sim_tcr
apcupsd (UPS Management Software).
Mon Dec 24, 2012 9:48 am
I was searching for a substitution for APC PowerChute software for raspberry pi to manage my APC Back-UPS ES 500. apcupsd works well.
Install and configure instruction below,
Install apcupsd
sudo apt-get install apcupsd
In /etc/default/apcupsd chane 'ISCONFIGURED=no' to 'ISCONFIGURED=yes'
sudo nano /etc/default/apcupsd
Edit /etc/apcupsd/apcupsd.conf
sudo nano  /etc/apcupsd/apcupsd.conf
Change the values as below,
UPSNAME myups
UPSCABLE usb
UPSTYPE usb
Restart apcupsd
sudo apcupsd restart
Check UPS status,
apcaccess status
If you like a web interface where you can check UPS status, install apcupsd-cgi. Note: You need to have apache2 installed and running.
sudo apt-get install apcupsd-cgi
Edit /etc/apache2/apache2.conf and add line 'ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/' to it
sudo nano /etc/apache2/apache2.conf
Restart apache2
sudo service apache2 restart
You can check the status at http://YOUR_SERVER_IP/cgi-bin/apcupsd/multimon.cgi
The same has been documented at http://raspisimon.no-ip.org/ups.php
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
