DirkS
Re: Any news on official Raspberry Display?
Sat Dec 06, 2014 2:20 pm
mung wrote:we may not see the display until after christmas :(
Shoudn't be a surprise... from http://techcrunch.com/2014/10/21/pi-pads/
“This is our first display panel that we’re going to be hopefully getting out of the door before the end of the year or early next,” he added.
Sat Dec 06, 2014 2:46 pm
mung wrote:
gsh wrote:
No unfortunately that doesn't actually help... The reason is that the DPI display has 24 signal lines that all transition up and down at the same time creating huge current spikes in the sources to those lines (i.e. the drivers in the conversion chip). The wires themselves will radiate some energy although it's unlikely they'll create a huge amount because they are so short. But those signals end up travelling out of the unit back down the power wire which tends to be around 2m long - perfect for some 100MHz type interference!
To combat this we add decoupling capacitors and chokes to the board, unfortunately these are expensive and you have to be very careful where you mount them and how you route the signals otherwise you end up coupling the noise straight back into the supply cable. Unfortunately this means the process of creating a device like the display is complicated by the problems of having to iterate the design to reduce the noise. Of course if it was someone else making the board or some Chinese outfit they'd not care, but we have to be much more careful (and we're learning as we go!)
Gordon
Well I know nothing about electronics (in the grand scheme of things) so anything I say is probably wrong, but.
Do switch mode supplies not isolate the supply (at least when switched off)? maybe chained?
You say DPI, I thought it was DSI, are DSI displays not available so that you don't have to get a DPI display and convert DSI to DPI seems a lot of extra electronics :(
What is the LAW requirements for EMC, if it were me I would split up the system sell the screen and the driver board seperately and have a legal disclaimer saying 'driver board not to be used with display as may cause unwanted RFI'. Not really very nice solution for some people when their wifi or TV sets stop working, but I will do anything to save money :lol:
So from what you are saying everything is still in development and we may not see the display until after christmas :(
The law can be interpreted in different ways, but from RS and Farnells point of view, you adhere to the EMC regs as they see them or they don't sell the product. Splitting up isn't really an options.
The display being sold is DPI with the electronics to convert to DSI and supplied with the screen as a small interface PCB. I think this is for cost and supply reasons - cheaper.
Burngate
Sat Dec 06, 2014 5:21 pm
jamesh wrote:The display being sold is DPI with the electronics to convert to DSI and supplied with the screen as a small interface PCB. I think this is for cost and supply reasons - cheaper.
Sooo ... slightly off topic ...
It's a DPI display ... and the Pi has a DPI interface, which Gert's VGA board uses ... could we ditch the DSI-DPI converter and just connect it straight to the GPIO header?
Or am I being a DiPstIck?
jdb
Sat Dec 06, 2014 5:45 pm
Yes, for some value of "working".
Display controllers often have very rigid timing requirements regarding sync signals, clock outputs, blanking intervals and so on. Violating any one of the timing parameters (which generally aren't well documented, if at all) results in a display that doesn't display things.
The amount of manual knob tweaking required to get a display to work, either via DSI or DPI, is not something to be underestimated.
Rockets are loud.
https://astro-pi.org
gsh
Sun Dec 07, 2014 2:19 pm
Yeah as Jonathan says, the DPI could be used but it isn't really much of a solution because then there'll be no GPIOs to do anything else with!
EMI can be got around by selling it as a component of a product ... But that's a great sign of a poor quality product. We at Raspberry Pi are not really interested in creating poor quality anything, we're also making these things in quantities that actually get noticed by import controls who go and check our conformance
So it's not really Farnell / RS who put pressure on us to pass our EMC, but we make sure our products work properly (don't forget poor quality devices will interfere with your WiFi... How would it be if you turn on the display and find that your WiFi doesn't work?
Some things are important...
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
Alexander Brown
Sun Dec 07, 2014 2:24 pm
gsh wrote:Yeah as Jonathan says, the DPI could be used but it isn't really much of a solution because then there'll be no GPIOs to do anything else with!
Gordon
Would be a bit silly to get the display and effectively turn you pi into a tablet and then find you need a wired internet connection because of the interference from the display blocking the Wi-Fi
I am
hippy
Sun Dec 07, 2014 2:52 pm
mung wrote:What is the LAW requirements for EMC, if it were me I would split up the system sell the screen and the driver board seperately and have a legal disclaimer saying 'driver board not to be used with display as may cause unwanted RFI'. Not really very nice solution for some people when their wifi or TV sets stop working, but I will do anything to save money :lol:
Professional companies cannot afford to be so blasé about their responsibility to others who are affected by what they produce or sell. That is why the Pi had to undergo its EMC testing as well.
davidcoton
Sun Dec 07, 2014 5:11 pm
In my experience companies who take short cuts on EMC also take short cuts on the quality and safety of their products. I for one want products that are good in all those areas. If it costs a little more, so be it. It's still cheaper than killing someone by faulty mains wiring, or burning a house down with under-rated components. And don't underestimate the cost of messing about to work round EMC issues -- you can waste hours sorting out a problem caused by a careless manufacturer.
ulix
Mon Dec 08, 2014 1:26 pm
Now it's december, is there any news? Will it happen this year, or next year?
cheers
DirkS
Mon Dec 08, 2014 1:30 pm
ulix wrote:Will it happen this year, or next year?
Yes.
Alexander Brown
Mon Dec 08, 2014 1:35 pm
Yes.
42
I am
gsh
Mon Dec 08, 2014 2:23 pm
First quarter 2015 is the current challenge!
Gordon
shuckle
Mon Dec 08, 2014 2:47 pm
You need time machine for that, so challenge indeed.
gsh
Mon Dec 08, 2014 3:09 pm
shuckle wrote:You need time machine for that, so challenge indeed.
Oops... edited!
Mon Dec 08, 2014 3:17 pm
Oops... edited!
I bet your bank used to reject all the cheques you wrote in January.
ulix
Mon Dec 08, 2014 6:06 pm
Hi Gordon,
thank you for your feedback! It's very appreceated 8-)
AndersNM
Mon Jan 19, 2015 12:19 pm
Any update on a shipment date?
ShiftPlusOne
Mon Jan 19, 2015 12:25 pm
When there is, it will be posted here and/or on the blog.
Mon Jan 19, 2015 1:44 pm
AndersNM wrote:Any update on a shipment date?
Ask again in April.
RaTTuS
Contact: Twitter YouTube
Mon Jan 19, 2015 1:47 pm
1st march ;)
Covfefe
Alexander Brown
Mon Jan 19, 2015 2:11 pm
RaTTuS wrote:1st march ;)
Is this a set release date?
I am
RaTTuS
Mon Jan 19, 2015 2:15 pm
:roll: http://www.raspberrypi.org/forums/viewt ... 00#p674241
Covfefe
BillStephenson
Fri Jan 23, 2015 7:28 pm
ShiftPlusOne wrote:When there is, it will be posted here and/or on the blog.
Or on a vendor's site, or some other blog, but I always miss those so I check here instead.
But for some reason I woke up this morning feeling we're getting close to seeing that post. I might be wrong again about that, but I'm almost positive we're closer...
W. H. Heydt
Fri Jan 23, 2015 7:51 pm
Well....yes... Every day we are 24 hours closer.
ulix
Wed Feb 04, 2015 12:19 pm
It would be great to know something more precise. Now the Pi V2 is out, most people thought this wouldn't happen before the display, what happens with the display? Is the Raspberry Team so bussy that we have to wait another half-year/ year? Is the display gone on hold? Aren't we a community, which loves computing and science, that shares? :?
