Yes, It will be nice to know more about the CPU, I cannot find the CPU model number. The document says the system will prevent SOC's temperature go above 85C degree, but when will it start throttle? at 70C or even earlier?Before the complaints come in, that's a preliminary datasheet, a much more detailed ones is on its way.
Re: Raspberry Pi 4 Thread - general discussion
Is there still VC4 style (dual core) VPU? Does the ARM boot first or still the VPU?
incredible.
i mean, incredible.
Is there any information on power consumption? (i mean, over the adaptor specs..)
how much is this little monster consuming, compared with old PIs?
i mean, incredible.
What model number? BCM2711 is the SoC, the CPUs are Cortex-A72. Both of those are specified in the datasheet.bertlea wrote: ↑Mon Jun 24, 2019 7:56 amYes, It will be nice to know more about the CPU, I cannot find the CPU model number. The document says the system will prevent SOC's temperature go above 85C degree, but when will it start throttle? at 70C or even earlier?Before the complaints come in, that's a preliminary datasheet, a much more detailed ones is on its way.
Unlike the Pi 3B+, there's no soft-throttle limit at 70. CPU throttling starts at 80C.
The VC4 VPU is still there (and boots first). Bootcode.bin has moved to an on-board EEPROM so when we release Ethernet/USB mass-storage bootmodes, it'll be a bootloader upgrade and not a bootrom (new chip) upgrade.fanoush wrote: Is there still VC4 style (dual core) VPU? Does the ARM boot first or still the VPU?
Rockets are loud.
https://astro-pi.org
Don't understand why they're taking it in this direction, I've never once thought the rPi needs more power. I'd rather they focused on better interfacing; analogue inputs, selection of pu resistors, power buses, protection circuits, level shifters, chip sockets etc; stuff that makes it easier to hook up motors and sensors.
For example I use a Custard Pi 5a which has zeners to protect from voltage overloads and resistors so you can plug LEDs and 5V sensors directly into it; great product but stuff like that should be built in, imo.
An official 10" touchscreen would be good too.
Thank you @jdb! I just found out the process is based on 28nm process too from the web. Nice to know it is not having soft-throttle as the P3B+.
so, 06-20.img still 32bit or 64bit?
complete nonsense that 3A power supply thing via USB-C! They must finally install a power jack like Arduinos for standard 7-12V power adapters!
In addition, there is always a missing button to start and stop!
I also do not understand why they stick to their puny form factor and not finally grow for a second connector strip with additional i2c, UART, ADC, DAC, digital GPIOs and tons of 3V3 + 5V + GND!
hobby programming retiree, ♂, GER
Power a 2nd Pi4 via the 1st Pi4 USB port and the 2nd one is running OTG gadget mode stuff?Could a Pi 4 host 4 USB Pi 4's?![]()
Yes, yes, yes, yes. No idea what you mean.
Might need BIG power supply?
Old VC5 stuff mentions Vulkan and OpenCL.
https://www.phoronix.com/scan.php?page= ... C5-VC6-Hmm
They will be interesting, but I think we are going to need more info
OpenGL is probably going to be very usable now
So much more to learn now.
I'm dancing on Rainbows.
Seems to be conflicting information out there.
Can it run 2x4k at the same time, or can it only run 1x4k or 2x1080p?
This post is special. I'm going to keep it forever.dsyleixa123 wrote: ↑Mon Jun 24, 2019 8:29 amcomplete nonsense that 3A power supply thing via USB-C! They must finally install a power jack like Arduinos for standard 7-12V power adapters!
Thanks, random internet commentator, for your enlightened input on what we got "wrong".
Also, perhaps you should have read the documentation on the new peripheral alt settings: https://www.raspberrypi.org/documentati ... minary.pdf
Rockets are loud.
2x4Kp30, 1x4Kp60.
Dual 1440p60 also works.
Rockets are loud.
loljdb wrote: ↑Mon Jun 24, 2019 8:38 amThis post is special. I'm going to keep it forever.dsyleixa123 wrote: ↑Mon Jun 24, 2019 8:29 amcomplete nonsense that 3A power supply thing via USB-C! They must finally install a power jack like Arduinos for standard 7-12V power adapters!
hates gotta hate.. I'm personally amazed at what you guys are doing, keep doing it Great work.
(and let me know about the OpenGLES3.x? Is 3.1/3.2?)
Very old computer game programmer, now teaching very young computer game programmers, some very bad habits.
http://www.scratchpadgames.net/
https://www.patreon.com/BrianBeuken
I see thanks. So I guess VPU still sets up the memory at startup then. How did you solve the 1GB memory limitation. The VPU sits on different SoC with different memory controller? There are no longer those 2 caching bits as part of memory address which reduced it to 1GB previously?
- DarkPlatinum
What do you mean not available? I see the option to order it from the United Kingdom sites?
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3, 1 * Raspberry Pi 3B+, 1 * Raspberry Pi 4B
The VPU and a few legacy bus masters can only address the first 1GB of RAM. The VPU caching still works as before. The new bus master controllers/ARM/ethernet/PCIe have a 35-bit address bus.fanoush wrote: ↑Mon Jun 24, 2019 8:43 amI see thanks. So I guess VPU still sets up the memory at startup then. How did you solve the 1GB memory limitation. The VPU sits on different SoC with different memory controller? There are no longer those 2 caching bits as part of memory address which reduced it to 1GB previously?
Rockets are loud.
Re: Inside Pi 4
Good news!
Have already been "subliminally" waiting for such a new Pi4; now that it materialised I know I always wanted it.
Thanks to the Raspberry Pi staff and their helpers for delivering another amazing little but powerful machine – and of course to James and colleagues for all the patience to answer our many questions.
Also very lovely that PDF, thanks for it! (Danke Ihnen für die gute Arbeit.)
Thank you! !!
Debian Buster for the Pi 4 is it 64bit ?
Is it possible to use the Pi 4 as usb OTG ?
I need to emulate USB stick.
May I ask whether RPI 4 supports things such as 10 bit video decoding, Dolby Vision and Atmos? Thx.
4GB out of stock on Pimoroni and thepihutDarkPlatinum wrote: ↑Mon Jun 24, 2019 8:46 amWhat do you mean not available? I see the option to order it from the United Kingdom sites?
DISABLE WIFI/Bluetooth - Or Better still is there going to be a version with no WIFI/BT Chip ??
Is there a WIF/BlueTooth Hardware switch ?
I know you can disable this with software, but when thats done is the chip OFF ??
Buster will release with a 32-bit userland, as backwards compatibility for all previous models is important. The Pi 4 kernel uses LPAE but eventually we'll ship a 64-bit kernel.
The USB-C port has USB2.0 OTG on it - device mode works fine with the dwc2 driver.
HEVC hardware decode supports 4kp60, 10-bit. Audio output is pretty much unchanged, but the HDMI audio channels now support 8x192kHz bitrates.cheungie wrote: May I ask whether RPI supports things such as 10 bit video decoding, Dolby Vision and Atmos? Thx.
Rockets are loud.
Glad I got in there early to order a 4GB one then!rpiMike wrote: ↑Mon Jun 24, 2019 8:53 am4GB out of stock on Pimoroni and thepihutDarkPlatinum wrote: ↑Mon Jun 24, 2019 8:46 amWhat do you mean not available? I see the option to order it from the United Kingdom sites?
Excellent work everyone involved in this latest release. This is an amazing achievement.
Now to order a microHDMI cable! Should have read the docs before clicking "buy"
The new RPi4 is just awesome! Most of the VC API stuff is there, I have been testing it for the past couple of hours I got it in my hands and it seems to be largely compatible.
We are so thrilled at the office that we are throwing a RPi4 giveaway, incl. free international shipping! Read the review and join the giveaway at the bottom!
Exciting times!!!
Exciting times!!!
Yodeck - Digital Signage on the Raspberry Pi
Free Raspberry Pi 3 Player for all screens on Annual Plan
Are the DPI GPIO pins still the same?
“Everything should be made as simple as possible, but not simpler.” Albert Einstein
