yv6eda
Updates for this repository will not be applied
Thu Sep 16, 2021 9:12 pm
Hello! I'm a rocky here.
I'm running Raspberry Pi OS and today I tried to run -sudo apt-get update- and I received three times -Updates for this repository will not be applied-.
I then try -sudo apt update- and received the same.
Please help! Thanks in advance!
Jorge
Re: Updates for this repository will not be applied
Thu Sep 16, 2021 11:03 pm
Please post all the output of apt update. There may be information in there that will help us.
Post in [ code] [ /code] tags (without the spaces) so it looks like
this
as it is easier to read that way.
Unreadable squiggle
yv6eda
Fri Sep 17, 2021 1:28 am
Thank you @rpdom
Here is:
pi@pishack:~ $ sudo apt-get update
Get:1 http://packages.microsoft.com/repos/code stable InRelease [10.4 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian buster InRelease [32.7 kB]
Reading package lists... Done
E: Release file for http://packages.microsoft.com/repos/code/dists/stable/InRelease is not valid yet (invalid for another 197d 2h 16min 27s). Updates for this repository will not be applied.
E: Release file for http://raspbian.raspberrypi.org/raspbian/dists/buster/InRelease is not valid yet (invalid for another 197d 12h 5min 42s). Updates for this repository will not be applied.
E: Release file for http://archive.raspberrypi.org/debian/dists/buster/InRelease is not valid yet (invalid for another 197d 2h 27min 27s). Updates for this repository will not be applied.
pi@pishack:~ $
Cloudcentric
Fri Sep 17, 2021 1:56 am
Thank you @rpdom
Here is:
pi@pishack:~ $
It would appear your date / time is not correct :?
When you set this correctly:
sudo apt update
sudo apt full-upgrade
sudo reboot
Return to “Raspberry Pi OS”
