iteadstudio
Raspberry PI LCD Adapter Kit
Tue May 14, 2013 7:18 am
We released a "Raspberry PI LCD Adapter Kit" before, and you can have our ITDB02-2.4E and ITDB02-2.8 connected directly to the Raspberry Pi for use. Here we provide some demo codes for these two screens – the demo codes are modified based on UTFT and UTouch libraries provided by Henning. As it is only for demonstration, and our engineers are not familiar with the Raspberry Pi, the codes may be a little bit rough thus for reference only.
First, connect ITDB02-2.4E screen module to Raspberry Pi through our Raspberry PI LCD Adapter Kit, then start the Raspberry Pi and enter the system.
Next, we will need to create an IO operation library wiringPi for the Raspberry Pi. For specific installation method, please refer to this post.
After installation, copy the demo code folder we provided to the user directory (then extract the compressed packages) – To facilitate demonstration, we put it directly on the desktop. Run the command line (if it is placed in other locations, modify to the corresponding directory path):
cd / home / pi / Desktop / RPILCD
Then run the command line so that gcc can compile file:
gcc lcd.c lcddemo.c SFont.c-lm-lwiringPi-o lcddemo
After compiling, implement ‘run’ command to see the display results, and Raspberry Pi will drive ITDB02-2.4E to refresh and display of a variety of patterns constantly
sudo. / lcddemo
As we nearly used all the functions provided by UTFT, you can also regard this demo file as half of a library, and you can modify LCDDemo file directly or re-create a new file. That is, you can write a realization program, then save it and use command lines to browse, compile and run to see the implementation effects.
You can download the zip here:http://blog.iteadstudio.com/raspberry-p ... -lcd-demo/
notro
Re: Raspberry PI LCD Adapter Kit
Tue May 14, 2013 11:45 am
The Connection table on the product page has a confusing header: Pins of Raspberry.
Looking at the code example it seem to be Wiring PI Pins.
Wiring Pi pin mapping table: http://wiringpi.com/pins/
I have made a framebuffer driver for the ITDB02-2.8 display (~25 fps). Download prebuilt image here https://github.com/notro/fbtft/wiki
This is the default GPIO mapping which has to be changed to match the adapter (dc=RS):
modprobe fbtft_device name=itdb28fb gpios=reset:17,dc:1,wr:0,cs:21,db00:9,db01:11,db02:18,db03:23,db04:24,db05:25,db06:8,db07:7
modprobe itdb28fb debug=3
iteadstudio
Thu May 16, 2013 11:25 am
Thanks notro ~ Thanks for your supplement about the Wiring PI Pins
And the framebuffer driver is cool , I will try it and give you the reply about my experience. Would you like to make it ITDB02-2.4E support :) We'd like to offer the free 2.4" sample~
notro
Thu May 16, 2013 2:36 pm
iteadstudio wrote: And the framebuffer driver is cool , I will try it and give you the reply about my experience. Would you like to make it ITDB02-2.4E support :) We'd like to offer the free 2.4" sample~
Glad you liked it :)
I had a quick look at the S6D1121 datasheet, and it looks like it uses the same registers to set GRAM update area as the ILI9325. That means you can probably use the flexfb driver.
Use the ITDB02-2.8 example, adjust width, height, gpios and init sequence: https://github.com/notro/fbtft/wiki/fle ... 28-ili9325
I'm a bit busy right now, so I can't make a dedicated driver. I have a display on the shelf that has been waiting 3 weeks for a driver...
Let me know if it works, and I'll add it to the wiki.
stanley
Fri May 17, 2013 6:01 am
I got an older revision D ITDB02-2.4DWOT without touchscreen and I hv a hard time figuring out the Raspberry Pi pinout from this page... without the LCD adapter...
http://store.iteadstudio.com/index.php? ... cts_id=133
There isn't any ICs on the back of the rev D board, is that normal or someone forgot to solder them on it ??
I have the pinout for the TFT LCD but for the Raspberry Pi side, I can't figure out which pins to connect to... is it physical pinout or the GPIO...
I'm looking at the RPILCD.doc , SetPinNU(P0, P1, P2, P3, P4, P5, P6, P7, Prs, Pcs, Pwr, Prst, Pdout, Pirq, Pdin, Pclk);
Which pins are P0 - P7 connect to the RPi ??
Stanley
blog :- http://arduino-for-beginners.blogspot.com/
fb group :- https://www.facebook.com/groups/arduino.for.beginners/
notro
Fri May 17, 2013 12:19 pm
This is to help those using the adapter with the FBTFT driver itdb28fb. I don't have an adapter, so this information is not verified
Raspberry PI LCD Adapter Kit wiring translation table
 ITDB02     Wiring Pi   Raspberry Pi Pin    GPIO rev. 1   rev.2 change    FBTFT pinname
   DB8	         D0             11              17                            db0
   DB9	         D1             12              18                            db1
   DB10           D2             13              21             27             db2
   DB11           D3             15              22                            db3
   DB12           D4             16              23                            db4
   DB13           D5             18              24                            db5
   DB14           D6             22              25                            db6
   DB15           D7              7               4                            db7
   CS	          D10            24               8                            cs
   RS	          D8              3               0              2             dc
   WR	          D9              5               1              3             wr
   RST	         D11            26               7                            reset
   T_CLK          D12            19              10
   T_CS	        D13            21               9
   T_DIN          D14            23              11
   T_DOUT         D15             8              14
   T_IRQ          D16            10              15
   VCC	         +5V            2,4
   GND	         GND        6,9,14,20,25
Load driver
Rev. 1 board
modprobe fbtft_device name=itdb28fb gpios=db0:17,db1:18,db2:21,db3:22,db4:23,db5:24,db6:25,db7:4,cs:8,dc:0,wr:1;reset:7
Rev. 2 board
modprobe fbtft_device name=itdb28fb gpios=db0:17,db1:18,db2:27,db3:22,db4:23,db5:24,db6:25,db7:4,cs:8,dc:2,wr:3;reset:7
Edit: Fixed table, it was too wide.
Skmo
Sun Jun 16, 2013 7:08 am
Notro, thanks for all the work! Just got my kit and lcd in the mail. I can get it to work with the itdb28fb fbtft driver but i cant make it permanent. I can see it is loading the driver on my hdmi monitor but the 2.8 is just black with the back light lit. Is it because the gpios are wired different? I'm kinda lost on this one. Any help would be great!
texy
Sun Jun 16, 2013 7:28 am
if you have the display working, but not permanent, then you probably need to edit the /etc/modules file and add the information.
For example, for the 1.8" TFT displays I sell, I would
sudo nano /etc/modules
and add
fbtft_device name=sainsmart18fb verbose=0 speed=32000000 fps=50
sainsmart18fb
(obviously you need to change those configurations for your display type)
Save those changes with Control-X, Y and reboot your Pi.
Hope this helps,
Texy
Skmo
Wed Jun 19, 2013 5:26 am
notro wrote: Rev. 2 board
Thanks Texy, I Added notros code to the /etc/modules and it works now
bgouveia
Sat Aug 10, 2013 9:05 pm
Hi , I managed to use your driver with an S6D1121 LCD with the following lines :
modprobe fbtft_device name=flexpfb
modprobe flexfb width=240 height=320 regwidth=16 setaddrwin=1 init=-1,0x0013,0xCC00,-1,0x0011,0x2004,-1,0x0015,0x2600,-1,0x0014,0x252A,-1,0x0012,0x0033,-1,0x0013,0xCC04,-2,5,-1,0x0013,0xCC06,-2,5,-1,0x0013,0xCC4F,-2,5,-1,0x0013,0x674F,-1,0x0011,0x2003,-2,5,-1,0x0030,0x2609,-1,0x0031,0x242C,-1,0x0032,0x1F23,-1,0x0033,0x2425,-1,0x0034,0x2226,-1,0x0035,0x2523,-1,0x0036,0x1C1A,-1,0x0037,0x131D,-1,0x0038,0x0B11,-1,0x0039,0x1210,-1,0x003A,0x1315,-1,0x003B,0x3619,-1,0x003C,0x0D00,-1,0x003D,0x000D,-1,0x0016,0x0007,-1,0x0002,0x0013,-1,0x0003,0x0003,-1,0x0001,0x0127,-2,5,-1,0x0008,0x0303,-1,0x000A,0x000B,-1,0x000B,0x0003,-1,0x000C,0x0000,-1,0x0041,0x0000,-1,0x0050,0x0000,-1,0x0060,0x0005,-1,0x0070,0x000B,-1,0x0071,0x0000,-1,0x0078,0x0000,-1,0x007A,0x0000,-1,0x0079,0x0007,-1,0x0007,0x0051,-2,5,-1,0x0007,0x0053,-1,0x0079,0x0000,-3
nice piece of code btw.
I also tried to change it to landscape mode , but it wasn't working very well , changed the resolution and the entry mode , but the screen wasn't updating where it should
Greetings
Bruno Gouveia
notro
Sun Aug 11, 2013 1:33 pm
bgouveia wrote: I also tried to change it to landscape mode , but it wasn't working very well , changed the resolution and the entry mode , but the screen wasn't updating where it should
Maybe this can help you with the entry mode: https://github.com/Tectu/ChibiOS-GFX/bl ... _lld.c#L77
bgouveia
Sun Aug 11, 2013 3:09 pm
Hi , thanks
I actually forgot the rotate parameter... , everything working now.
fbtft_device name=flexpfb rotate=3
flexfb width=240 height=320 regwidth=16 setaddrwin=1 init=-1,0x0013,0xCC00,-1,0x0011,0x2004,-1,0x0015,0x2600,-1,0x0014,0x252A,-1,0x0012,0x0033,-1,0x0013,0xCC04,-2,5,-1,0x0013,0xCC06,-2,5,-1,0x0013,0xCC4F,-2,5,-1,0x0013,0x674F,-1,0x0011,0x2003,-2,5,-1,0x0030,0x2609,-1,0x0031,0x242C,-1,0x0032,0x1F23,-1,0x0033,0x2425,-1,0x0034,0x2226,-1,0x0035,0x2523,-1,0x0036,0x1C1A,-1,0x0037,0x131D,-1,0x0038,0x0B11,-1,0x0039,0x1210,-1,0x003A,0x1315,-1,0x003B,0x3619,-1,0x003C,0x0D00,-1,0x003D,0x000D,-1,0x0016,0x0007,-1,0x0002,0x0013,-1,0x0003,0x0009,-1,0x0001,0x0127,-2,5,-1,0x0008,0x0303,-1,0x000A,0x000B,-1,0x000B,0x0003,-1,0x000C,0x0000,-1,0x0041,0x0000,-1,0x0050,0x0000,-1,0x0060,0x0005,-1,0x0070,0x000B,-1,0x0071,0x0000,-1,0x0078,0x0000,-1,0x007A,0x0000,-1,0x0079,0x0007,-1,0x0007,0x0051,-2,5,-1,0x0007,0x0053,-1,0x0079,0x0000,-3
notro
Sun Aug 11, 2013 3:25 pm
Good, which display are you using? I'm going to add it to the wiki.
Can you also give me the various entry mode values for the different rotations?
bgouveia
Sun Aug 11, 2013 8:47 pm
I bought the dipslay on ebay, in the description the seller says that it uses an ili9235 controller but it actually comes with an s6d1121 , it's an 8bit 2.4" lcd like this one from elecfreaks (http://www.elecfreaks.com/store/24-tft- ... p-110.html) , it comes with a touchscreen and an SD card socket.
the entry modes are similar to the ili9235 (the bit positions are diferent):
Register 0x0003 controls rotation: 0=0x0003, 1=0x000A, 2=0x0000, 3=0x0009
notro
Sun Aug 11, 2013 10:25 pm
chou.aieb
Thu Sep 05, 2013 10:13 am
i got this 2.8" 18-bit color TFT LCD with touchscreen breakout board - ILI9325 from adafruit
here is a link for it :http://www.adafruit.com/products/335
its needs 8 pins for data i/o , 4 for the control input,4 for the touch panel plus the leds and back light.
any ways i'm wondering if any one have an idea on how to wire this display with a raspberry pi model B.
do i wire it to pins of my choice and when loading the module for it assign each db and control pin to the one i've chosen ? or there is a default wiring that needs to be done ?
here is two photos of the display pins:
thank you in advance
Gary Littlemore
Fri Sep 06, 2013 12:33 pm
Would I be able to get this working with RaspBMC? If so, how easy would it be?
3b+, 2b, b+, b, Zero & Zero-W
bmichel
Thu Apr 24, 2014 6:56 pm
The LCD works fine with the adapter kit and notro's driver. However the touchscreen SPI isn't correctly connected. I needed to make some changes in order to make it work:
- Connect ITDB02 pin RST to Raspberry pin 8 (GPIO14) instead of pin 26 (GPIO7/CE1)
- Connect ITDB02 pin T_CLK to Raspberry pin 23 (SCLK) instead of pin 19
- Connect ITDB02 pin T_CS to Raspberry pin 26 (CE1) instead of pin 21
- Connect ITDB02 pin T_DIN to Raspberry pin 19 (MOSI) instead of pin 23
- Connect ITDB02 pin T_DOUT to Raspberry pin 21 (MISO) instead of pin 8
I didn't try to do the modifications on the adapter yet, I just did the connections with wires.
Then the configuration of the drivers is:
fbtft_device name=itdb28 gpios=reset:14,dc:2,wr:3,cs:8,db00:17,db01:18,db02:27,db03:22,db04:23,db05:24,db06:25,db07:4 rotate=90
ads7846_device cs=1 speed=2000000 model=7846 swap_xy=1 x_min=230 x_max=3900 y_min=200 y_max=3700 x_plate_ohms=80 pressure_max=255 gpio_pendown=15 keep_vref_on=1 verbose=3
PS: I have a Raspberry version B rev 2.
Skmo
Wed Oct 22, 2014 12:58 am
bmichel wrote:Hello,
Can you share any pictures of how you did this? I have had this screen laying around waiting to fix the touch screen.
were you able to modify the adapter?
blackcorvo
Sun Feb 28, 2016 2:20 pm
I have a screen like those and a RasPi 2. I'm trying to make a portable gaming device running RetroPie.
How would I go about getting it to work? I'm completely clueless to all the codes and I just would like help walking through the process of installing it properly, because I have no idea how to proceed in regards to that.
I made an adaptor out of an old 40-pin IDE cable using the "fixed touch pinout" posted by bmichel, and I'll post a pic of my reference sheet for the cable connections. If there's something wrong in it let me know, please!
This diagram is wrong. Updated version has green arrows!
blackcorvo.com
She/They since August 2021
blackcorvo
Tue Mar 01, 2016 1:19 am
I would deeply appreciate if somebody could help walking me through the process of getting the screen to work.
I see many people have looked at the picture I posted already, but I'm seeking some enlightenment here!
I have Raspbian and RetroPie with a few roms, both installed via Berryboot (with a boot selection screen at startup), thanks to following tutorials.
So, what I'd like help with is:
What do I need to download?
How do I install it all in my Pi?
How to I add the touchscreen fix? Unless there's a "pre-fixed" file I can get and use?
Do I need to calibrate the touchscreen after finishing the installation? How is it done?
I'm completely new to this and I have never worked with Linux/Unix systems before. Thanks ahead for any help or tips on getting it working.
blackcorvo.com
texy
Tue Mar 01, 2016 10:16 am
contact the supplier - they have designed it to work with the Pi so should know how to configure it. It must of at least worked back in 2013, although not with a Pi2.
Your diagram doesn't tie up with this :
Texy
blackcorvo
Tue Mar 01, 2016 10:29 pm
texy wrote:Hi,
It's a generic screen and it has no info on it's manufacturer.
texy wrote: Your diagram doesn't tie up with this :
Texy
Why not? Is it the RasPi or the ITDB02 pins that are wrong? I used mine for reference and it didn't have the exact same names for the pins (T_DOUT is T_DO on mine, and RST is REST). What would then be the correct connections to be made?
Just for reference, here's a couple pics of my particular screen module:
Image Image
It seems to be similar to the ones from itead.
[EDIT]
I have mistakenly counted the pinout for my screen board. I'm working on a corrected version of the connection diagram that I'll be posting soon, I apologize for my mistake!
blackcorvo.com
blackcorvo
Thu Mar 03, 2016 12:51 am
Here is the updated diagram. Again, I'm sorry for the mistake! Hopefuly it's all correct now.
Corrected connection diagram
blackcorvo.com
T4d3o
Sun Nov 13, 2016 10:44 am
bgouveia wrote:Hi,
Hi.
I have the same LCD. I'm using https://github.com/notro/fbtft/wiki/LCD ... #itdb02-28 for wire connections but I only get a white screen when load driver like described here https://github.com/notro/fbtft/wiki/fle ... 24-s6d1121
What I'm doing wrong?
Thanks in advance.
Return to “Other projects”
