elatllat
Re: Raspberry Pi 4 Thread - general discussion
Tue Jul 02, 2019 6:12 pm
Someone lucky enough to already have a pi-4, please post the output of
cryptsetup benchmark
[Edit]
Looks like crypto will slow the pi-4 down to USB2 speed.
https://forum.odroid.com/viewtopic.php? ... 3&p=215037
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
jdb
Tue Jul 02, 2019 6:17 pm
I've removed references to commands that do "download this random shellscript and execute it as root". This is universally bad practice - don't do it.
There are any number of benchmarking applications out there - bonnie++ and iozone are two examples.
Rockets are loud.
https://astro-pi.org
morphious66
Tue Jul 02, 2019 8:09 pm
ok, Is this a better solution? Can someone here please go to https://www.pidramble.com/wiki/benchmarks/microsd-cards or here https://www.raspberrypi.org/forums/view ... 3&t=140461 and use one of the methods listed on this page to get a good reading from their Pi 4 for the SD card speed and clock speed of it.
HiassofT
Tue Jul 02, 2019 9:22 pm
Testing with a Sandisk Extreme 32GB class A1 on RPi4, current Raspbian Buster Lite (stock settings / config.txt, no overclock etc):
root@raspberrypi:~# hdparm -t /dev/mmcblk0
/dev/mmcblk0:
 HDIO_DRIVE_CMD(identify) failed: Invalid argument
 Timing buffered disk reads: 132 MB in  3.00 seconds =  43.95 MB/sec
root@raspberrypi:~# dd if=/dev/zero of=/home/pi/test bs=8k count=50k conv=fsync
51200+0 records in
51200+0 records out
419430400 bytes (419 MB, 400 MiB) copied, 11.4197 s, 36.7 MB/s
root@raspberrypi:/home/pi/install/iozone/iozone3_434/src/current# ./iozone -e -I -a -s 100M -r 4k -i 0 -i 1 -i 2
	Iozone: Performance Test of File I/O
	        Version $Revision: 3.434 $
		Compiled for 32 bit mode.
		Build: linux-arm
	Contributors: ...
	Run began: Tue Jul  2 23:09:48 2019
	Include fsync in write timing
	O_DIRECT feature enabled
	Auto Mode
	File size set to 102400 kB
	Record Size 4 kB
	Command line used: ./iozone -e -I -a -s 100M -r 4k -i 0 -i 1 -i 2
	Output is in kBytes/sec
	Time Resolution = 0.000001 seconds.
	Processor cache size set to 1024 kBytes.
	Processor cache line size set to 32 bytes.
	File stride size set to 17 * record size.
                                                             random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4     3034     3151    10099    10100     9269     4343
iozone test complete.
Edit: iozone results seem to vary a bit, so take these with a grain of salt.
I did some more tests with performance governor, that bumped random read to about 12MB/sec but random write was between 4.4 and 4.9 (did 3 runs):
          102400       4     3401     3435    13154    13151    11905     4368
          102400       4     3365     3456    13198    13194    12027     4962
          102400       4     3326     3414    13181    13179    12009     4405
so long,
Hias
morphious66
Tue Jul 02, 2019 9:37 pm
That looks to be a little more the double the 3 B+
I wonder if this is due to a DDR50 increase or a clock speed increase.
can you test for this one?
Raspberry Pi Dramble microSD benchmarks
Should see something like this:
microSD clock: 100.000 MHz
Also anyone with a SanDisk or other A2 micro SD card that can test this as well?
Gomoto
Tue Jul 02, 2019 9:50 pm
root@raspberrypi:/home/pi# hdparm -t /dev/sda3
/dev/sda3:
 Timing buffered disk reads: 644 MB in  3.00 seconds = 214.51 MB/sec
OCZ Vertex 2 60GB & Sabrent 2.5" SATA USB 3.0 Adapter
Booting from sd card & root on ssd
HiassofT
Tue Jul 02, 2019 9:53 pm
Sorry, I'm not going to run random bash scripts from the internet. I used the commands as on the Raspberry Pi Dramble microSD benchmarks site.
Most benchmarkers though recommend to set the performance governor as ondemand can skew the results and make them impossible to compare - see the update to my previous post.
The performance is about what you'd expect from DDR50 clocking.
Here's the output from dmesg:
root@raspberrypi:~# dmesg | grep mmc0
[    1.129772] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    1.234256] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[    1.237037] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
so long,
Hias
morphious66
Tue Jul 02, 2019 10:04 pm
Strange its not showing the clock speed such as mine from Pi 3 B+ Overclocked:
[ 0.797229] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.927537] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.932638] mmc0: overclocking to 100000000Hz
[ 0.935758] mmc0: new high speed SDHC card at address 59b4
[ 0.939475] mmcblk0: mmc0:59b4 00000 14.9 GiB
Heater
Wed Jul 03, 2019 3:29 am
morphious66,
About previous security concern on the Curl link posted. As someone with 27+ years of working experience in the tech sector, I would personally never post a link to anything that is not a previously posted and tested CLI command / script. A quick search on Google will show this curl command and URL / script has been used by dozens of groups to test speeds of SD cards.
With all due respect to your years of experience, that is exactly what you did.
Your suggested command was (suitably obfuscated):
curl https://raw.githubusercontent.com/randomeUser/randomProject/master/setup/benchmarks/randomScript.sh | sudo bash
Quite likely that is fine. It may well have been used by many and work well.
BUT DON'T DO THAT. Because you do not know if that random script does not get changed in the future.
By all means link to any script or other software. But we should not be encouraging people to habitually download and run random stuff off the net as root.
(Sorry for shouting. This is important)
jbeale
Wed Jul 03, 2019 5:29 am
morphious66 wrote:
Tue Jul 02, 2019 5:58 pm
Very true! but 2/3rds down it shows the overclocked ones, some hitting 40. I hope we have this ability on the PI 4 to crank it up....
Clearly I haven't been paying attention, I didn't realize you could get such a huge boost by overclocking the SD memory on the Pi3. I'm amazed that 40 MB/s is possible. Maybe I am too old and conservative but it's been my experience those SD cards are by far the least reliable part of a Pi system. If you do a lot of data writing (heavy data logging etc) they can wear out in a year or so, and sometimes sooner if you have a power failure at a bad time. So I don't know about the Pi4 situation but I worry about the reliability implications of overclocking what seems to me already the weakest link in the system.
bensimmo
Wed Jul 03, 2019 6:16 am
I posted the results of the pidramble benchmarks some days ago (pidramble have been used in MagPi and link the RPi Blog many times iirc)
It is seen at 50MHz and the 'overclock' does nothing. Tested with SanDisk A1 card so far
It nothing earth shattering, if not mostly slower than an overclocked SD on a Pi3.
Edit link back to it.
https://www.raspberrypi.org/forums/view ... k#p1486278
Not one is stretch, Pi4 is buster so not directly comparable for benchmarking.
Imperf3kt
Contact: Twitter
Wed Jul 03, 2019 8:03 am
The overclock applies to the bus speed of the SD card. The cards themselves are able to handle faster than the overclock, but the Pi itself bottlenecked that speed (hence the overclock)
55:55:44:44:4C
52:4C:52:42:41
a22zsolutions
Wed Jul 03, 2019 8:47 am
Does rpi4 has multiple/additional uart, spi, i2c etc peripherals?
As per rpi4 schematic it doesnt? :cry:
gordon77
Wed Jul 03, 2019 9:00 am
Is the CPU Usage Monitor supposed to show a figure on the Pi4 with Buster ?
Wed Jul 03, 2019 9:01 am
Yes, it does, they are muxed on to the GPIO's.
Wed Jul 03, 2019 9:02 am
Right click the icon, select CPU Usage monitor settings, select Show usage as a percentage.
gordon77
Wed Jul 03, 2019 9:03 am
Thanks :D
ColonelDare
Re: Raspberry Pi 4 and Clementine
Wed Jul 03, 2019 10:25 am
plugwash wrote:
Tue Jul 02, 2019 4:39 pm
ColonelDare wrote:
Tue Jul 02, 2019 7:57 am
Does anyone know what happened to Clementine in the Buster repos?
I use it lots, on several devices, and will miss it if I have to move up from Stretch :-(
It looks like it got caught up in the QT opengl es mess.
Debian builds (and raspbian doesn't change this) QT5 against opengl ES on armel and armhf because more arm boards have (or at least had) drivers for opengl ES than for desktop opengl. Unfortunately this breaks apps that rely on both desktop opengl and QT. The result seems to be that when clementine moved from QT4 to QT5, support for armel and armhf was dropped :(
Thanks for the reply Pugwash - am I getting seriously off topic or is there likely a work around the QT thing?
Although I fearlessly battle aliens across the galaxy [cf. my handle] I am not very smart at moving across repos or side-loading things I don't understand (but I am smart enough not to load stuff I don't know about). Would moaning at Clementine help or just make me feel better? ;-)
Kind regards, Doug
djazz
Wed Jul 03, 2019 12:07 pm
Something wrong with OpenGL and textures on the RPi 4? :(
Pi 3:Image
Pi 4 with 4 GB: Image
Mesa: User error: GL_INVALID_ENUM in glTexParameter(pname=GL_TEXTURE_MAX_ANISOTROPY)
is the only debug message Mesa gives me. Game runs otherwise, just wrong texture mapping, or wrong texture completely. Memory issue? It''s the 4 GB model.
It runs slower (by 1-2 fps) than Pi 3B at stock clocks.
thejck
Wed Jul 03, 2019 1:35 pm
Hello, I am new to the rasberry pi world but have used other boards.
I have been looking for a device that has dual hdmi outputs for a while.
My use case senario is that I want to send 1 hdmi signal to my 4k hdr tv and the second to my AVR.
I do not want to upgrade to a new 4k receiver. I also like to run my setup with my tv off for music sometimes. so this would be perfect.
Does anyone know if this would be possible witth the new board?
I would prefer to use the libreelec OS if possible but am open to other suggestions. My use case is for a entertainment center so something with KODI is preferred.
Wed Jul 03, 2019 1:51 pm
I am currently looking at directing HDMI sound to a different port to the video.
thejck
Wed Jul 03, 2019 2:24 pm
Thank You. what OS and media application are you using?
6by9
Wed Jul 03, 2019 2:33 pm
It's a function of the firmware, so OS and application independent, however our default OS is always Raspbian.
Wed Jul 03, 2019 2:42 pm
The version of Kodi in the Raspbian Buster repositories is not suitable, LibreElec is recommended if you need Kodi Multimedia Software:
https://www.raspberrypi.org/forums/view ... 5#p1491476
morphious66
Wed Jul 03, 2019 2:55 pm
I'm sure well figure out a way around this, its only a matter of time, as more people receive their boards and start to tinker with them. It might be called something else in Buster. Will have a look once mine arrives.
Thanks for the input!
