shd06131
Fail to install VScode on raspberry pi 3b
Sun Nov 11, 2018 8:00 am
I try to install vscode via the following command
sudo -s
. <( wget -O - https://code.headmelted.com/installers/apt.sh )
However, the following error come out and the installation is not success.
--2018-11-11 15:53:10--  https://code.headmelted.com/installers/apt.sh
Resolving code.headmelted.com (code.headmelted.com)... 104.27.186.80, 104.27.187.80, 2606:4700:30::681b:ba50, ...
Connecting to code.headmelted.com (code.headmelted.com)|104.27.186.80|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/x-sh]
Saving to: ‘STDOUT’
-                       [ <=>                ]   2.29K  --.-KB/s    in 0s
2018-11-11 15:53:11 (6.58 MB/s) - written to stdout [2349]
Detecting architecture...
Ensuring curl is installed
Reading package lists... Done
Building dependency tree
curl is already the newest version (7.52.1-5+deb9u8).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Architecture detected as armv7l...
Retrieving GPG key [headmelted] (https://packagecloud.io/headmelted/codebuilds/gpgkey)...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
gpg: no valid OpenPGP data found.
Removing any previous entry to headmelted repository
Installing [headmelted] repository...
Updating APT cache...
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Hit:3 https://deb.nodesource.com/node_7.x stretch InRelease
Get:4 https://packagecloud.io/headmelted/codebuilds/debian stretch InRelease [23.4 kB]
Ign:4 https://packagecloud.io/headmelted/codebuilds/debian stretch InRelease
Fetched 23.4 kB in 3s (7,584 B/s)
W: GPG error: https://packagecloud.io/headmelted/codebuilds/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0CC3FD642696BFC8
W: The repository 'https://packagecloud.io/headmelted/codebuilds/debian stretch InRelease' is not signed.
Done!
Repository install complete.
Installing Visual Studio Code from [stretch]...
The following NEW packages will be installed:
  code-oss
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 41.7 MB of archives.
After this operation, 157 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
  code-oss
E: There were unauthenticated packages and -y was used without --allow-unauthenticated
Visual Studio Code install failed.
Do anyone has any idea what's going on? :o
Re: Fail to install VScode on raspberry pi 3b
Sun Nov 11, 2018 8:36 am
That's your error.
You'll need to get the GPG key from https://packagecloud.io/gpg.key and install that in your APT system.
wget -qO - https://packagecloud.io/gpg.key | sudo apt-key add -
shd06131
Sun Nov 11, 2018 9:02 am
thank you for your reply, should I just type in
then type in my original command? Same error was received afterward. :(
Sun Nov 11, 2018 9:17 am
shd06131
Sun Nov 11, 2018 9:59 am
Many thanks, it's work now
