Duke-Pad
Anyone brave enough to try this : https://wiki.openjdk.java.net/display/OpenJFX/DukePad
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
Funny, I've thinking to build a tablet with RPi since it has came out. I've bought the same LCD panel with HDMI adapter, and the same battery pack from Amazon they wrote in the part list. I also have camera module. So, except the case, MPU 9150 Gyro/Accel/Mag, and some small accessories, I have everything for it
Last night I've started to build the software part of it, today I will finish it.
I've printed the case plan in A3 format, compared the LCD panel to it but the print is smaller
So it can't be use without modification) I would order cutting the case from acrylic if I had the plan in proper format.
Re: Duke-Pad
how am i supposed to do this???On your desktop, clone http://hg.openjdk.java.net/openjfx/8/graphics/rt
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
On Ubuntu/debian/Mint
On Windows :
http://tortoisehg.bitbucket.org/
ghans
sudo apt-get install mercurial
man hg
ghans
Re: Duke-Pad
I am very interested in this.
Apologies if it's a basic question but - will the Duke-Pad run 'typical' Raspberry Pi things - in my case:
- Terminal and GNU/Debian tools (e.g. gcc, bash, apt);
- Web browser;
- Some kind of office software (e.g. LibreOffice)?
I don't care about X11 specifically - if the GUI is achieved by other means this is fine.
Thank you,
Daniel Barker
- Web browser;
Thank you,
Daniel Barker
Re: Duke-Pad
I guess fullscreen JavaFX and X11 are exclusive on the Pi : You can't have both at the same time , but you
should be able to shutdown the one to launch the other , without rebooting the OS (similiar to XBMC on Raspbian) .
ghans
ghans
Re: Duke-Pad
a little bit help on
using ubuntu 13.04
cant get this to workIf you are using IntelliJ IDEA, locate under rt/apps/experimental the DukePad project. Open it and build. It should build, auto-downloading dependencies from maven central. Alternatively, you can try using the gradle build file. To do so, cd into rt/apps/experimental/DukePad. Execute:
me@my-computer:$ gradle artifacts
using ubuntu 13.04
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
Re: Duke-Pad
This could help? : http://www.raspberrypi.org/archives/4920
or should i do this? : https://wiki.openjdk.java.net/display/O ... ng+OpenJFX
Re: Duke-Pad
i think you can give it a try on the pi
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
rt/apps/experiments/DukePad# gradle artifacts
FAILURE: Build failed with an exception.
* Where:
Build file '/home/gabor/a/rt/apps/experiments/DukePad/build.gradle' line: 54
* What went wrong:
A problem occurred evaluating root project 'DukePad'.
Cause: 7
build.grade line 54:
sourceCompatibility = 1.8;
* Where:
* What went wrong:
Cause: 7
Re: Duke-Pad
Hi trying the same...
set JAVA_HOME to the correct JDK1.8.0 directory location and can get it to build with errors, 20, reduced from 100 with variable set. First error being..
Still trying to build using virtualbox ubuntux64 on win7x64
will post progress as & when, cheers mark
/home/lamiii/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:29: error: package org.eclipse.core.runtime.preferences does not exist
import org.eclipse.core.runtime.preferences.ConfigurationScope;
Re: Duke-Pad
i am also getting 20 errors
sahaj@sahaj-Ubuntu:~/rt/apps/experiments/DukePad$ gradle artifacts
:core:compileJava
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:29: error: package org.eclipse.core.runtime.preferences does not exist
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:30: error: package org.osgi.service.prefs does not exist
import org.osgi.service.prefs.BackingStoreException;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:31: error: package org.osgi.service.prefs does not exist
import org.osgi.service.prefs.Preferences;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:38: error: cannot find symbol
private Preferences preferences;
symbol: class Preferences
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:83: error: cannot find symbol
protected final Preferences getPreferences() {
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:38: error: package org.osgi.framework does not exist
import org.osgi.framework.BundleActivator;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:39: error: package org.osgi.framework does not exist
import org.osgi.framework.BundleContext;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:40: error: package org.osgi.framework does not exist
import org.osgi.framework.Constants;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:41: error: package org.osgi.framework does not exist
import org.osgi.framework.ServiceEvent;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:46: error: cannot find symbol
public class CoreActivator implements BundleActivator {
symbol: class BundleActivator
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:54: error: cannot find symbol
@Override public void start(final BundleContext bundleContext) throws Exception {
symbol: class BundleContext
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:89: error: cannot find symbol
@Override public void stop(BundleContext bundleContext) throws Exception {
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:63: error: cannot find symbol
Preferences prefs = getPreferences();
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:66: error: cannot find symbol
} catch (BackingStoreException e) {
symbol: class BackingStoreException
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/DukeApplication.java:84: error: package ConfigurationScope does not exist
if (preferences == null) preferences = ConfigurationScope.INSTANCE.getNode(getName());
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:67: error: cannot find symbol
}, "("+ Constants.OBJECTCLASS+"=com.javafx.experiments.dukepad.core.DukeApplication)");
symbol: variable Constants
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:64: error: cannot find symbol
case ServiceEvent.REGISTERED: root.add(app); break;
symbol: variable ServiceEvent
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:65: error: cannot find symbol
case ServiceEvent.UNREGISTERING: root.remove(app); break;
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:54: error: method does not override or implement a method from a supertype
/home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java:89: error: method does not override or implement a method from a supertype
Note: /home/sahaj/rt/apps/experiments/DukePad/modules/core/src/main/java/com/javafx/experiments/dukepad/core/CoreActivator.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
20 errors
:core:compileJava FAILED
* What went wrong:
Execution failed for task ':core:compileJava'.
> Compilation failed; see the compiler error output for details.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 11.526 secs
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
I have been wrangling with this problem, you should be able to build it using this: http://www.jetbrains.com/idea/download/
I am attempting to build it now. so far without sucess
Visit my website with the original instructions on it for both vanilla and Tekkit Lite Servers: www.picraftbukkit.webs.com
Re: Duke-Pad
My result:
-VirtualBox:~/a/rt/apps/experiments/DukePad$ gradle artifacts
FAILURE: Build aborted because of an internal error.
* What went wrong:
Build aborted because of an unexpected internal error. Please file an issue at: http://www.gradle.org.
* Try:
Run with --debug option to get additional debug info.
* Exception is:
org.gradle.api.UncheckedIOException: java.io.IOException: File '/home/gabor/.gradle/caches/1.0-milestone-3/scripts/settings_5h15qd86ho110tchu6nr4durur/buildscript_SettingsScript/emptyScript.txt' could not be created
at org.gradle.util.GFileUtils.touch(GFileUtils.java:60)
at org.gradle.groovy.scripts.DefaultScriptCompilationHandler.compileScript(DefaultScriptCompilationHandler.java:123)
at org.gradle.groovy.scripts.DefaultScriptCompilationHandler.compileToDir(DefaultScriptCompilationHandler.java:60)
at org.gradle.groovy.scripts.CachingScriptCompilationHandler.compileToDir(CachingScriptCompilationHandler.java:33)
at org.gradle.groovy.scripts.DefaultScriptCompilerFactory$ScriptCompilerImpl.loadViaCache(DefaultScriptCompilerFactory.java:90)
at org.gradle.groovy.scripts.DefaultScriptCompilerFactory$ScriptCompilerImpl.compile(DefaultScriptCompilerFactory.java:69)
at org.gradle.configuration.DefaultScriptPluginFactory$ScriptPluginImpl.apply(DefaultScriptPluginFactory.java:114)
at org.gradle.initialization.ScriptEvaluatingSettingsProcessor.applySettingsScript(ScriptEvaluatingSettingsProcessor.java:64)
at org.gradle.initialization.ScriptEvaluatingSettingsProcessor.process(ScriptEvaluatingSettingsProcessor.java:55)
at org.gradle.initialization.PropertiesLoadingSettingsProcessor.process(PropertiesLoadingSettingsProcessor.java:37)
at org.gradle.initialization.SettingsHandler.loadSettings(SettingsHandler.java:97)
at org.gradle.initialization.SettingsHandler.findSettingsAndLoadIfAppropriate(SettingsHandler.java:87)
at org.gradle.initialization.SettingsHandler.findAndLoadSettings(SettingsHandler.java:46)
at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:133)
at org.gradle.initialization.DefaultGradleLauncher.doBuild(DefaultGradleLauncher.java:112)
at org.gradle.initialization.DefaultGradleLauncher.run(DefaultGradleLauncher.java:80)
at org.gradle.launcher.RunBuildAction.execute(RunBuildAction.java:41)
at org.gradle.launcher.RunBuildAction.execute(RunBuildAction.java:27)
at org.gradle.launcher.ExceptionReportingAction.execute(ExceptionReportingAction.java:32)
at org.gradle.launcher.ExceptionReportingAction.execute(ExceptionReportingAction.java:21)
at org.gradle.launcher.CommandLineActionFactory$WithLoggingAction.execute(CommandLineActionFactory.java:219)
at org.gradle.launcher.CommandLineActionFactory$WithLoggingAction.execute(CommandLineActionFactory.java:203)
at org.gradle.launcher.Main.execute(Main.java:55)
at org.gradle.launcher.Main.main(Main.java:40)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.gradle.launcher.ProcessBootstrap.runNoExit(ProcessBootstrap.java:46)
at org.gradle.launcher.ProcessBootstrap.run(ProcessBootstrap.java:28)
at org.gradle.launcher.GradleMain.main(GradleMain.java:24)
Caused by: java.io.IOException: File '/home/gabor/.gradle/caches/1.0-milestone-3/scripts/settings_5h15qd86ho110tchu6nr4durur/buildscript_SettingsScript/emptyScript.txt' could not be created
at org.apache.commons.io.FileUtils.openOutputStream(FileUtils.java:175)
at org.apache.commons.io.FileUtils.touch(FileUtils.java:220)
at org.gradle.util.GFileUtils.touch(GFileUtils.java:58)
... 30 more
BUILD FAILED
Total time: 6.207 secs
* What went wrong:
* Try:
* Exception is:
... 30 more
BUILD FAILED
Re: Duke-Pad
managed to build, got 100 errors but also some .jars etc. it doesn't work as of yet.
Re: Duke-Pad
have already tried , same problemchromebookbob wrote:I have been wrangling with this problem, you should be able to build it using this: http://www.jetbrains.com/idea/download/
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
Has anyone tried this? : jdk-8-ea-b109-linux-arm-vfp-hflt-25_sep_2013.tar.gz
Re: Duke-Pad
just another weekly buildsirkope wrote:Has anyone tried this? : jdk-8-ea-b109-linux-arm-vfp-hflt-25_sep_2013.tar.gz
will and probably does have the same result!
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
Re: Duke-Pad
And then? We should gave it up?
Re: Duke-Pad
I've managed to build in virtualbox - ubuntu13.04 using itellijidea 12.
After adding OSGI/maven plugins inside Intellijidea and changing project structure settings etc, I can build/run with no errors in Ubuntu but not yet Rpi, still working on it. Will post later with update.
Cheers,
mark
Cheers,
mark
Re: Duke-Pad
Any news?
Re: Duke-Pad
Any news? heeeeellllp!
Re: Duke-Pad
Sorry, not had too much time and reached a standstill,. Can compile and run in windows/linux (virtualbox), but can't run released or on pi, so stumped for the moment.
Re: Duke-Pad
that's y i mentioned BRAVE,, it needs a lot of debugging!ric96 wrote:Anyone brave enough to try this : https://wiki.openjdk.java.net/display/OpenJFX/DukePad
twitter @sahajsarup
skype srics1996
twitter @sahajsarup
skype srics1996
