michele.x
Almost like CGA
Thu Nov 01, 2012 10:02 pm
This is a really silly trick you can do with the Pi connected to an analog monitor.
It looks almost like an old CGA monitor, and reduces flicker too. That old monitor uses a tube developer for black and white tv sets so the white phosphor is fast-decay. Using this trick the flicker is a lot less noticeable.
file cga.sh
#!/bin/bash
setfont Uni1-VGA8
#PAL
fbset -a -xres 640 -yres 240
#NTSC
#fbset -a -xres 640 -yres 200
reset
file vga.sh (to get back the normal font)
#!/bin/bash
setfont Uni1-VGA16
#VGA
fbset -a -xres 640 -yres 480
#M24
#fbset -a -xres 640 -yres 400
reset
remember to make executable the scripts with:
chmod a+x cga.sh
chmod a+x vga.sh
my config.txt has this snippet to have a 640x480 pixel unscaled framebuffer:
overscan_left=16
overscan_right=0
overscan_top=16
overscan_bottom=16
sdtv_aspect=1
sdtv_mode=2
Note that if X is launched after changing the framebuffer, the vertical resolution is reduced to half.
guidol
Re: Almost like CGA
Mon Jan 14, 2013 3:00 pm
Today I did try your config with a very small black/white TV on my RPi.
Looks very funny :-)
http://lehwalder.wordpress.com/2013/01/ ... ini-sw-tv/
