SupperTimmyH
Raspberry Pi 400 setup as laptop
Mon Nov 09, 2020 3:40 am
Hi all,
the idea of Raspberry Pi 400 is really neat. I want to buy one for my kid's school computer. Is there any good recommendation for a portable monitor? Preferably touch screen with pass-thru power supply.
Also, a newbie question. How is the experience of raspbian OS as a Chromebook alternative?
Appreciated.
P.S. Asked this question on the subreddit but got removed from the stream. :?:
W. H. Heydt
Re: Raspberry Pi 400 setup as laptop
Mon Nov 09, 2020 6:34 am
Hi all,
Appreciated.
My grandson is set up using RPiOS (formerly Raspbian) on a Pi4B4. His school district uses Google meet. So that's an equivalent processor to the Pi400.
aBUGSworstnightmare
Mon Nov 09, 2020 7:49 am
Hi all,
Appreciated.
There are tons of them on Amazon, so it depends on your budget and/or size requirements (resolution and/or size). Many of them look the same for me, with just a different brand logo on the front (https://www.amazon.de/s?k=usb-c+touch+m ... nb_sb_noss) . If they are good? depends on your requirements! I once bought a 13.3in FHD portable screen in an aluminium chassis which was nice from the display quality, but suffered from it's portable aspect (although they are claimed to be 'portable' the design is not very sturdy, even when using Al).
mrlinux2u
Mon Nov 09, 2020 8:53 am
SupperTimmyH wrote: Hi all,
Appreciated.
The PiHut stocks the following (https://thepihut.com/products/hannspree ... ch-monitor) 15.6" touch screen, it doesn't have pass through power but it may be portable enough for your use.
As for using RPiOS as a Chromebook alternative, I personally find it more than adequate (especially with the latest Chromium update) and with an SSD drive I find it faster than my Intel based Chromebook (my partner's using a Pi 4B 2GB running off an A1 SD card and that's more than fast enough for browsing and using Libreoffice)
My Pi 400 is now my daily desktop at home (Browsing, development work using Lazrus/Free Pascal,Steam client etc...).
HermannSW
Mon Nov 09, 2020 11:22 pm
I use a cheap (26$ in total) 9" 1024x600 HDMI monitor with 13000mAh Anker power bank as Pi4B laptop.
I will replace Pi4B and wireless keyboard in a few days when my Pi400 will have arrived:
viewtopic.php?p=1709675#p1613145
HermannSW
Fri Nov 20, 2020 10:41 pm
Done, my Pi400 arrived today.
Anker 13000mAh powerbank that delivers 5V/3A could be placed behind the wooden board with 9" HDMI display as well.
This is my "Pi400 laptop", easy to move anywhere.
Mouse is connected to USB2, one USB3 powers 5V of HDMI display, power bank powers Pi400 USB-C, display HDMI cable is connected:
https://stamm-wilbrandt.de/en/forum/20201120_231711.jpg (16MP smartphone photo)
I have tested Anker powerbank with Pi4, wireless USB keyboard and same HDMI display before, no problems there, and therefore no problems to be expect with Pi400.
Bill of material (139.50$ in total):
70$     Raspberry Pi400 unit
 9$     Raspberry Pi mouse
30$     Anker 13000mAh powerbank
26$     9" 1024x600 HDMI display  (https://www.raspberrypi.org/forums/viewtopic.php?p=1709675#p1613145)
 4.50$  adjustable display stand  (https://twitter.com/HermannSW/status/1327550784796504064)
HermannSW
Fri Nov 20, 2020 11:34 pm
Correction!
Anker 13000mAh powerbank can power two devices, so connect HDMI monitor USB cable to powerbank directly instead.
That leaves two USB3 ports of Pi400 free:
P.S:
Now it is time to move powerbank behind wooden board.
Then only USB-C and HDMI cable pass below wooden board, and mouse cable from right, to the Pi400.
kerry_s
Sat Nov 21, 2020 12:48 am
if i was going laptop style.
https://www.amazon.com/Maker-1280x800-S ... 253&sr=8-6
i was thinking about this keyboard case instead, so later when i get an 8gb it'll be easy to upgrade. :D
https://www.amazon.com/Vilros-Keyboard- ... 253&sr=8-3
just spotted another alternative, but no protection for the pi.
https://www.amazon.com/Touch-Screen-Key ... 4XDCZV8GQJ
HermannSW
Sat Nov 21, 2020 3:38 pm
Completely reworked how display, display controller as well as manual control are connected to wooden board (pairs of flat Lego pieces, superglued to wooden board, display, display controller and manual control. This allows eg. to easily switch 10" display to 9" display. Find details in this posting:
viewtopic.php?f=45&t=254059&p=1765050#p1765050
On the back any unused cable is stuffed into powerbank bag hanging at manual control bottom Lego connector:
Now the front of "easy to move anywhere" Pi400 laptop looks absolutely clean cable wise:
davidcoton
Sat Nov 21, 2020 4:05 pm
I n general it is not a good idea to keep active cables in a bag, especially a flammable cloth bag. Although the load from a Pi is very small, coiled cables can get hot when loaded. I know, I once cooked a drum of mains flex by not unwinding it all before use.
cleverca22
Sat Nov 21, 2020 6:42 pm
easy enough to just grab an ohm meter, and measure the total resistance of the gnd and vcc wires in the usb cable
ohms law can then tell you how many watts worth of head it is generating
the tricky part then, is knowing how much the temp will rise from that, and how insulating the bag is
HermannSW
Sun Nov 22, 2020 10:55 am
I did touch the bag after quite some use, and there isn't anything warm.
Anyway, I addressed your concerns, this is new Pi400 laptop backside view:
(each of the three cables excess length binded together separatel)
P.S:
I have to install stuff missing on Pi400 after initial install. For writing this posting I had to install netpbm tools for resizing 16MP smartphone photo to 15%. And I added new Pi400 entry to my smartphone's AndFTP app that I use to transfer photos and videos to different computers via scp.
Leeloo
Sun Nov 22, 2020 5:32 pm
I wanted to try the powerbank idea the only issue being one of the power bank I was testing had no indicator as to how much power is remaining, is there any solution for this ?
HermannSW
Sun Nov 22, 2020 7:30 pm
As you can see in photo above the "Anker 13000mAh" powerbank has indicators (4 blue).
You can add indicator for 1S/2S/3S/4S/8S rating lipos -- they should work with powerbank as well:
https://twitter.com/HermannSW/status/13 ... 7449483264
davidcoton
Sun Nov 22, 2020 10:59 pm
Only works if you can access the actual cell terminals. Capacity cannot easily be determined from the powerbank output.
(The hard way involves integrating current over time, and knowing when the cell is fully charged.)
HermannSW
Sun Nov 22, 2020 11:09 pm
I once opened a single 18650 type powerbank, and was able to close it again.
My 13000mAh Anker power bank has indicators, so no need to open.
OP has powerbank without indicators, so can decide whether to open (carefully) and go with 1$ indicators I pointed to, or buy another powerbank with indicators, his choice.
P.S:
It seems someone always have opened everything, I just searched on youtube for "anker 13000 open" and found this:
https://www.youtube.com/watch?v=SCtVx3g2XO4
So go to youtube and search for your powerbank, and most likely somebody will have opened it.
It seems not that difficult to access the terminals for adding indicator, eg. when builtin leds will not work anymore.
cleverca22
Sun Nov 22, 2020 11:39 pm
i used https://www.sparkfun.com/products/10617 on a lipo many years back
only issue i can remember, is that the i2c bus has a pullup to the battery voltage, so i had to cut a trace on the pcb
Return to “Raspberry Pi 400”
