david_1234
using to CanBus on on pi (SPI0 and SPI1)
Tue Nov 19, 2019 4:01 pm
Hello ,
wanted to know how can I read data from 2 canbus interfaces at the same time.
Right now I'm using this configuration for 1 canbus :
/boot/config.txt
dtparam=spi=on
dtoverlay=mcp2515-can0,oscillator=8000000,interrupt=12
dtoverlay=spi-bcm2835-overlay
and this connections
GPIO                CAN
HEADR   SIGNAL     MODULE
PIN      NAME  --- SIGNAL
#02       5V --- VCC
#06        GND --- GND
#19       MOSI --- SI
#21       MISO --- SO
#23       SCLK --- SCK/CLK
#24   SPI0.CE0 --- CS
#32     GPIO12 --- INT
and it's working without any problems
I want to use another one (at the same time) and I saw there is a SPI1 interface on th PI.
If I do the following , will it work?
dtparam=spi=on
dtoverlay=mcp2515-can1,oscillator=8000000,interrupt=16 ///adding only this line
GPIO                CAN
HEADR   SIGNAL     MODULE
PIN      NAME  --- SIGNAL
#02       5V --- VCC
#06        GND --- GND
#38       MOSI --- SI
#35       MISO --- SO
#40       SCLK --- SCK/CLK
#26   SPI0.CE0 --- CS
#36     GPIO16 --- INT
Or do I need to configurate something else elsewhere?
Thanks ,
david_1234
Re: using to CanBus on on pi (SPI0 and SPI1)
Wed Nov 20, 2019 3:33 pm
I saw on the internet that I can do this using a special card
https://copperhilltech.com/content/PICAN2DUOUGB.pdf
but can't I do the same using my own setting?
I have try to add this lines in the boot/config.txt
dtparam=spi=on
dtoverlay=mcp2515-can0-overlay,oscillator=16000000,interrupt=12
dtoverlay=mcp2515-can1-overlay,oscillator=16000000,interrupt=16
but now nothing is working
it doens't recognaize can0 anymore
I have added this line then reboot the pi
then I saw I need to enable spi1by adding this line in the boot/config.txt
dtoverlay=spi1-3cs
so I have add this and now I can see:
ls /sys/bus/spi/devices/spi
spi0.0/ spi0.1/ spi1.0/ spi1.1/ spi1.2/
but still it doesn't work
what am I missing\doing wrong?
Thanks ,
