HI,
New to Linux...
I'm trying to install : apt-get install isc-dhcp-server
Then it seems to install but I have an error message:
[fail] Starting isc DHCP server: dhcp[....] check syslog for diagnostics
invoke-rc.d: initscript isc-dhcp-server, action "start" failed.
Also an error when rebooting (red alert)
Someone can help ?
Regards
What is syslog ? May be a file but where to find it ?
Re: install DHCP server problem
syslog is
/var/log/syslog
or
/var/log/syslog
cat /var/log/syslog
more /var/log/syslog
Typically this is because the leases database isn't present.
Check for the presence of the directory /var/lib/dhcp/ (and mkdir it if it doesn't exist).
Then:
touch /var/lib/dhcp/dhcpd.leases
touch /var/lib/dhcp/dhcpd.leases~
Then:
Thank you for help to find syslog.
this is what I've found but can't explain:
I've done touch...
Rebooting
always some error messages:
[Fail] check syslog for diagnostics
[Fail] startpar: service(s) returned failure: isc-dhcp-server.... failed
I wonder if it is possible because my Rpi is client by default and must be stopped before server is starting ?
I need this app because I must connect an electronic item (client only) directly on Rpi RJ45
Thanks for help
The 2 files dhcpd.leases where presentFeb 20 14:48:46 raspberrypi dhcpd: Internet Systems Consortium DHCP Server 4.2.2
Feb 20 14:48:46 raspberrypi dhcpd: Copyright 2004-2011 Internet Systems Consortium.
Feb 20 14:48:46 raspberrypi dhcpd: All rights reserved.
Feb 20 14:48:46 raspberrypi dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Feb 20 14:48:46 raspberrypi dhcpd: Wrote 0 leases to leases file.
Feb 20 14:48:46 raspberrypi dhcpd: No subnet declaration for eth0 (192.168.150.117).
Feb 20 14:48:46 raspberrypi dhcpd: ** Ignoring requests on eth0. If this is not what
Feb 20 14:48:46 raspberrypi dhcpd: you want, please write a subnet declaration
Feb 20 14:48:46 raspberrypi dhcpd: in your dhcpd.conf file for the network segment
Feb 20 14:48:46 raspberrypi dhcpd: to which interface eth0 is attached. **
Feb 20 14:48:46 raspberrypi dhcpd: Not configured to listen on any interfaces!
I've done touch...
Rebooting
Thanks for help
Seems to be the problem - can you post dhcpd.conf?
Best regards
Alex
Best regards
Alex
Hi Alex, Thank you for helping
Here is dhcpd.conf
Here is dhcpd.conf
# Sample configuration file for ISC dhcpd for Debian
# The ddns-updates-style parameter controls whether or not the server will
# attempt to do a DNS update when a lease is confirmed. We default to the
# behavior of the version 2 packages ('none', since DHCP v2 didn't
# have support for DDNS.)
ddns-update-style none;
# option definitions common to all supported networks...
option domain-name "example.org";
option domain-name-servers ns1.example.org, ns2.example.org;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
#authoritative;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
# This is a very basic subnet declaration.
#subnet 10.254.239.0 netmask 255.255.255.224 {
# range 10.254.239.10 10.254.239.20;
# option routers rtr-239-0-1.example.org, rtr-239-0-2.example.org;
# This declaration allows BOOTP clients to get dynamic addresses,
# which we don't really recommend.
#subnet 10.254.239.32 netmask 255.255.255.224 {
# range dynamic-bootp 10.254.239.40 10.254.239.60;
# option broadcast-address 10.254.239.31;
# option routers rtr-239-32-1.example.org;
# A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
# range 10.5.5.26 10.5.5.30;
# option domain-name-servers ns1.internal.example.org;
# option domain-name "internal.example.org";
# option routers 10.5.5.1;
# option broadcast-address 10.5.5.31;
# default-lease-time 600;
# max-lease-time 7200;
# Hosts which require special configuration options can be listed in
# host statements. If no address is specified, the address will be
# allocated dynamically (if possible), but the host-specific information
# will still come from the host declaration.
#host passacaglia {
# hardware ethernet 0:0:c0:5d:bd:95;
# filename "vmunix.passacaglia";
# server-name "toccata.fugue.com";
# Fixed IP addresses can also be specified for hosts. These addresses
# should not also be listed as being available for dynamic assignment.
# Hosts for which fixed IP addresses have been specified can boot using
# BOOTP or DHCP. Hosts for which no fixed address is specified can only
# be booted with DHCP, unless there is an address range on the subnet
# to which a BOOTP client is connected which has the dynamic-bootp flag
# set.
#host fantasia {
# hardware ethernet 08:00:07:26:c0:a5;
# fixed-address fantasia.fugue.com;
# You can declare a class of clients and then do address allocation
# based on that. The example below shows a case where all clients
# in a certain class get addresses on the 10.17.224/24 subnet, and all
# other clients get addresses on the 10.0.29/24 subnet.
#class "foo" {
# match if substring (option vendor-class-identifier, 0, 4) = "SUNW";
#shared-network 224-29 {
# subnet 10.17.224.0 netmask 255.255.255.0 {
# option routers rtr-224.example.org;
# subnet 10.0.29.0 netmask 255.255.255.0 {
# option routers rtr-29.example.org;
# pool {
# allow members of "foo";
# range 10.17.224.10 10.17.224.250;
# pool {
# deny members of "foo";
# range 10.0.29.10 10.0.29.230;
Hi again,
as you can see in your dhcpd.conf all lines which could define a subnet are commented out.
You must define your subnet in dhcpd.cond otherwise the dhcp derver does not know which addresses to serve!
A short guide to dhcpd.conf can be found here: http://www.yolinux.com/TUTORIALS/DHCP-Server.html
What subnet do you use?
Best regards
Alex
Best regards
Alex
Ok Alex,
When looking for my subnet (Rpi not plugged to network) I can see (ifconfig):
nothing into ETH0
for lo: IP=127.0.0.1 Mask:255.0.0.0
Rpi plugged to my home network
ETH0 = 192.168.0.22 Mask:255.255.255.0
Rpi plugged directly to my electronic Item
same as not plugged
I wrote an app in python to send in broadcast mode (UDP) a command witch, when received by my electronic item returns it's MAC & IP address (then I know the IP address to make tcp connection and continue)
When Rpi + electronic item connected to my home network, the program is working fine.
But... I plan to use my Rpi without my home network
May be you can explain how to do it ?
I'm electronician and new to linux...
Regards
Herve
nothing into ETH0
same as not plugged
Regards
Herve
Hi Herve,
subnet is your home network.
But: how does your Rpi get its IP address? Do you use static IP or is your router acting as a DHCP server already? Please provide some information about your home network! What is the electronic item?
Best regards
Alex
Best regards
Alex
Alex,
My Router (internet box) is giving DHCP to my Rpi (I think it works like this)
The electronic Item is a subrack using "Tibbo" (http://tibbo.com/products/modules/x20x/em1206.html)
This Tibbo is a kind of transformer. It has 4 serial ports witch can have communication over network
serial to RJ45
It can be configured to be DHCP or Fixed IP
When connected to a network, it received an IP adress, then, with a command in a broadcast mode (sending 'X' at port 65535) it answer it's MAC & IP address
Knowing it's IP address, it can be connected by classic TCP to receive and answering commands (ASCII in my case) to 4 ports.... Changing this commands into RS232 like serial datas TX&RX (for 1 or more µC)
Hope this can help to resolve my problems..
Regards
serial to RJ45
Regards
OK, but what is the role of the additional DHCP server on the Rpi in this scenario?
Best regards
Alex
Best regards
Alex
The Rpi must be connected directly to my electronic item without my home network.
(It must be installed where there is no available network)
Rpi<------- RJ45 ---------> electronic item
Rpi must have server ability to give my electronic an IP address.
Best Regards
Herve
Best Regards
Herve
OK, I think I understand now.
You can use the same address range on the standalone Pi as your home network,
using a different range does not hurt
Define this in dhcpd.conf and you should be going.
But if you link Pi and device directly, you'll need a crossover cable.
Best regards
Alex
Best regards
Alex
in /etc/default/ifplugd, the default configuration is this
INTERFACES="auto"
HOTPLUG_INTERFACES="all"
ARGS="-q -f -u0 -d10 -w -I"
SUSPEND_ACTION="stop"
Simply changing it to this
INTERFACES="eth0"
HOTPLUG_INTERFACES="eth0"
i guess this is your solution
INTERFACES="auto"
INTERFACES="eth0"
