspberrypi kernel: [ 1.358184] This architecture does not have kernel memory protection.
Nov 29 02:56:33 raspberrypi kernel: [ 1.365247] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Nov 29 02:56:33 raspberrypi kernel: [ 1.480524] mmc1: new high speed SDIO card at address 0001
Nov 29 02:56:33 raspberrypi kernel: [ 1.959343] NET: Registered protocol family 10
Nov 29 02:56:33 raspberrypi kernel: [ 1.991413] ip_tables: (C) 2000-2006 Netfilter Core Team
Nov 29 02:56:33 raspberrypi kernel: [ 4.067118] i2c /dev entries driver
Nov 29 02:56:33 raspberrypi kernel: [ 5.438357] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Nov 29 02:56:33 raspberrypi kernel: [ 8.180713] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Nov 29 02:56:33 raspberrypi kernel: [ 9.182081] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Nov 29 02:56:33 raspberrypi kernel: [ 9.202354] usbcore: registered new interface driver brcmfmac
Nov 29 02:56:33 raspberrypi kernel: [ 9.579758] brcmfmac: Firmware version = wl0: Aug 7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
Nov 29 02:56:33 raspberrypi kernel: [ 9.580988] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
Nov 29 02:56:33 raspberrypi kernel: [ 13.498498] uart-pl011 20201000.serial: no DMA platform data
Nov 29 02:56:33 raspberrypi systemd[1]: Started System Logging Service.
Nov 29 02:56:33 raspberrypi systemd[1]: Started Copy user wpa_supplicant.conf.
Nov 29 02:56:35 raspberrypi raspi-config[232]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Nov 29 02:56:35 raspberrypi dphys-swapfile[248]: Starting dphys-swapfile swapfile setup ...
Nov 29 02:56:35 raspberrypi raspi-config[232]: No. Switching to ondemand scaling governor.
Nov 29 02:56:35 raspberrypi resize2fs_once[238]: Starting resize2fs_once:resize2fs 1.43.4 (31-Jan-2017)
Nov 29 02:56:35 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Nov 29 02:56:35 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Nov 29 02:56:35 raspberrypi systemd[1]: Started Login Service.
Nov 29 02:56:35 raspberrypi kernel: [ 16.066076] EXT4-fs (mmcblk0p2): resizing filesystem from 1189376 to 7803392 blocks
Nov 29 02:56:35 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Nov 29 02:56:35 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Nov 29 02:56:35 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Nov 29 02:56:35 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Nov 29 02:56:36 raspberrypi systemd[1]: Started Raise network interfaces.
Nov 29 02:56:36 raspberrypi dhcpcd[321]: dev: loaded udev
Nov 29 02:56:36 raspberrypi dhcpcd[321]: forked to background, child pid 339
Nov 29 02:56:36 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Nov 29 02:56:36 raspberrypi systemd[1]: Reached target Network.
Nov 29 02:56:36 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Nov 29 02:56:36 raspberrypi systemd[1]: Starting Permit User Sessions...
Nov 29 02:56:37 raspberrypi systemd[1]: Started Permit User Sessions.
Nov 29 02:56:37 raspberrypi systemd[1]: Starting Light Display Manager...
Nov 29 02:56:37 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Nov 29 02:56:37 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Nov 29 02:56:37 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Nov 29 02:56:37 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 149 (plymouthd).
Nov 29 02:56:37 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Nov 29 02:56:37 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Nov 29 02:56:37 raspberrypi systemd[1]: Started Getty on tty1.
Nov 29 02:56:37 raspberrypi systemd[1]: Reached target Login Prompts.
Nov 29 02:56:37 raspberrypi kernel: [ 18.403411] Bluetooth: Core ver 2.22
Nov 29 02:56:37 raspberrypi kernel: [ 18.403561] NET: Registered protocol family 31
Nov 29 02:56:37 raspberrypi kernel: [ 18.403569] Bluetooth: HCI device and connection manager initialized
Nov 29 02:56:37 raspberrypi kernel: [ 18.408224] Bluetooth: HCI socket layer initialized
Nov 29 02:56:37 raspberrypi kernel: [ 18.408248] Bluetooth: L2CAP socket layer initialized
Nov 29 02:56:37 raspberrypi kernel: [ 18.408295] Bluetooth: SCO socket layer initialized
Nov 29 02:56:37 raspberrypi kernel: [ 18.520665] Bluetooth: HCI UART driver ver 2.3
Nov 29 02:56:37 raspberrypi kernel: [ 18.520681] Bluetooth: HCI UART protocol H4 registered
Nov 29 02:56:37 raspberrypi kernel: [ 18.520686] Bluetooth: HCI UART protocol Three-wire (H5) registered
Nov 29 02:56:37 raspberrypi kernel: [ 18.520826] Bluetooth: HCI UART protocol Broadcom registered
Nov 29 02:56:37 raspberrypi btuart[233]: bcm43xx_init
Nov 29 02:56:37 raspberrypi btuart[233]: Flash firmware /lib/firmware/BCM43430A1.hcd
Nov 29 02:56:37 raspberrypi btuart[233]: Set BDADDR UART: b8:27:eb:34:89:f8
Nov 29 02:56:37 raspberrypi btuart[233]: Set Controller UART speed to 3000000 bit/s
Nov 29 02:56:37 raspberrypi btuart[233]: Device setup complete
Nov 29 02:56:37 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Nov 29 02:56:38 raspberrypi systemd[1]: Starting Bluetooth service...
Nov 29 02:56:39 raspberrypi systemd-udevd[140]: Process '/sbin/crda' failed with exit code 249.
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Bluetooth daemon 5.43
Nov 29 02:56:39 raspberrypi systemd[1]: Started Bluetooth service.
Nov 29 02:56:39 raspberrypi systemd[1]: Started BluezALSA proxy.
Nov 29 02:56:39 raspberrypi dhcpcd-run-hooks[378]: wlan0: starting wpa_supplicant
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Starting SDP server
Nov 29 02:56:39 raspberrypi dphys-swapfile[248]: want /var/swap=100MByte, generating swapfile ... of 100MBytes
Nov 29 02:56:39 raspberrypi kernel: [ 20.218696] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Nov 29 02:56:39 raspberrypi kernel: [ 20.218709] Bluetooth: BNEP filters: protocol multicast
Nov 29 02:56:39 raspberrypi kernel: [ 20.218734] Bluetooth: BNEP socket layer initialized
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Bluetooth management interface 1.14 initialized
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Failed to obtain handles for "Service Changed" characteristic
Nov 29 02:56:39 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 29 02:56:39 raspberrypi kernel: [ 20.360449] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
Nov 29 02:56:39 raspberrypi dphys-swapfile[248]: done.
Nov 29 02:56:39 raspberrypi bluetoothd[373]: Sap driver initialization failed.
Nov 29 02:56:39 raspberrypi bluetoothd[373]: sap-server: Operation not permitted (1)
Nov 29 02:56:39 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Nov 29 02:56:40 raspberrypi systemd[1]: Starting Hostname Service...
Nov 29 02:56:40 raspberrypi systemd[1]: Reached target Bluetooth.
Nov 29 02:56:40 raspberrypi bluetoothd[373]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Source/1
Nov 29 02:56:40 raspberrypi bluetoothd[373]: Endpoint registered: sender=:1.4 path=/A2DP/SBC/Sink/1
Nov 29 02:56:40 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 29 02:56:40 raspberrypi systemd[1]: Started Hostname Service.
Nov 29 02:56:40 raspberrypi kernel: [ 21.293141] Bluetooth: RFCOMM TTY layer initialized
Nov 29 02:56:40 raspberrypi kernel: [ 21.293178] Bluetooth: RFCOMM socket layer initialized
Nov 29 02:56:40 raspberrypi kernel: [ 21.293210] Bluetooth: RFCOMM ver 1.11
Nov 29 02:56:40 raspberrypi kernel: [ 21.466013] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Nov 29 02:56:40 raspberrypi kernel: [ 21.466031] brcmfmac: power management disabled
Nov 29 02:56:40 raspberrypi kernel: [ 21.471626] random: crng init done
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: waiting for carrier
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: carrier acquired
Nov 29 02:56:42 raspberrypi dhcpcd[339]: DUID 00:01:00:01:21:b0:de:6a:b8:27:eb:cb:76:07
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: IAID eb:cb:76:07
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: adding address fe80::e155:9544:daa:ffa1
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: carrier lost
Nov 29 02:56:42 raspberrypi dhcpcd[339]: wlan0: deleting address fe80::e155:9544:daa:ffa1
Nov 29 02:56:45 raspberrypi kernel: [ 26.321825] EXT4-fs (mmcblk0p2): resized to 3670016 blocks
Nov 29 02:56:49 raspberrypi systemd[1]: Created slice User Slice of pi.
Nov 29 02:56:49 raspberrypi systemd[1]: Started Session c1 of user pi.
Nov 29 02:56:49 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Nov 29 02:56:49 raspberrypi lightdm[358]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 29 02:56:49 raspberrypi systemd[1]: Started Light Display Manager.
Nov 29 02:56:49 raspberrypi lightdm[358]: Could not enumerate user data directory /var/lib/lightdm/data: Error opening directory '/var/lib/lightdm/data': No such file or directory
Nov 29 02:56:52 raspberrypi systemd[431]: Starting D-Bus User Message Bus Socket.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Paths.
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent (access for web browsers).
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on GnuPG cryptographic agent and passphrase cache.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Timers.
Nov 29 02:56:52 raspberrypi systemd[431]: Listening on D-Bus User Message Bus Socket.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Sockets.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Basic System.
Nov 29 02:56:52 raspberrypi systemd[431]: Reached target Default.
Nov 29 02:56:52 raspberrypi systemd[431]: Startup finished in 2.779s.
Nov 29 02:56:52 raspberrypi systemd[1]: Started User Manager for UID 1000.
Nov 29 02:56:54 raspberrypi ssh-keygen[285]: ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Nov 29 02:56:54 raspberrypi systemctl[449]: Removed /etc/systemd/system/multi-user.target.wants/regenerate_ssh_host_keys.service.
Nov 29 02:56:54 raspberrypi systemd[1]: Reloading.
Nov 29 02:56:55 raspberrypi systemd[1]: Started Regenerate SSH host keys.
Nov 29 02:56:55 raspberrypi systemd[1]: Starting Turn on SSH if /boot/ssh is present...
Nov 29 02:56:56 raspberrypi kernel: [ 36.698838] EXT4-fs (mmcblk0p2): resized to 6291456 blocks
Nov 29 02:57:00 raspberrypi lightdm[358]: session_get_login1_session_id: assertion 'session != NULL' failed
Nov 29 02:57:00 raspberrypi systemd[1]: Reloading.
Nov 29 02:57:02 raspberrypi kernel: [ 43.560052] EXT4-fs (mmcblk0p2): resized filesystem to 7803392
Nov 29 02:57:03 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Nov 29 02:57:03 raspberrypi resize2fs_once[238]: Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required
Nov 29 02:57:03 raspberrypi resize2fs_once[238]: old_desc_blocks = 1, new_desc_blocks = 2
Nov 29 02:57:03 raspberrypi resize2fs_once[238]: The filesystem on /dev/mmcblk0p2 is now 7803392 (4k) blocks long.
Nov 29 02:57:04 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Nov 29 02:57:04 raspberrypi systemd[1]: Started Turn on SSH if /boot/ssh is present.
Nov 29 02:57:04 raspberrypi systemd[1]: Reloading.
Nov 29 02:57:06 raspberrypi systemd[1]: Reached target Multi-User System.
Nov 29 02:57:06 raspberrypi systemd[1]: Reached target Graphical Interface.
Nov 29 02:57:06 raspberrypi resize2fs_once[238]: .
Nov 29 02:57:06 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Nov 29 02:57:06 raspberrypi systemd[1]: Started LSB: Resize the root filesystem to fill partition.
Nov 29 02:57:06 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Nov 29 02:57:06 raspberrypi systemd[1]: Startup finished in 1.699s (kernel) + 45.350s (userspace) = 47.050s.
Nov 29 02:57:06 raspberrypi lightdm[523]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Nov 29 02:57:07 raspberrypi systemd[1]: Started Session c2 of user pi.
Nov 29 02:57:07 raspberrypi lightdm[358]: Error opening audit socket: Protocol not supported
Nov 29 02:57:07 raspberrypi systemd[431]: Started D-Bus User Message Bus.
Nov 29 02:57:11 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Nov 29 02:57:11 raspberrypi systemd[431]: Starting Virtual filesystem service...
Nov 29 02:57:11 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.Daemon'
Nov 29 02:57:11 raspberrypi systemd[431]: Started Virtual filesystem service.
Nov 29 02:57:11 raspberrypi kernel: [ 52.013141] fuse init (API version 7.26)
Nov 29 02:57:11 raspberrypi systemd[1]: Mounting FUSE Control File System...
Nov 29 02:57:11 raspberrypi systemd[1]: Mounted FUSE Control File System.
Nov 29 02:57:13 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Nov 29 02:57:13 raspberrypi systemd[1]: Starting Authorization Manager...
Nov 29 02:57:13 raspberrypi polkitd[661]: started daemon version 0.105 using authority implementation `local' version `0.105'
Nov 29 02:57:13 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Nov 29 02:57:13 raspberrypi systemd[1]: Started Authorization Manager.
Nov 29 02:57:21 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Nov 29 02:57:21 raspberrypi systemd[431]: Starting Virtual filesystem service - disk device monitor...
Nov 29 02:57:21 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Nov 29 02:57:21 raspberrypi systemd[1]: Starting Disk Manager...
Nov 29 02:57:22 raspberrypi udisksd[696]: udisks daemon version 2.1.8 starting
Nov 29 02:57:22 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Nov 29 02:57:22 raspberrypi systemd[1]: Started Disk Manager.
Nov 29 02:57:22 raspberrypi udisksd[696]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 29 02:57:23 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Nov 29 02:57:23 raspberrypi systemd[431]: Started Virtual filesystem service - disk device monitor.
Nov 29 02:57:23 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Nov 29 02:57:23 raspberrypi systemd[431]: Starting Virtual filesystem service - digital camera monitor...
Nov 29 02:57:23 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Nov 29 02:57:23 raspberrypi systemd[431]: Started Virtual filesystem service - digital camera monitor.
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Nov 29 02:57:24 raspberrypi systemd[431]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Nov 29 02:57:24 raspberrypi kernel: [ 64.685529] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: carrier acquired
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: IAID eb:cb:76:07
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: adding address fe80::592a:178f:b470:c16d
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Nov 29 02:57:24 raspberrypi systemd[431]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Nov 29 02:57:24 raspberrypi systemd[431]: Starting Virtual filesystem service - Apple File Conduit monitor...
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: soliciting a DHCP lease
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: offered 192.168.0.31 from 192.168.0.254
Nov 29 02:57:24 raspberrypi dhcpcd[339]: wlan0: probing address 192.168.0.31/24
Nov 29 02:57:24 raspberrypi gvfs-afc-volume-monitor[716]: Volume monitor alive
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Nov 29 02:57:24 raspberrypi systemd[431]: Started Virtual filesystem service - Apple File Conduit monitor.
Nov 29 02:57:24 raspberrypi dbus-daemon[541]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Nov 29 02:57:24 raspberrypi systemd[431]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Nov 29 02:57:25 raspberrypi dhcpcd[339]: wlan0: soliciting an IPv6 router
Nov 29 02:57:25 raspberrypi dbus-daemon[541]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Nov 29 02:57:25 raspberrypi systemd[431]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Nov 29 02:57:25 raspberrypi avahi-daemon[272]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::592a:178f:b470:c16d.
Nov 29 02:57:25 raspberrypi avahi-daemon[272]: New relevant interface wlan0.IPv6 for mDNS.
Nov 29 02:57:25 raspberrypi avahi-daemon[272]: Registering new address record for fe80::592a:178f:b470:c16d on wlan0.*.
Nov 29 02:57:28 raspberrypi dhcpcd[339]: wlan0: leased 192.168.0.31 for 864000 seconds
Nov 29 02:57:28 raspberrypi avahi-daemon[272]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.31.
Nov 29 02:57:28 raspberrypi dhcpcd[339]: wlan0: adding route to 192.168.0.0/24
Nov 29 02:57:28 raspberrypi dhcpcd[339]: wlan0: adding default route via 192.168.0.254
Nov 29 02:57:28 raspberrypi avahi-daemon[272]: New relevant interface wlan0.IPv4 for mDNS.
Nov 29 02:57:28 raspberrypi avahi-daemon[272]: Registering new address record for 192.168.0.31 on wlan0.IPv4.
Feb 13 12:06:17 raspberrypi systemd-timesyncd[205]: Synchronized to time server 194.177.34.116:123 (0.debian.pool.ntp.org).
Feb 13 12:06:17 raspberrypi systemd[431]: Time has been changed
Feb 13 12:06:17 raspberrypi systemd[1]: Time has been changed
Feb 13 12:06:17 raspberrypi systemd[1]: Reached target Network is Online.
Feb 13 12:06:17 raspberrypi systemd[1]: Starting Daily apt download activities...
Feb 13 12:06:22 raspberrypi dhcpcd[339]: wlan0: no IPv6 Routers available
Feb 13 12:06:39 raspberrypi systemd[1]: Started Daily apt download activities.
Feb 13 12:06:39 raspberrypi systemd[1]: apt-daily.timer: Adding 1h 32min 43.028191s random time.
Feb 13 12:06:39 raspberrypi systemd[1]: apt-daily.timer: Adding 7h 56min 46.576448s random time.
Feb 13 12:06:39 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
Feb 13 12:06:43 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Feb 13 12:06:43 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 56min 41.445210s random time.
Feb 13 12:06:43 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 49min 28.372278s random time.
Feb 13 12:10:05 raspberrypi systemd[1]: Started Session c3 of user pi.
Feb 13 12:11:26 raspberrypi dbus[263]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service'
Feb 13 12:11:26 raspberrypi systemd[1]: Starting PackageKit Daemon...
Feb 13 12:11:26 raspberrypi PackageKit: daemon start
Feb 13 12:11:26 raspberrypi dbus[263]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Feb 13 12:11:26 raspberrypi systemd[1]: Started PackageKit Daemon.
Feb 13 12:17:01 raspberrypi CRON[1117]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Feb 13 12:20:08 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
Feb 13 12:20:09 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
