ShiftPlusOne
Re: The Raspberry Pi Model B+ Q&A thread
Wed Jul 23, 2014 5:39 pm
I would carefully place the heatsinks in the bin, since they're not necessary and not effective. If you want to use them because they "look cool", then throw them on the RAM chip and the USB/LAN chip. Since it's purely cosmetic, then the glue they use is fine, just make sure you have air flow to avoid negative effects from the heatsinks.
Heater
Wed Jul 23, 2014 7:00 pm
As has been stated here a billion times "the Pi does not need heat sinks". They are a waste of money.
In fact, carelessly applied, by people who have been told they are a "good idea", could actually result in the Pi SoC and RAM running hotter. Thermal pads and paste can get in the way of removing heat, they are not good thermal conductors.
However, never throw heat sinks in the bin. You never know when you are going to actually need them.
Wed Jul 23, 2014 7:56 pm
Heater wrote:As has been stated here a billion times "the Pi does not need heat sinks". They are a waste of money.
That depends on how hot your bin gets. :lol:
AndrewS
Wed Jul 23, 2014 11:36 pm
rpdom wrote:That depends on how hot your bin gets. :lol:
If it's a compost bin you want it to get hot :D
Thu Jul 24, 2014 5:43 am
In that case you tend to get heat stinks :D
RaTTuS
Contact: Twitter YouTube
Thu Jul 24, 2014 8:07 am
Properly running compost bin's should not Stink - if they do then you are probably not getting enough air flow though so need a fan ;)
use your heatsinks on your parallela
Covfefe
Greg Erskine
Thu Jul 24, 2014 10:16 am
Hi guys,
Is there some information on how to connect to i2s on the B+?
I saw a few mentions of i2s and PP test points on the B+ but nothing concrete relating to i2s.
regards
* Raspberry Pi is a trademark of the Raspberry Pi Foundation
plugwash
Thu Jul 24, 2014 10:18 am
In the arm perhipherals datasheet there is a table of what functions are available on what IO lines. There is also a diagram of what IO lines are available on the B+ GPIO header. Putting the two together it should be possible to work out how to hook up I2S.
mahjongg
Thu Jul 24, 2014 10:20 am
same as normal B.
Lots of other things of the B+ remain compatible with the "old" B.
Post edit:
The I2C pins of the B+ are now assigned to different special function ports than the original B, but driver libraries should make that change invisible, as the first release (revision 1) also had a similar assignment difference. Drivers can detect on which revision they are running, and compensate for any hardware difference. off-course this only works when you are using the latest, and adapted driver.
plugwash
Thu Jul 24, 2014 10:22 am
mahjongg wrote:same as normal B.
No, the GPIO lines used for I2S on the B are no longer available on the B+, so you need to look at the pin mux table to find which lines you can use.
Greg Erskine
Thu Jul 24, 2014 10:30 am
Thanks moderators,
I have been looking at what information is available, so far I can not find the information. Where can I find pin mux table please?
I am looking forward to the B+ schematics being released.
regards
plugwash
Thu Jul 24, 2014 10:37 am
There is a partial schematic of the B+ showing the GPIO header pinout at
http://www.raspberrypi.org/documentatio ... matics.pdf
You can find the pin mux table in the arm perphipherals datasheet at
http://www.raspberrypi.org/documentatio ... herals.pdf
Greg Erskine
Thu Jul 24, 2014 11:09 am
Hi plugwash,
Thanks for the links. On the Model B Port 5 (aka Port 6 on rev2.1) had the i2s GPIOs, GPIO 28 to GPIO 31 (ALT2).
On the B+ do we now use GPIO18 to GPIO21 (ALT0) instead?
Although I read the documentation before I didn't think to look for alternative GPIOs. :roll:
many thanks
AndrewS
Thu Jul 24, 2014 12:37 pm
Greg Erskine wrote:Thanks for the links. On the Model B Port 5 (aka Port 6 on rev2.1) had the i2s GPIOs, GPIO 28 to GPIO 31 (ALT2).
Yup, see the handy table I made here: http://elinux.org/RPi_BCM2835_GPIOs
To get this working in the current kernel code, you'll need to edit https://github.com/raspberrypi/linux/bl ... i2s.c#L309 as appropriate (ignoring the inaccurate comments) and then rebuild. I haven't tried this myself, but I've been in touch with one of the IQaudIO developers over email and he confirmed that changing this worked for his board. Send me a PM if you want me to put you in touch.
Although I'm led to believe a "better" way of doing this is to use the new 'gpioman' feature in the firmware, but I don't think this has been documented yet...
PeterO
Thu Jul 24, 2014 4:14 pm
There seems to be an ongoing problem with the web-cam software discussed in this thread:
http://www.raspberrypi.org/forums/viewt ... 43&t=63276
Standard reply to camera freezing is "try this older firmware".
sudo rpi-update 8660fe5152f6353dec61422808835dbcb49fc8b2
However since I'm running it on a B+ I assume the older firmware solution is going to stop the USB/Ehternet from working.
Is anyone looking into the firmware problems that cause camera freezes with this software ?
PeterO
with ice cream
Thu Jul 24, 2014 7:54 pm
I upgraded from a B rev. 2 to a B+, all updates (packages and firmware) have been applied. Now I can't get the camera module to work and my 1-wire thermometer is acting up. Am I missing a step?
Thu Jul 24, 2014 8:47 pm
Camera should be fine. What error are you seeing?
But I'd check the connections first...
with ice cream
Thu Jul 24, 2014 9:06 pm
Thanks for the quick reply. The camera problem seems to be a firmware issue. I downgraded and now it is working (see related thread here).
Greg Erskine
Thu Jul 24, 2014 9:47 pm
Thanks AndrewS,
All clear now. :shock:
blachanc
Fri Jul 25, 2014 2:37 am
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
PeterO
Fri Jul 25, 2014 8:30 am
Just noticed the LEDs on the Ethernet connector on my Bs (not B+) are not working anymore... Is this a consequence of changes made for the B+ ?
PeterO
MrEngman
Fri Jul 25, 2014 8:39 am
PeterO wrote:Just noticed the LEDs on the Ethernet connector on my Bs (not B+) are not working anymore... Is this a consequence of changes made for the B+ ?
PeterO
I don't think it will be. They're working fine on my B2 512MB which was update with rpi-update last night, Jul 24th. There was an issue with the previous update, Jul 23rd, which had problems booting if gpu_mem was less than 64. Even then the LAN LEDs all worked.
EDIT: and I've not seen your problem on all the previous rpi-updates I've done and I usually update this particular Pi every time an update appears.
MrEngman
jdb
Fri Jul 25, 2014 10:35 am
PeterO
You have LEDs *in* your Model B's ethernet connector?
Rockets are loud.
https://astro-pi.org
PeterO
Fri Jul 25, 2014 1:50 pm
PeterO
D'OH !!! I put my B+ in a spare Adafruit case to start with, then moved it to a PiBow and put a B in the adafruit case... Then noticed the LEDs in the connector were not working any more... obviously !!! :oops:
PeterO
mahjongg
Fri Jul 25, 2014 1:59 pm
strange that you had a B with LED's in the Ethernet connector, normally they are simply absent.
Perhaps they had a problem getting Jacks with magnetics without LED's for a while and used what they could get, but I'm not sure what they did with the wires of the LED's as a B doesn't have the holes for them, perhaps they simply cut them off ?
