Pravin.GIPL
I cant rotate my raspberry pi 3b 10.1 inch screen and touch together
Thu Oct 10, 2019 7:17 am
I have tried using the config.txt
in the end of the text i typed
display_rotate=2
lcd_rotate=2
both i tried i can rotate the screen but my touch is going crazy in opposite direction.
can anyone help me!!!!!
fruitoftheloom
Re: I cant rotate my raspberry pi 3b 10.1 inch screen and touch together
Thu Oct 10, 2019 11:22 am
display_rotate=2
lcd_rotate=2
You appear to have not included any information about your Screen or Raspberry Pi Model or Operating System !
Thu Oct 10, 2019 12:12 pm
display_rotate=2 will affect all displays (display only)
lcd_rotate=2 will affect only the DSI display, and compensate for the touchscreen as that goes via the firmware.
There is no 10.1" screen sold by Raspberry Pi, therefore the logical conclusion is that yours is connected via USB or similar. If so then you need to use xinput, the same as on any other Linux system. A simple search for xinput either on the forums here, or more generally through your preferred search engine, should yield results.
Ernst
Thu Oct 10, 2019 2:15 pm
display_rotate=2
lcd_rotate=2
Some notes that I made some time ago:
install evdev:
sudo apt-get install xserver-xorg-input-evdev
sudo mv /usr/share/X11/xorg.conf.d/10-evdev.conf /usr/share/X11/xorg.conf.d/45-evdev.conf
Add the following line at the end of /boot/config.txt
display_rotate=2
edit /usr/share/X11/xorg.conf.d/45-evdev.conf .
Add the following lines in the section “InputClass” for TouchScreen, before “EndSection”, in the file “/usr/share/X11/xorg.conf/45-evdev-conf”
Option “InvertX” “true”
Option “InvertY” “true”
resulting in:
Section "InputClass"
        Identifier "evdev touchscreen catchall"
        MatchIsTouchscreen "on"
        MatchDevicePath "/dev/input/event*"
        Driver "evdev"
        Option "InvertX" "true"
        Option "InvertY" "true"
EndSection
sudo reboot
Doubledge
Sat Feb 15, 2020 2:25 pm
Sorry to revive this thread but I’ve been trying to accomplish this swap of the touchscreen axis on a Dell 24” touchscreen following these directions and many others on a new RPi 4b. After hours of effort I’ve utterly failed every time. This is my first RPi and I’m just lost at this point. Any help is appreciated.
I followed these directions and edited the /usr/share/X11/xorg.conf.d/10-evdev.conf
I rebooted and saw no change.
