Re: Raspberry Pi 4 Thread - general discussion
Now the really question is - when will the new Raspberry Pi Zero with 1gb ram and quad core cpu be out?
What I read is that is the Pi4 USB ports can provide a combined total of 1.2 A. If that assumes you are using the official supply which is 3A (15 W output), this means the Pi4 itself cannot use more than 1.8 A so unless you have power-hungry accessories, I think a 2.1A supply should still work.webbsmurfen123 wrote: ↑Mon Jun 24, 2019 4:58 pmI would have liked to see a a variant capable to run from a 5V 2.1A powerbank, like you could with the older Raspberry pi 2B. I like the idea to move around in the wild
If you DO have power-hungry accessories, there are USB-C power banks with 15 watt output.
saw this and my jaw dropped gimmee gimme gimme!!!!!!
I do strange things and am sometimes the techhead stereotype.
deal with it!
deal with it!
Excellent news, thankyou. Mine's due tomorrow, Royal Mail permitting. I was worried you'd have to end up doing something with Mali or similar, which I've had much less success with on non-Pi SBCs.
One question, which I have a feeling 6by9 is going to hate me for: is it / will it ever be possible to drive the H.265 decoder (with all that that entails, regarding pumping that extra data through the rest of the stack) via OpenMAX?
Thanks. I'm awaiting the post tomorrow with interest.
I believe it has been fixed.KanoMaster22 wrote: ↑Mon Jun 24, 2019 4:30 pmThis question also interests me. Does anyone know the answer to it?
Another great product from the Raspberry Pi team. Can't wait to get my hands on one (when the 4GB ones are back in stock).
picockpit.com - tools to make your life with the Pi a little bit easier
I searched through this topic and didn't find anything on a pretty pressing topic yet: how does the interrupt controller on the Pi 4 work? Does it distribute all interrupts over multiple cores, or is the behavior similar to all previous Pi's where only one single core handles all interrupts and by handling them it fully stops processing?
Keywords: irq affinity
Previous topics: https://www.raspberrypi.org/forums/view ... hp?t=38076
No.
The H265 decoder is currently accessed via a modified FFmpeg, it doesn't touch the GPU at all. It is effectively open, therefore there is no need to insert IL or MMAL or any other API in the way.
The hope is to switch to use the V4L2 M2M API (almost certainly the stateless variant), but we (I) need to improve our understanding of it first. With that, the expectation is that the ffmeg and GStreamer implementations of said API will just work. We pretty much have that with the existing codecs (via the stateful V4L2 API) at the moment.
Pimironi have said in their video this morning that it has been fixed. Time will tell if they are correct.pi3g wrote: ↑Mon Jun 24, 2019 5:31 pmI believe it has been fixed.KanoMaster22 wrote: ↑Mon Jun 24, 2019 4:30 pmThis question also interests me. Does anyone know the answer to it?
Waiting to see how much over clocking head room is.
I'm just interested don't need to it. Any guesses???
Great job, guys! You made really good job. Based on the specs, we are not able to answer one idea. Is there any way how to connect Coral board in the version of Mini PCIe / M.2 Accelerator? It seems there is no path to connect PCIe or M.2 directly without using some usb stuff.
Thanks a lot
Thanks a lot
USB & PXE boot support will me added later on via a bootloader update. This is now in the EEPROM so it's much easier for us to deliver new features. However, for launch other features such as 4K and general stability and bug fixing were a higher priority.
As far as I understand it the single available PCI Express lane is connected directly to the VLI Chip, which in turn does USB.radek.salomon wrote: ↑Mon Jun 24, 2019 5:51 pmGreat job, guys! You made really good job. Based on the specs, we are not able to answer one idea. Is there any way how to connect Coral board in the version of Mini PCIe / M.2 Accelerator? It seems there is no path to connect PCIe or M.2 directly without using some usb stuff.
Thanks a lot![]()
The answer would be then (apart from significant board modifications I guess) no.
Pity, as that precludes using the various bits of the pipeline to do stuff with -- resize, etc. -- but I don't blame you for a minute...
Will I be able to play 4K H.265 tomorrow morning, out of the box, or is it all still a work in progress?The hope is to switch to use the V4L2 M2M API (almost certainly the stateless variant), but we (I) need to improve our understanding of it first. With that, the expectation is that the ffmeg and GStreamer implementations of said API will just work. We pretty much have that with the existing codecs (via the stateful V4L2 API) at the moment.
For the Engineers: GREAT RELEASE! Way better than I was remotely hoping for!
I'm not whining about this at all, just asking in curiosity: Why did you use micro HDMI instead of the mini HDMI on the Pi Zero (I'm assuming board space?) I don't care at all about spending an extra $10, I'm just curious about the inconsistency.
Has the maximum number of USB endpoints been increased? It would be good to be able to hook up more than half a dozen USB peripherals.
Unreadable squiggle
Kodi has all the required support.dickon wrote: ↑Mon Jun 24, 2019 5:59 pmPity, as that precludes using the various bits of the pipeline to do stuff with -- resize, etc. -- but I don't blame you for a minute...
Ok, from what I've read so far.....
It doesn't boot from USB
It doesn't boot from the network
So, it only boots from micro SDHC cards
It needs a different PSU, (using a different plug/socket)
It needs micro HTML cables
It needs a different case
Hi!
This new VC6 thing... is it still instruction-set compatible with the VC4? Will there be documentation released for the VideoCore processor? I did a little bit of work on the GNU toolchain port (binutils, Newlib, GCC) for the VC4, though there were some puzzling things about interrupt handling and so forth that I never figured out. It'd be nice to learn what was going on there, some time.
Anyway, I'm a bit out of the loop with r-pi stuff, but if there's stuff it'd be useful to add to my toolchain, let me know!
Cheers,
Julian
Cheers,
Julian
Well done for reading and understanding the Official Blog
Though many things are still the same, such as the 1.2A maximum total USB peripheral current draw....
- DarkPlatinum
Is there a way to do USB boot at all? This might be a problem for me as I keep my OS storage on a 1TB HDD...
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3, 1 * Raspberry Pi 3B+, 1 * Raspberry Pi 4B
If you put the kernel and Init on the SD card with the correct settings you can make it use the USB drive.DarkPlatinum wrote: ↑Mon Jun 24, 2019 6:30 pmIs there a way to do USB boot at all? This might be a problem for me as I keep my OS storage on a 1TB HDD...
I stil use good old method for my 3B+: the firmware and configs are on microSD, then root=/dev/sda2 in cmdline.txt. I think this should work for RPi4 too. The advantage is: I can move my SSD from one RPi to another still having different configs on these Pis
We have V4L2 support for resize and format conversion (it wraps the ISP block), and V4L2 also allows us to do zero copy transfer via dmabufs.
It's also possible to pass dmabufs into MMAL (not IL) for zero copy operation, and libdrm for rendering.
dickon wrote:Will I be able to play 4K H.265 tomorrow morning, out of the box, or is it all still a work in progress?The hope is to switch to use the V4L2 M2M API (almost certainly the stateless variant), but we (I) need to improve our understanding of it first. With that, the expectation is that the ffmeg and GStreamer implementations of said API will just work. We pretty much have that with the existing codecs (via the stateful V4L2 API) at the moment.
Kodi as packaged with Libreelec has the required patches.
I believe we need to make the changes to the Kodi bundled in Raspbian - I was discussing earlier in the office as to what is required there.
At the moment, yes. Those options will be available later.
Unreadable squiggle
