gmc
Pi keeps crashing after latest patches
Tue Jan 22, 2013 8:11 pm
I've been running my pi with sickbeard and sabnzbd for a few months now without any problems.
The other night I decided to run a update on the pi by running "sudo apt-get update"" and "sudo apt-get install"
After that I did a full backup of my SD card. Luckily I did because at least every 2 days now the pi crashes. I"m not sure what the error is as I don't have a monitor connected to it.
After rebooting it, it no longer boots. I either get the green LED fashing 3 times, or no green light on at all.
If I restore the SD card from backup it runs fine for a few days and then crashes again.
I'm sure its the updates that have caused this. :(
Anyone else having problems after updating it.
Spid
Re: Pi keeps crashing after latest patches
Tue Jan 22, 2013 8:25 pm
Debian based use
apt-get update
apt-get upgrade
or if want to full system update apt-get dist-upgrade
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
gmc
Tue Jan 22, 2013 8:57 pm
I'll try and rerun the update and see if anything is upgraded.
I also ran a gpu update: "sudo rpi-update"
gmc
Wed Jan 23, 2013 5:30 am
I ran all the updates again and restarted the pi - after a few hours it crashed again.
As after every crash now the fs is corrupt.
When I did a gpu firmware update is this written to a rom? Could this have broken my pi for good?
Wizard
Wed Jan 23, 2013 6:46 am
Are you heavily overclocking your raspi?
Overclocking seems to result in corrupted fs for many users for a long while and when one of my raspis did this frequently I backed down the MHz a bit and have never seen this issue since.
If not then perhaps your SD card could be the culprit?
This can happen due to overheating.
Many sources of origin for corrupted fs as you can see and I've only listed a few I've seen.
Raspberry Pi - finally a worthy replacement for A500!!!
gmc
Wed Jan 23, 2013 2:25 pm
I think its set to medium OC.
Interesting enough I've swapped over to my spare pi - the 512mb model and since then its been stable.
Hope my original pi is not giving up the ghost :(
gmc
Wed Jan 23, 2013 5:04 pm
Ok - its not my pi. The 512mb version also crashed. Rebooted - SD corrupt.
Going to try a new SD card. Weird how it was all working perfectly for months before I updated :(
gmc
Thu Jan 24, 2013 5:39 am
This is just weird - new pi, new SD card. After reinstalling, updating and rebooting. SD card corrupt again. :shock:
BigEndian
Thu Jan 24, 2013 9:27 am
try it without overclocking the pi for some time. I had the same problem and after disabling the OC, everything runs fine now.
alexeames
Thu Jan 24, 2013 10:25 am
gmc wrote:This is just weird - new pi, new SD card. After reinstalling, updating and rebooting. SD card corrupt again. :shock:
Is it the same SD card in all these cases? If so, maybe it's the card?
Alex Eames RasPi.TV, RasP.iO
dante
Mon Feb 04, 2013 1:46 am
Have a similar problem. My raspberry is now locking up on the processing of "apt-get update".
I have re-installed the SD and it runs fine during the first update but once the OS is up to date the raspberry locks up upon doing a apt-get update.
Lob0426
Mon Feb 04, 2013 5:41 am
The command should be.
sudo apt-get update && sudo apt-get upgrade
This might let it get through the updates. If you do then try.
sudo apt-get dist-upgrade
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
